The All New BAMF X-100 Modular Trailer Platform
Discussion in 'Bay Area Metal Fabrication' started by jlee, Oct 29, 2019.
  1. Oct 29, 2019 at 9:02 AM
    jlee
    jlee [OP] New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    This has been a pet project of mine ever since making my first Expo Trailer in 2014. I wanted to design/manufacturer a trailer that you could build or change over time, without the need to take it to a shop to have done or cut and weld on it.
    Hundreds of hours in CAD The completely modular design of the all new X-100 trailer chassis. Allows for these trailers too be changed or modified with simple nuts and bolts. The trailer can be ordered as a base model and upgraded over time. They will be offered as a bolt together kit you can build in your garage or fully a built out unit ready to roll. You could also order a chassis alone and build your own box. The best part about it they can be pallet ship-able as a DIY bolt together kit.
    Accepting 25% deposits for pre production orders, Production starts in November 2019 contact Jerry@bayareametalfab.com for details.
    The introductory Price on a DIY bolt together kit (no wheels and tires) is $8250.00 with FREE shipping to a business address and $8500.00 dropped in your driveway! to anywhere in the lower 48 And $8900.00 for a fully assembled trailer pickup only on assembled trailers.
    Trailer specs
    Dimensions:
    Chassis tongue to tail 135.5", Width fender/fender 76.5"
    Box dimensions:
    L75"xW48.5"xH33.5" 70.49cft
    Weight:
    Starting under 1000lbs
    Construction:
    Chassis,
    is one single sheet of 11 gauge A36 HRPO Laser cut and formed. Gusseted with .250" A36 HRPO X braces with relief holes for weight reduction. Fenders are 11 gauge A36 HRPO.
    Box, is constructed from 6 laser cut and formed .125" thick 5052 marine grade aluminium panels that bolt together for easy assembly and modifications. The doors are .125" 5052 as well with Steel corner gussets and hinges and slide on oil embedded thrust washers. Locking Southco latches are standard on all doors.
    Suspension:
    Timbren axle-less suspension is standard with 2000lb spindles or the option of 3500lb spindles for the heavy builds.
    NOTE:
    The DIY kit is a full complete finished kit without wheels and tires. All parts are included and are completely finished and powder coated with the extreamly durable and field repairable Poly armor thermoplastic powder coating. No welding or painting is needed to assemble the trailer.
    _DSC2949.jpg _DSC2930.jpg _DSC2928.jpg _DSC2916.jpg _DSC2918.jpg _DSC2919.jpg _DSC2922.jpg _DSC2919.jpg _DSC2927.jpg _DSC2903.jpg _DSC2935.jpg _DSC2936.jpg _DSC2899.jpg _DSC2902.jpg _DSC2937.jpg _DSC2938.jpg _DSC2905.jpg _DSC2950.jpg _DSC2933.jpg _DSC2932.jpg _DSC2790.jpg _DSC2445.jpg
    Voyagermike, Pinay, andy9743 and 4 others like this.
  2. Oct 30, 2019 at 7:59 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    We also will be offering financing on the trailers for those that don't want to drop all that cash at once. I'll have more info on that in the next few days.
    Voyagermike likes this.
