Rear Differential Gear Oil Recommendation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 8, 2019.
  1. Sep 8, 2019 at 8:58 AM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Howdy,
    Toyota dealer too far and blows a day of work for me.
    So what would be as good or better option for Rear Differential Gear Oil I could find at AutoZone or O'Reilly's?
    I saw a couple threads about it draining pretty dirty in short order and I was towing a lot so figure a good simple maintenance.
    Thanks,
    Greg
  2. Sep 8, 2019 at 9:07 AM
    15whtrd
    15whtrd Mr. Blonde
    Mobile one is good stuff. I’m running royal purple but I have a couple 5 qt jugs of M1 to service my diffs later. I think some people run red line as well as Amsoil. But M1 is readily available and good stuff.
    Trooper2 and Greg Marmalard[OP] like this.
  3. Sep 8, 2019 at 9:10 AM
    Greg Marmalard
    Thanks!
    So LT 75W-85 GL-5 or equivalent...
    I guess they are not LSD so no need for an LSD specific.
    Dang that pumpkin hold a gallon of lube!
    Thanks!
    G
  4. Sep 8, 2019 at 9:13 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  5. Sep 8, 2019 at 9:27 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Oriellys carries redline as well in my area. Surprisingly few options for a chain store
  6. Sep 8, 2019 at 9:28 AM
    Greg Marmalard
    Never used Red Line..
    Is it a premium on par with Mobil 1?
  7. Sep 8, 2019 at 9:28 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
  8. Sep 8, 2019 at 9:35 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I just put Valvoline Synthetic 75W90 in my Crewmax
  9. Sep 8, 2019 at 9:48 AM
    six7zero
    six7zero New Member
    Pacific Northfresh 503
    15 SR5 Crewmax
    25% off on 150 or more with free shipping to home. I did front and rear except the transfer case. I just added stuff on my cart to hit that 150 minimum.
    Pudge likes this.
  10. Sep 8, 2019 at 9:54 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I like Amsoil and run 75-140 in the front diff. I think thicker is better for towing. Because of the ARB locker in the rear it's not a syn and I run Lucas 85-140.
    BestGen likes this.
  11. Sep 8, 2019 at 10:11 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Actually im half asleep. I meant lucas oil. Thats the local stock up here
    831Tun likes this.
  12. Sep 8, 2019 at 10:27 AM
    Trooper2
    JR
    Advertised as a premium, will cost more than M1. M1 should meet or exceed your needs. Changing regular is the key.
    YardBird likes this.
  13. Sep 8, 2019 at 11:57 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I like Schaeffer oil. My local gear shop uses it. Schaeffer makes a 80-140w I use in my rear diff that has an Auburn LSD. Nitro Gears branded oil is also Schaeffer.
    kparrow and 831Tun like this.
  14. Sep 8, 2019 at 12:04 PM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    I concur on the Valvoline. The only Mobil 1 I use is engine oil and having second thoughts about it.
    RitcheyRch[QUOTED] likes this.
  15. Sep 8, 2019 at 12:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I just changed mine. Rear and front. 52,000 miles. I don't tow anything other than my motorbike trailer (with bike) occasionally. I used Red Line 75-90. Cuz I'm a big Red Line (boutique oil company) fan.
    GHOST and YardBird like this.
  16. Sep 9, 2019 at 12:44 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    BTBAKER, TRDblvd and Haggis777 like this.
  17. Sep 13, 2019 at 6:31 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
  18. Sep 13, 2019 at 7:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yeah it was a pretty good eye opener as far as quality of some oils.
    I was happy I found the article again. I only read it once about a year ago.
  19. Sep 14, 2019 at 7:57 AM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Amsoil severe gear 75-90.
    Larly5000 likes this.
  20. Sep 14, 2019 at 8:20 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Redline Heavy Shockproof. Especially if you're running a locker. Flows like 75-90 but with a film strength of 250wt. Pricey but really quieted down the ratcheting of my Spartan locker.
  21. Sep 14, 2019 at 4:09 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I changed my rear diff oil today. Went to the dealer to get crush washer and the guy said they use 75w90 in diffs and T-case for tundras....even though Toyota calls for 75w85 in diffs and 75w in the transfer case.
    I went with 3.8 quarts of Mobil 1 oil for the rear diff and will do the same in the front and i think the front take 1.6 quarts. I still think I will order some 75w for the T case, it only takes 2 quarts so even though its pricey I'll go with Toyota recommends for that oil, the 75w90 is close enough for the diffs but much different that 75w from what I have read.
    It was an easy job. One tip that I am sure you have all heard before is to make sure you can loosen the fill plug before you drain the fluid out. You don't wanna end up with an empty differential and no way to fill it.
    Trooper2, georgiey22 and 15whtrd like this.
  22. Sep 14, 2019 at 4:20 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I wouldn’t worry about anything using the 75W 90 in the diffs. But the guy at the dealership is a complete moron. It “was” OK to use the same stuff from your differentials in your transfer case until they changed the transfer case in either 2014 or 15. Now it’s 75W. If your transfer case has pipe plugs for drain and fill, it’s the new unit that requires 75W. If the dealer is really putting in differential gear oil in these new transfer cases, it may come to bite them in the ass. But knowing them they will still get the customer to pay for the future repair.
    I can tell you firsthand what happens when you put in the wrong stuff, it will not disengage properly, it will stick in 4 hi until a slight turn is made. I promptly changed it out for 75W end is working flawlessly again. What’s unknown here is what could happen long-term using the wrong fluid. Probably minimal for people who don’t use it much. It’s possible there could be very few ramifications, but I just find it completely ridiculous that the dealer won’t even follow manufacture specs.
  23. Sep 14, 2019 at 4:26 PM
    Pudge
    CT
    Thanks for the reply Sean. I was a little baffled by him saying 75w90 was okay in the T case too, I get that its close enough for the diffs but that's way off from 75w . I'm glad I didn't do what they recommended. Like I said I plan to get some 75w for the T case, I just need to find some now. I think I saw Ravenol and redline make 75w. What brand did you use?
    I haven't looked at my T case very well so I'm not sure what the drain and fill plugs look like. I do know that the dealer did NOT have any part numbers for crush washers or gaskets for tanger care plugs, so it must be the type you're talking about. I will have to dig into some research on this.
    15whtrd likes this.
  24. Sep 14, 2019 at 4:32 PM
    15whtrd
    15whtrd Mr. Blonde
    I used the Ravenol. There are a couple threads here And some people advise against it. But a few of us have been using it without any problems. The safest bet is to use the Toyota stuff if you’re concerned.
    Sorry for the crooked picture but this is what your T case should look like. The lower pipe plug with the 1/2” square drive and the other one is the fill on the right hand side of the T. case.
    No crush washers required.
    Pudge[QUOTED] likes this.
  25. Sep 14, 2019 at 4:37 PM
    Pudge
    CT
    Thank you very much. That pic is perfect. I'll order up some of the Ravenol. I think it said 2.2 quarts
    15whtrd[QUOTED] likes this.
  26. Sep 14, 2019 at 5:07 PM
    15whtrd
    15whtrd Mr. Blonde
  27. Sep 14, 2019 at 5:14 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I use the conventional 85W-140 I find at O'Riellys. Red Line and Royal Purple can keep their $20 per quart gear oil...
  28. Sep 14, 2019 at 5:15 PM
    Pudge
    CT
  29. Sep 14, 2019 at 5:19 PM
    15whtrd
    15whtrd Mr. Blonde
  30. Sep 14, 2019 at 5:26 PM
    computeruser6
    Dirk
    Escondido
    Avi8or, classiccat and 915tundra like this.
