Extra long socket for factory skid plate removal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodm1, Jul 10, 2020.
  1. Jul 10, 2020 at 7:14 PM
    rodm1
    rodm1 [OP] New Member
    Every time I change the oil I seem to lose the socket inside the skid plate. What are you guy's doing to prevent this? I'm thinking of getting a socket that is extra long or a locking extension.
  2. Jul 10, 2020 at 7:54 PM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    I usually use electrical tape on my socket and extension. But I'm also really cheap.
  3. Jul 10, 2020 at 8:21 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I use a longer socket. Haven’t had a problem.
  4. Jul 12, 2020 at 8:50 AM
    Cheesy1
    Cheesy1 New Member
    2020 CrewMax TSS
    I just use a standard 3/8 drive socket in a 1/4” impact driver holder from Harbor Freight. Never had the socket pop off, but Toyota’s stupid standoff and sheet metal bolt retainer is a pain to me.
    Separate gripe, What’s it take, 4 sockets to change oil? 1 for the front screws (or a philips bit), 1 for the front bolts. 1 for the back bolts. 1 for the drain plug (or a box end wrench). Couldn’t have used fasteners with the same size head could they?
    Haggis777, DWS, tstieb and 1 other person like this.
  5. Jul 12, 2020 at 9:33 AM
    timsp8
    NY
    I use a deep well socket and small extension. My issue is more with all the dirt that falls on my face.
  6. Jul 12, 2020 at 4:41 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I wish they wouldn't call it a skid plate. It's more like a dust shield. When I ordered my 2017 DC new, the dealer was raving about how it even has beefy skid plates. Three days later when I went to pick it, I looked underneath at the "skid plate" and was PISSED. Wanted to say something but was trying to stay in a good mood since I was getting a brand new truck. Still to this day, that is a thorn in my side. Wouldn't have been bad if he wouldn't have gone on and on about the "skid plates."
  7. Jul 13, 2020 at 2:08 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    Just leave it off.
  8. Jul 13, 2020 at 5:39 AM
    Bammer
    Monroe, CT
    10mm for the front 3, 12 mm for the 5 skid plate bolts and a 14 mm for the drain plug. Oil change takes 10 minutes, skid plate takes 30 !
  9. Jul 13, 2020 at 5:58 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I suck it out using a pump.
    Best 100.00 I ever spent
    CaptainGrumpus likes this.
  10. Jul 13, 2020 at 6:05 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  11. Jul 13, 2020 at 6:32 AM
    timsp8
    NY
  12. Jul 13, 2020 at 6:39 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
  13. Jul 13, 2020 at 6:42 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I really need to do this to mine
  14. Jul 13, 2020 at 6:53 AM
    CaptainGrumpus
    Maine
    What pump are you using? You would still have to remove the skid to change the filter unless you have an aftermarket skid plate.
  15. Jul 13, 2020 at 6:54 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I believe the stock Non-TRD plate is refered to as a "Splash Plate" by Toyota.
  16. Jul 13, 2020 at 7:15 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I have the Mityvac 7201 pump
    https://www.amazon.com/Mityvac-Fluid-Evacuator-Plus-MTY-7201/dp/B007QV0966
    My skid has a door on it that was stock to remove the filter though.
    Wasnt sure if it was stock on all trucks but I have a 2019 Pro.
    Allen wrench and the pump in about 10 minutes.
    Pump the old oil into the jugs I bought the new oil and done.
  17. Jul 13, 2020 at 8:20 AM
    CaptainGrumpus
    Maine
    Wow. That is quite tempting. Mess free changes. Could use it on the snowblower as well. Added to cart :thumbsup:
  18. Jul 13, 2020 at 8:40 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Just be careful pumping it into the 5 gallon jugs.
    When it empties the air comes out and its like a porn video with it spraying all over.
    My first oil change it looked like I ran under the chocolate fountain at Golden Corral .
    I started pumping it with the hose in the 5 gallon jug and it was filling up pretty fast. I kept pumping.
    Well it holds the air like a compressor
    Once the oil is out air then comes out.
    The hose lifted up out of the jug and trying to catch that damn hose was a site.
    My wife said from a distance it looked like I was swatting at a bee.
    Then I walked in the house.
    It is funny now, my wife still laughs like hell about it with tears in her eyes.
  19. Jul 13, 2020 at 9:31 AM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    I generally just use a standard length socket and 1 extension. It is just long enough to get the skid plate bolts installed and tightened up!
  20. Jul 13, 2020 at 10:15 AM
    DWS
    DWS New Member
    2015 BadAzz-Brown Tundra CrewMax
    Thanks for starting this conversation back up, OP. Lots of fresh ideas. I wish the oil filter replacement as easy as my 06 4runner 4.0.
  21. Jul 13, 2020 at 10:17 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Locking socket extension. Get a set from harbor freight; they’re like ten bucks
    FlyingWolfe likes this.
  22. Jul 13, 2020 at 10:25 AM
    Very nice Sean. Great idea.:thumbsup:
    Pudge[QUOTED] likes this.
  23. Jul 13, 2020 at 3:05 PM
    kevine0001
    kevine0001 New Member
    Kevin
    effing genious
  24. Jul 13, 2020 at 3:49 PM
    glowblue
    glowblue From time to time
    VA
    Two words:
    Fumoto valve
    RCI skid plate
    (Well, more than two words...):rofl:
    :thumbsup:
  25. Jul 13, 2020 at 4:29 PM
    Jubei99
    Jubei99 New Member
    Phoenix, AZ
    2017 MGM Tundra TRD Crew Cab
    With the improvised door cut out. Have the filter in and out with in minutes. Ensure to use door weather strip to prevent cutting your arm.20200630_111911.jpg 20200630_111915.jpg
  26. Jul 13, 2020 at 8:24 PM
    Pudge
    CT
    After I cut the hole I figured I'd leave a signature for someone down the line. Good old fashioned 69 etched in there for the next owner or oil tech. Yes I'm immature and bored.
  27. Jul 13, 2020 at 8:49 PM
    :rofl::rofl:
  28. Jul 18, 2020 at 4:28 AM
    rodm1
    The window is a good quick oil change but you wont be able to inspect the rest of the under body. I had a bad water pump with slow leak and would never have seen it if I had the window but I did add a small amount of coolant sow maybe that way. The same for high mileage oil changes less time under the hood.
  29. Jul 18, 2020 at 4:35 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Tiny hands for the win!.. at least i’m good for something. :rofl:
    But I take the few dozen minutes and just drop the plate so I can inspect the underfluffies.
