Milwaukee Tools
Discussion in 'Off-Topic Discussion' started by T-Rex266, Nov 9, 2024.
  1. May 4, 2025 at 5:18 PM
    #1921
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Who makes stronger screw bits, Milwaukee or Diablo?
  2. May 4, 2025 at 5:24 PM
    #1922
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have not had great luck with Milwaukee bits
    T-Rex266[QUOTED][OP] likes this.
  3. May 4, 2025 at 5:28 PM
    #1923
    I broke a few of them yesterday trying to break a bolt loose :anonymous:
    ZappBrannigan[QUOTED] likes this.
  4. May 5, 2025 at 9:01 PM
    #1924
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    T-Rex266[OP] likes this.
  5. May 6, 2025 at 11:03 AM
    #1925
  6. May 6, 2025 at 7:03 PM
    #1926
    French Avocado
    Utah / Wyo
    Here it is:
    https://www.tundras.com/threads/milwaukee-tools.150636/page-45#post-3846681
    Because of the Renegade tonneau I used Integral Truck bedside panel drop bracket extenders to lower the mounting to the rails - https://integraltruck.com/products/...op-bracket-kits?_pos=1&_psq=drop&_ss=e&_v=1.0. Then, you can use any T-Slot fastener, such as https://www.amazon.com/dp/B0BG7BMLX...04b4a&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWw&th=1 or https://www.amazon.com/dp/B09Z8Q42D2 from Scamazon.
  7. May 7, 2025 at 5:34 AM
    #1927
    Ghost Rider
    Ian
    Cypress, Texas
  8. May 7, 2025 at 6:57 PM
    #1928
    French Avocado
    Utah / Wyo
    No back plate. T-Slots in the rails, Integral Truck drop brackets attached to T-Slots (not needed if you do not have a tonneau), then Packout plate attached to drop brackets. I have a Bed Rug and the Packout bottom fits snug to the Bed Rug. (If you have an open bed then Integral Truck sells locking plates. I only used the brackets and not the panel.) I used two large Packout wall plates https://www.homedepot.com/pep/Milwa...L5dHSMxklMPfEqKZ_wRoCG48QAvD_BwE&gclsrc=aw.ds. I can grab some close-up photos if you want.
