stock wheels with a BDS 7" lift ????
Discussion in 'Suspension' started by Bkbuilders, Jan 10, 2017.
  1. Jan 13, 2017 at 3:51 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    I'm liking the wheels. Tires don't look bad either. Can't wait to see it finished.
  2. Jan 13, 2017 at 6:42 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
  3. Jan 14, 2017 at 12:03 PM
    Bkbuilders
    Bkbuilders [OP] New Member
    Scott
    2017 trd pro
  4. Jan 14, 2017 at 12:07 PM
    Bkbuilders
    Scott
    2017 trd pro
    Truck looks great. The back still needs to go up 2 inches the BDS 7 inch is made to level a tundra but not sure about other tundra but the TRD PRO starts level so now back is lower than front by 1.5. I sure can't have that so back needs to go up. Going to check with BDS to see if they knew. Site says it should end up level. Bed cover and whether Tech mats too
    geno0506 likes this.
  5. Jan 14, 2017 at 12:09 PM
    Bkbuilders
    Scott
    2017 trd pro
    Shocks from truck are for sale $1,900 shipped to your door or $1,800 if local pick up southwest Michigan
  6. Jan 14, 2017 at 12:25 PM
    Zharris
    Zharris Merica!
    Truck looks great man. It'll look better once the back is picked up. I'd rather have a little lean to the front than the back. But looks awesome.
  7. Jan 14, 2017 at 12:41 PM
    Bkbuilders
    Scott
    2017 trd pro
    Yes. I like back higher too. But at least even.
  8. Jan 14, 2017 at 12:43 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    :drool::drool::drool:
  9. Jun 20, 2017 at 12:34 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Stock won't work cause they lower something or drop cm? Is that right ?
  10. Jun 20, 2017 at 3:03 AM
    Bkbuilders
    Scott
    2017 trd pro
    The angles change when you raise it and the stock wheels don't have enough off set and the back of the wheel and tire rub
    Jsena likes this.
  11. Apr 11, 2022 at 11:30 AM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    Why do the stock wheels not work?
