Added MTS/Crawl Control switch to Platinum CrewMax
Discussion in '3rd Gen Tundras (2022+)' started by Tundra_Lover7, Oct 19, 2022.
  1. Apr 7, 2025 at 1:33 PM
    #361
    Main Lo
    Main Lo New Member
    2023 Tundra CrewMax 4x4 SR5 TSS
    You got a deal!
    ESalt206 likes this.
  2. Apr 7, 2025 at 4:43 PM
    #362
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    I can confirm that it works on my truck. 2024 Platinum with AVS and rear air.
    mikewantsabeer and Blufin like this.
  3. Apr 7, 2025 at 4:48 PM
    #363
    Mb911
    Mb911 New Member
    Be
    24 sr5 4x4
    TRD wheels
    Yes bought out of a low mileage wreck but still doesn’t work so not sure it was worth it.
    ziznack likes this.
  4. Apr 7, 2025 at 7:19 PM
    #364
    mikewantsabeer
    mikewantsabeer New Member
    Pacific County, WA
    2023 Tundra Limited
    glad it worked for you!
    ziznack[QUOTED] likes this.
  5. Apr 7, 2025 at 10:34 PM
    #365
    ziznack
    ziznack New Member
    Texas Y'all
    Thanks bud!
  6. Apr 21, 2025 at 6:03 PM
    #366
    spliffgates
    spliffgates New Member
    2022 Magnetic Grey SR5 Tundra 4x4
    Just tried installing on my 22 sr5 4x4 with convenience package and it didn’t work unfortunately. Going to be selling mine if anyone in the Phoenix AZ area is looking for one.
  7. Apr 25, 2025 at 1:10 PM
    #367
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    OK, I just tried to put the switch in mine and I can barely get the front of the current switch up enough to even shine a light in there. Definitely can't pull the back of the switch up any further. There was little to no slack in the wiring below and I'm cautious about pulling too hard and causing an unnecessary issue.
    For those that were successful, how were you able to get enough room to pull out the plug? I've got a 2025 Limited.
  8. Apr 25, 2025 at 1:24 PM
    #368
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Once you got the switch unhooked / released from the snap fits, tilt it back towards the center console since the hook on the plug faces the front of the truck. Then you can bareeely fit fingers or a screwdriver in there to unhook the plug. My wiring harness was also super tight. Plugging in the new switch is even more fun. I still haven’t replaced my MTS switch with the old one bc I’m not motivated to do that again. Good luck!
  9. Apr 25, 2025 at 4:38 PM
    #369
    Rookhoe
    Rookhoe New Member
    Binghamton, NY
    2025 Mesquite Toyota Tundra Limited
    Basically this. I also have a 2025 limited and the harness was super tight. I pretty much “fondled” it until I was successful, lol. I almost gave up and asked my wife to get her small hands in there to see if she could connect the harness.
    chrisgibbs707[QUOTED] likes this.
  10. Apr 26, 2025 at 6:32 AM
    #370
    nkawal
    nkawal New Member
    2024 Tundra Limited
    Pop off the small side panels and you can stick your fingers to hold the harness up while you plug it in. This is what I did on my 24.
    Rookhoe likes this.
  11. May 6, 2025 at 1:38 PM
    #371
    mayoutze78
    mayoutze78 New Member
    I'm bummed, I added the MTS/Crawl switch assembly but MTS doesn't work. I knew crawl wouldn't but hope that MTS would. I disconnected the battery, nothing!
    24 Limited 4x4 crewmax. Non OR.
    Would a zero point calibration help at all?
  12. May 6, 2025 at 3:36 PM
    #372
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I have a 24 Limited as well & it works fine. Did you put it in 4wd & make sure it was locked in before you tried the switch? That's been one thing that a few overlooked.
  13. May 6, 2025 at 4:24 PM
    #373
    nkawal
    nkawal New Member
    2024 Tundra Limited
    I too have a 24 limited crewmax and it worked fine with MTS. You must make sure that 4H or 4L is engaged first.
  14. May 6, 2025 at 5:14 PM
    #374
    mayoutze78
    THank you for replying, unfortunately I tried it all. Closed doors, drive D or R, 4i, 4h, moving, not moving... nothing! Oh well, the buttons look cool...
    Blufin and chrisgibbs707 like this.
  15. May 6, 2025 at 7:45 PM
    #375
    DrinksOnMe
    DrinksOnMe New Member
    2024 Silver Tundra Limited 4x4
    Do you have the hybrid? Anyone else non-hybrid limited 4x4 get this to work? I wonder if it is only hybrids because the whole Offroad and Trd pro line are hybrids. Would make sense for the limited hybrid 4x4s to be the foundation for the TRD lines.
    Blufin likes this.
  16. May 6, 2025 at 7:53 PM
    #376
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    People with non-hybrid have had it work. Even an SR5 without the PVM. It’s a mystery so far.
  17. May 6, 2025 at 8:02 PM
    #377
    chrisgibbs707
    Socal
    2022 Tundra SR5 4x4
    I wonder if the brake booster / ABS module is different on some. If not, I’d imagine it’s a software based thing, right?
    DrinksOnMe likes this.
  18. May 6, 2025 at 8:08 PM
    DrinksOnMe
    I would say technology package with the full digital screen display for graphics. But I recall someone here had one with just the small screen and analog odometer. I could be wrong. It’s been a while since I have read through this whole thread and I don’t plan on doing it again for my own sanity.
  19. May 6, 2025 at 8:15 PM
    #379
    60centenergy
    60centenergy New Member?
    Zack
    Greenville, SC
    2024 Lunar Rock SR5 Tundra TRD Sport
    Yes, I’m one of the SR5s without PVM that has it working. Actually just used the MTS mode this last weekend on a trail I was on. It worked great. I thought it may be wiring differences at first but that was debunked so don’t know what’s different.
  20. May 6, 2025 at 8:16 PM
    #380
    60centenergy
    Zack
    Greenville, SC
    This one was me. I have the SR5 with analog gauge and small radio screen.
  21. May 6, 2025 at 8:52 PM
    #381
    DrinksOnMe
    This makes me feel better. Remembering that made brain hurty.
    I’m glad we got around the Offroad upcharge. We should make custom badges “TRD OffRoad sans Crawl” for our trucks. Then we can silently nod with approval at one another as we pass by.
  22. May 7, 2025 at 5:03 AM
    #382
    mayoutze78
    It’s a complete mystery, I have the hybrid with digital gauges, big screen…
    Considering looking at the 4x4 control module!?
