2001 Limited 4x2 rear dif finally broke...
Discussion in '1st Gen Tundras (2000-2006)' started by AH64Tundra, May 6, 2025 at 4:06 PM.
  1. May 6, 2025 at 4:06 PM
    AH64Tundra
    AH64Tundra [OP] New Member
    2001 Tundra Limited
    Lifted with Billstien 5100, on steel wheels and a lot of maintenance needed.
    I have a 2001 Tundra Limited 4x2, rear dif has finally gone and i am in need a Third Member or finding out what to replace and fix so i can have her driving again.
    I believe the gear ratio is 3.91, i've looked into doing a more modern swap into the 2014 tundra rear ends with disk brakes but being a the hawaii budget doesnt leave many options.
    ive seen pricing for brebuilt and remanufactured third members but as the truck doesnt drive because the rear dif i am open to options and buying a new one.Mahalo
  2. May 6, 2025 at 5:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    Grab one out of a wrecking yard
  3. May 6, 2025 at 5:44 PM
    AH64Tundra
    2001 Tundra Limited
    Can't find any, checked multiple places with either no response or in stock. Plus id have to figure out how to get it home, kinda hard to transport that with only a bike.
  4. May 6, 2025 at 5:58 PM
    Time to buy another 1st gen, so you can go to the junkyard and get parts to fix your other 1st gen. Then you're blessed with double the 1st gen, double the fun.
  5. May 6, 2025 at 6:02 PM
    AH64Tundra
    2001 Tundra Limited
    Not gonna lie...i've thought of that!
  6. May 6, 2025 at 6:33 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You can use a seqouia 3rd member, bonus is they are all 4.10 gears.
  7. May 7, 2025 at 3:44 AM
    bfunke
    Where are you located Apache?
  8. May 7, 2025 at 5:09 AM
    Shipping may be expensive but I have a 4.10 diff chilling here doing nothing.
  9. May 7, 2025 at 5:10 AM
    Have you already diagnosed what failed in your third? Is the rest of the axle housing and components good otherwise?
