Tailgate won't unlock using remote
Discussion in '2.5 Gen Tundras (2014-2021)' started by Skotto, Apr 11, 2019.
  1. Apr 11, 2019 at 11:16 AM
    Skotto
    Skotto [OP] New Member
    Scott
    2017 Tundra SR5
    Hey all! New to the community and came across this issue yesterday. Has anyone else had problems with their tailgate lock?
    Ps1stoy18 likes this.
  2. Apr 11, 2019 at 11:18 AM
    finn
    finn New Member
    It’s not wired to the remote. Unless you’ve added a aftermarket part.
  3. Apr 11, 2019 at 11:25 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    This
    Medic343 and GODZILLA like this.
  4. Apr 11, 2019 at 11:38 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    So on my 2018 I’ve noticed with cold weather my tailgate won’t unlock with the clicker... I hear it moving but it’s like it’s jammed. And I’m not talking negative temps I am in Dallas
  5. Apr 11, 2019 at 11:40 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Do you have an aftermarket pop and lock installed? Either way, I’d take the back of the tailgate off and inspect the locking mechanism.
  6. Apr 11, 2019 at 11:41 AM
    Skotto
    Scott
    2017 Tundra SR5
    I should have mentioned that this was working in the past and unsure of what has changed. I can hear the tailgate trying to unlock, but, unfortunately I've had to use the key to open it.
  7. Apr 11, 2019 at 11:47 AM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Factory no aftermarket
  8. Apr 11, 2019 at 11:49 AM
    Omohundro
    Jody
    McMinnville TN
    I didn’t know Toyota offered this. I have an 18 Platinum and had to add myself.
  9. Apr 11, 2019 at 11:50 AM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    My friend and I both have ‘18 SR5 with factory remote lock/unlock tailgate. Hell his even came with bed lights
  10. Apr 11, 2019 at 11:53 AM
    Omohundro
    Jody
    McMinnville TN
    I don’t want to speak out of turn, but I’m pretty sure you have a dealer installed Pop-Lock.
    I am currently looking in the this.
    GODZILLA likes this.
  11. Apr 11, 2019 at 11:55 AM
    Jrharvey02
    Jrharvey02 New Member
    You’re correct, dealership add-on. Won’t stop them from claiming “factory”.
    GODZILLA and Tundyfundy like this.
  12. Apr 11, 2019 at 11:59 AM
    KnuckleHD
    Toyota does not make one. They are typically installed at port as part of a package. Regardless, Toyota or aftermarket, they are all the same thing. Just an actuator moving up and down to lock and unlock. If your tailgate unlocks Via the key then the locking mechanism is working fine and it’s likely the actuator that broke. Pretty common unfortunately.
    15whtrd likes this.
  13. Apr 11, 2019 at 11:59 AM
    Omohundro
    Jody
    McMinnville TN
    So the next question is what did this option cost you?
  14. Apr 11, 2019 at 12:00 PM
    KnuckleHD
    Hopefully it’s just the set screen that came lose but more often than not, the actuator arm breaks. So it will make the sound but the arm doesn’t move up/down as it should.
    Jrharvey02 likes this.
  15. Apr 11, 2019 at 12:01 PM
    Jrharvey02
    At least the hard part of wiring the pop-n-lock is done, replace for $90 and consider yourself lucky you didn’t spend an hour under your truck fishing wire like the rest of us...
  16. Apr 11, 2019 at 12:02 PM
    Omohundro
    Jody
    McMinnville TN
    If it came from the dealer, go back.
  17. Apr 11, 2019 at 12:16 PM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Not sure what it cost I didn’t even know it came with it. Mine is weird though only time it acts up is cold temps like 20’s and 30’s
  18. Apr 11, 2019 at 1:43 PM
    Razorwyre
    Razorwyre New Member
    In Texas the distributer is Gulf States Toyota. They offer a locking tailgate, bedlights etc. that are "Distributer Installed" items. You can configure them right on the Toyota.com website.
    Jrharvey02[QUOTED] likes this.
  19. Apr 11, 2019 at 1:55 PM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Did not know that, interesting!
  20. Apr 11, 2019 at 1:58 PM
    KnuckleHD
    But it’s still not made by Toyota... just rebranded aftermarket parts.
  21. Apr 11, 2019 at 2:03 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The power tail gate lock is a Toyota accessory, but not as cheap ($289) as adding a Pop N' Lock.
  22. Apr 11, 2019 at 2:08 PM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    This is the part you'll need most likely. $17 from Amazon. Should take you 15 minutes to fix and be a direct replacement. 30 minutes if you've never even seen a screw driver. I know the Pop-A-Lock version is about $90 (and even has Toyota part number 00016-34092 at some places for $150+), but this is THE actuator that is used. I've got a South East TSS 2019 and am adding two more of these actuators to my tailgate so that it will open on the third press of the key fob's unlock. There are 8 T-27 (or T-30) screws on the access panel on your tailgate, two or three sheet metal screws on the actuator.
    https://www.amazon.com/gp/product/B0009SWLE6/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
    Here's a link to the Toyota instructions for the OP's 2017 Tundra: http://toyotaparts.sparkstoyota.com/install/00016-34092inst-2017Tundra.pdf
    Link to Spark's Part that has links to instructions for other years: https://www.sparksparts.com/accessories-and-aftermarket-parts-tailgate-power-lock-00016-34092
    panicman and Skotto[OP] like this.
  23. Apr 11, 2019 at 2:11 PM
    15whtrd
    15whtrd Mr. Blonde
    I have an aftermarket pop and lock installed. Mine worked great initially but then slowly stopped locking the gate every time. I took everything back apart. The actuator is only mounted by one screw if I’m recalling correctly. There is a locating tab that rests against The handle assembly. If you have the locating tab all the way against the handle assembly it tends to throw the linkage just out of reach of completely locking the gate.
    What you need to look for is that the actuator is straight up and down not kicked either direction. I remedied this with some aluminum dryer duct tape LOL. I wrapped it around the locating tab to shim it in the perfect position. No amount of lube or anything worked until I figured this out.
    Just take off the access panel on the inside of the tailgate. You’ll see the actuator and how it all works. Hit your remote and watch the actuator do it’s thing. Now index it slightly and see if it works better.
    gkelm, Tundyfundy, panicman and 2 others like this.
  24. Jun 9, 2020 at 3:36 PM
    heidson
    heidson New Member
    2017 White Tundra Limited 4x4
    Bilstein 5100's all around
    Cannot seem to get mine to unlock. Came with the truck purchased used. It tries but just doesn’t have the force to unlock it. Locks fine though.
  25. Jun 9, 2020 at 7:29 PM
    Kanobi13
    Kanobi13 New Member
    Mine never works always have to use key
  26. Jun 10, 2020 at 7:16 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I'd just replace the actuator with a new one from Amazon. In the picture at the Amazon link, the little brass-colored piece of metal is a bendable/ adjustable mount that will allow you to adjust the angle of the push/ pull motion of the actuator to the tailgate locking mechanism. I've installed this particular actuator on two Tundras for the tailgate lock (my current Tundra came with the Pop-n-Lock dealer installed) but if I recall correctly, I mounted it horizontally, but I could have the lock and the automatic tailgate opener installs backward in my head though. I know i remember having to adjust the angle between the actuator and the lock mechanism though. See step 12 in the first post in this thread regarding the adjustments- https://www.tundras.com/threads/diy-pop-and-lock-for-a-fraction-of-the-cost.28693/
    The actuator is $12 at Amazon- https://www.amazon.com/Install-Esse...5&sr=1-1-70f7c15d-07d8-466a-b325-4be35d7258cc
    gkelm likes this.
  27. Oct 23, 2021 at 5:03 PM
    meatballs
    meatballs New Member
    reviving this thread. pop and lock 4 years old,motor too weak to lock or unlock .cleaned ,lubed,tried all kinds of adjustments and still no worky. kept getting worse over time. first issues appeared a few weeks after install. disappointed in the quality of this product.
    do not buy from them,buy the oem toyota instead.
