Can I have 2 switches power 1 lightbar?
Discussion in 'Lighting' started by Huvster, Mar 15, 2020.
  1. Mar 15, 2020 at 5:48 PM
    Huvster
    Huvster [OP] New Member
    Jt
    2002 4x4 6cyl manual
    I'm looking to have my rear light bar turn on when I put truck in reverse. ( I have a trigger wire already from backup camera) AND have a seperate switch in cab to turn on the same light bar. Is that possible?
  2. Mar 15, 2020 at 6:02 PM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    Yes use a relay
    BrandonL812 and Shark Bait like this.
  3. Mar 15, 2020 at 6:04 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Like this
  4. Mar 15, 2020 at 6:05 PM
    Huvster
    Jt
    Wouldn't that way have the bar always on?
  5. Mar 15, 2020 at 6:08 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Nope out is the light and the inis power from the reverse circuit and power from the separate switch
  6. Mar 15, 2020 at 6:12 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
  7. Mar 15, 2020 at 6:13 PM
    Huvster
    Jt
    Ok thanks ill give it a shot
