Decided to make my oil changes a bit easier....
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1999cutiger, Jan 28, 2018.
  1. Jan 28, 2018 at 12:19 PM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Access hole cut into the factory skid plate. Doesn’t look great....but it’s easy to do and effective. I did not measure the cutout....but it’s approximately 7” square. Make sure to use a file on the edges, unless you like tetanus.
    Sorry about the crappy pics...
    CORRECTION: The cutout is 5” square. I just measured it.
    CA039F4A-FCFB-4083-98B6-CED93DBD1A1E.jpg E44D0C93-BAEE-4499-BCA7-E76751EA6AD9.jpg
  2. Jan 28, 2018 at 12:37 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Nice work, one thing I liked about my e53 BMW X5 with 4.8 V8 was the easily accessible oil filter canister that was under the hood, had a screw in cover that allowed the filter to drain into the engine and pull the filter easily.
  3. Jan 28, 2018 at 1:22 PM
    rodm1
    rodm1 New Member
    I'm going to do this to, was wondering what size hole to use. Are you going to make a cover plate?
  4. Jan 28, 2018 at 1:25 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Good idea. Maybe some type of swivel plate.
  5. Jan 28, 2018 at 1:28 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Good idea. Would a 5 inch hole saw be big enough?
  6. Jan 28, 2018 at 1:58 PM
    1999cutiger
    I think a 5” hole would work but is a little on the small side IMO. However, keep it as small as you are comfortable with given the fact you are removing metal from the skid plate.
    The cutout in the picture looks much larger than it really is...the hole might he closer to 6”...I did not measure it.
  7. Jan 28, 2018 at 2:03 PM
    1999cutiger
    I have no plans for a cover plate...I rarely go offroad and when I do it’s really tame. For heavy offroad use...a cover plate might be a good idea.
  8. Jan 28, 2018 at 3:36 PM
    Stig
    Stig New Member
    Not sure what it's called but there is a flexible trim type material that's designed to cover cut sheet metal. I know you filed it down but that would give you a little more insurance for your wrist when you go to spin on the canister.
    Jernik and Rocko9999 like this.
  9. Jan 28, 2018 at 3:39 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Can you use the cut plate, fab up something where you can secure back and release when ready?
  10. Jan 28, 2018 at 3:49 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Why in the hell didn’t Toyota engineer a drop down cover plate? My wife’s Highlander has an opening.
    Nice job. I may consider doing the same.
    Tundra2010&60 likes this.
  11. Jan 28, 2018 at 3:55 PM
    1999cutiger
    Thanks.
    I agree...Toyota missed on this one.
    The Highlander is a good design...my wife has one too.
  12. Jan 28, 2018 at 4:00 PM
    1999cutiger
    CORRECTION: The cutout is 5” square...I just measured it.
    BTBAKER likes this.
  13. Jan 28, 2018 at 5:51 PM
    Aurora CO
    Cool. This has been done, except an access plate was utilized with hinges and quick disconnect...
    NewImprovedRon likes this.
  14. Feb 28, 2019 at 12:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Resurrecting an old post. I am going to be changing my oil in the next week or so. I got oil today and a filter from my dealer. I am so ordered a fumoto valve and a new aluminum filter housing.
    I really wanna cut a hole in my skid plate for easy access in the future. I will try to figure a way to rivet a hinge and latch in place too. Has anyone who had cut a hole and left it open had any issues with the hole? I do not offroad at all and figured adding the aluminum housing add some protection, if for some reason I can't get a cover fabbed up.
    Dawgmech and Berdine like this.
  15. Feb 28, 2019 at 1:09 PM
    @CMB did this.....
  16. Feb 28, 2019 at 1:17 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    I plan on doing this without any type of door. No offroading we should be fine.
    Thinking of trimming the hole out with door edge trim, something like this:
  17. Feb 28, 2019 at 2:07 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I wouldn’t worry about it. Quite a few Tundras don’t even have a skid plate. The Platunim my buddy just bought doesn’t have one so I don’t think you risk anything leaving a hole there. I was going to get mine cut and covered by a fab shop but they wanted 200 bucks so I just ordered a RCI.
  18. Feb 28, 2019 at 3:01 PM
    Pudge
    CT
    That I can do. Thanks Jim!
    BTBAKER likes this.
  19. Feb 28, 2019 at 3:45 PM
    :thumbsup:
    Pudge[QUOTED] likes this.
  20. Feb 28, 2019 at 5:31 PM
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    I had the same problem on my 2015 4Runner. And it had that crappy plastic housing for the filter can. I lived with the plate and dropped it when I needed to change it. But, I changed out the housing cover for an aluminum one (because I cracked it). That (swap it out for the aluminum housing) is the first thing I am doing when I do my first oil change.
    Pudge likes this.
  21. May 31, 2021 at 12:12 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Here’s my version.
    Door is 1/16” steel, 7 x 8”, bent and painted black. Opening is 6 x 6.5”. Door opens by removing (2) 10mm bolts from clip nuts and is held open with a spring clamp when working.
    18905B06-95D7-4348-84B7-93E08FD10700.jpg 7AE9EA18-1231-4C8D-BAC2-6CA337B778E6.jpg 4306CB97-A532-47FF-B59D-8EBEE66489FB.jpg
    My thanks to ideas posted previously in this and other threads.
  22. May 31, 2021 at 12:25 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Waited many years for this. Makes changing oil very easy.
    Mater, camron1039, The Dude and 16 others like this.
  23. May 31, 2021 at 2:09 PM
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    Very appropriate photo.
  24. Jun 2, 2021 at 7:55 PM
    jomoco
    jomoco New Member
    joe
    2021 SR5 Cement
    Nice!!!!! I'm envious!!!!!Nice!!!!!
    waynescaggs likes this.
  25. Jun 3, 2021 at 10:05 AM
    cain0725
    cain0725 New Member
    nice shop
    Avi8or likes this.
  26. Jun 3, 2021 at 10:10 PM
    R65
    R65 New Member
    2021 Tundra double cab
    Yes
    Man cave
    Avi8or likes this.
  27. Jun 4, 2021 at 3:59 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I hope no one is actually making these holes or hatches any more. Just get yourself a nice RCI skid plate, it comes with the hatch. And it's a much nicer plate, very heavy duty.
    The Tundra TRD skid plate has this. Toyota didn't miss it.... they left it out so you could upgrade.
  28. Jun 4, 2021 at 5:28 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I upgraded. To an RCI skid.
    15whtrd likes this.
  29. Jun 4, 2021 at 6:57 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I just ditched mine on my last oil change. Before that I used an old paint tray to catch the oil draining from the filter. It was as big a PITA as removing the skid plate. The oil filter change was so easy without that @#$% skid plate.
  30. Jun 4, 2021 at 7:02 AM
    15whtrd
    15whtrd Mr. Blonde
    :woot:
