Stock HU, audio upgrade questions
Discussion in 'Audio & Video' started by Kilos, Dec 11, 2016.
  1. Dec 11, 2016 at 7:21 AM
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    Tundra Crew - need some advice on an audio setup. Looking to keep my stock Premium Entune HU (non JBL) to retain all of the factory uses such as Bluetooth, backup camera, entune, etc. (2017 TRD Pro CM)
    Went to a few local audio shops and came up with this:
    Amp - Alpine PDR-V75 five channel
    Pioneer sub - TS-SW2502S4 shallow mount 10in (one)
    Custom box - mounted behind the rear seats
    Rear speakers - Alpine SPR-60 6.75in
    Front speakers - Alpine SPR-69 6x9
    Dynamat Xtreme - 4 doors, roof and back cab wall
    Premium four gauge wiring for the amp
    With install, total would be $1500 and requires a full day. Supposedly the amp has a built in line converter to clean up the signal.
    Checked out *********, but don't want to do the install myself and I'm in AZ. Want to make sure it's a clean, high quality sound (I'm a bit of an audiophile), but have never kept the stock HU in previous vehicles. Not looking for extreme bass output either.
    Thoughts, changes, advice? Thanks in advance!
  2. Dec 11, 2016 at 7:09 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Well, I can tell you right now, your head unit puts out a dirty signal and no amp or regular line converter will clean it up. I tried with an audiocontrol lc7i, but got low end white noise. Lot of money to have something like that. The only thing you can do is try though. Let me put it this way, if you go thru with your plan and don't have any dirty sound, you will be the first person to do it that I know of. Some say a high end line converter will do it, but I have my doubts. Looking at the taco tunes converter, it looks very similar to the lc7i. For me it was an easy decision though, I had a basic head unit in my 13. If I were in your shoes, I'd try with what you've got with the thought that if I didn't like the sound, I'd invest in a high end line converter later. Good luck. Looking forward to hearing the results.
    Kilos[QUOTED][OP] and GNTundra like this.
  3. Dec 11, 2016 at 7:29 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Keep us posted with some pics Brett. Very interested to see the outcome quality. Thanks.......
    Kilos[QUOTED][OP] likes this.
  4. Dec 11, 2016 at 7:34 PM
    TruckyTruck
    Gary
    Yep, you would be the first. there was a guy here who said he didn't have any problems, but came back later and said he had low end white noise. When your volume is at zero or 1, you don't hear anything? If not that's great. Tell us what you installed!
    Kilos[OP] likes this.
  5. Dec 12, 2016 at 1:59 PM
    TruckyTruck
    Gary
    I loved how much power the lc7i gave, but the dirty signal was just awful. Same with everyone else that's had one. Except for you! Well that's pretty nice. Even though my head unit was basic, I would have preferred to keep the stock look.
  6. Dec 27, 2016 at 7:13 PM
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    Change of plans Crew...
    Pulled the trigger on this set up and having it installed Monday:
    JL Audio 13tw5 and box (sub)
    JL Audio xd700/5 channel amp
    Memphis MClass 6x9 front doors
    Memphis MClass 6.5 rear doors
    Dynamat XTreme: doors, floor, back wall
    Premium wiring for entire system
    (will add the ********* ReCurve later if needed)
    Pics and full review to follow...
    DOZER505 and TruckyTruck like this.
  7. Dec 29, 2016 at 6:49 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Sounds like a great deal for 1500 installed. I also used the factory HU (into an LCQ-1 before the amp) and had No problems with noise. You can see my set up on my audio install post if you're interested.
    Congrats on the new mod!
    Kilos[OP] and DOZER505 like this.
