Amsoil In Tundra Transmission ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, Jun 13, 2020.
  1. Jun 13, 2020 at 8:45 PM
    brandostundra
    brandostundra [OP] New Member
    I have religiously run Amsoil fluids in every vehicle I have owned,
    engine oil , transmission and differential because its the best and have had outstanding results
    I am About to change out all the fluids in my 2016 Tundra and do the Amsoil switch over.
    My local transmission guy (who also loves Amsoil products) said that the Tundra transmission is actually best off with the stock Toyota WS oil. He said they work better with the stock WS fluid. I am trying to get more information from him and others.
    Anyone running Amsoil in their Tundra Transmission have any issues, or heard anything similar?
    thanks
  2. Jun 13, 2020 at 9:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No issues. Amsoil is pretty fastidious about their stuff, they wouldn't recommend their product if they didn't feel it was up to manufacturer standards. For example, they don't offer a transfer case oil for the 3rd Generation Tundras, 2015 and newer.....
    14burrito likes this.
  3. Jun 13, 2020 at 10:38 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    I have Amsoil every where except the transfer case in my 16 and no issues.
    16 blue crewmax likes this.
  4. Jun 14, 2020 at 2:05 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Toyota WS is a semi synthetic made by Exxon Mobil . It's nothing special ,
    I switched my 2019 over to Amsoil signature series and noticed an improvment in shift quality . I have always loved Amsoil ATF and gear oils
    rapide likes this.
  5. Jun 14, 2020 at 2:59 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I've been using Amsoil in everything I own with an engine since 1990, including my 2010 Tundra's engine,trans, diffs and transfer case(83,000 miles, no work,only maintenance). Our 04 Pilot has 358,000 issue-free miles on it; Amsoil since new.
    gavia and jordoncloutier like this.
  6. Jun 14, 2020 at 3:05 PM
    Ericsopa
    Ericsopa Old man and the sea
  7. Jul 23, 2020 at 10:58 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
  8. Jul 23, 2020 at 11:04 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The transfer cases in the 2008s and the 2020s are different and require different fluids from each other.
  9. Jul 23, 2020 at 11:12 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    :monocle:
  10. Jul 23, 2020 at 12:47 PM
    jordoncloutier
    Jordon
    Alberta , Canada
    That " transmission guy" seems like its just his opinion about ws fluid being better
    Where as there is actual information online proving the fact that toyota ws is a semi synthetic made by mobil for toyota .
    Its common knowledge that a full synthetic fluid will protect better and last longer than a semi-synthetic fluid.
  11. Jul 23, 2020 at 2:35 PM
    CMB
    CMB New Member
    Cecil County MD.
    I've always believed Semi- Synthetic oil is produced by sitting a quart of full synthetic in the warehouse with regular oil!:D
  12. Jul 23, 2020 at 3:33 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Where it concerns kinematic viscosity shift over unit time I would tend to agree.
    Where I disagree is contact wear and oxidation resistance because those are attributes of the additive package. And I cant find those values for WS, from the manufacturer, on the interwebs.
    Besides... there's no oxygen to be had in that system. It's all nitrogen after a few miles.
    Trooper2 likes this.
  13. Jul 23, 2020 at 3:39 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    As long as it's the proper viscosity and has the appropriate approvals, I have never heard of an engine, transmission or diff failing because of brand of fluid.
    Run Amsoil, Mobil1, Shell, Walmart or whatever.
    Hoff likes this.
  14. Jul 23, 2020 at 4:35 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    @duerrs
    14+ transfer cases are electromagnetic units from Borg Warner. They use a 75w fluid.
  15. Jul 23, 2020 at 5:31 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I just bought 4 gallons to change out my transmission with. I'm currently at 36k and have seen many good reports.
    For what it's worth I have also been a dealer for the past 10-11 years. Have been using the stuff in everything since I could drive. I haven't had any issues yet. Like the previous dealer I'm not much of a sales person. I bought the dealership to get things at cost and extend that to family and friends. If anyone is interested at getting it at cost let me know.
  16. Jul 23, 2020 at 6:46 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Been runnin’ it for about 30k in my trans. No better, no worse than the WS it replaced as far as I can tell.
    jordoncloutier and YardBird like this.
  17. Jul 23, 2020 at 7:13 PM
    jordoncloutier
    Jordon
    Alberta , Canada
    Same here . Changing fluid to amsoil don't expect magic to happen . The benefits are strictly that it withstands heat far greater than any other fluid on the market and intern will extend the service interval as well .
    To anyone who changes any oil over to amsoil and claims it runs smoother of feels better is just experiencing the placebo effect imo.
    Larly5000[QUOTED] likes this.
  18. Jul 23, 2020 at 7:32 PM
    Larly5000
    NV
    07 Crewmax
    Zachly. Have no doubt drop for drop its a superior fluid to most of the junk out there.
    But even that stuff is capable of functioning in a drama free environment(daily driving).
    Long term, towing and the fact its bottled and blended in the states is worth the extra couple bucks to me.
    :oldglory:
  19. Jul 23, 2020 at 7:45 PM
    jordoncloutier
    Jordon
    Alberta , Canada
    Hell Im Canadian and I like the fact that it's made in the USA
  20. Jul 23, 2020 at 7:57 PM
    Larly5000
    NV
    07 Crewmax
    :thumbsup: Didn’t catch that...wasn’t flyin’ old glory at ya! I’ve enjoyed my time on that side of the border
  21. Jul 23, 2020 at 8:00 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    its probably the fresh fluid effect... if they changed it to fresh WS it would do the same thing
    BSW9 and jordoncloutier[QUOTED] like this.
  22. Aug 19, 2020 at 7:46 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Those with an 18+ tundra, how did you swap your fluid?
  23. Aug 19, 2020 at 7:54 PM
    ninjajay
    Spoolston, TX
    No different process than the 07-17
  24. Aug 20, 2020 at 3:20 AM
    Bammer
    Monroe, CT
    EXACTLY !
  25. Aug 20, 2020 at 5:25 AM
    duerrs
    duerrs Semper Fi!
    According to the two dealers I've talked to, it is different. They do not do a complete flush (12 quarts), only pan drain and fill (4.5 quarts). This is likely due to not having transmission cooler lines and being able to hook up to their "flush" machine. I'll be draining the 4.5 quarts and adding Amsoil beginning soon. I'll likely change 3-4 times every 10,000 miles or so. After that, I'm not going to worry about it for at least 100,000 miles.
  26. Aug 20, 2020 at 8:18 AM
    ninjajay
    Spoolston, TX
    I thought that was 19+? Does yours not have the transmission cooler?
  27. Aug 20, 2020 at 8:36 AM
    duerrs
    duerrs Semper Fi!
    Sorry....I believe you're correct. No transmission cooler on the 19's +. I have a 2020 and no, I do not have a cooler.
    Thanks!
  28. Aug 20, 2020 at 9:05 AM
    ninjajay
    Spoolston, TX
    ahhh yeah... I would imagine there’s still an “unofficial” way to get more of it out, maybe with a mytivac?
  29. Aug 20, 2020 at 9:10 AM
    duerrs
    duerrs Semper Fi!
    That's what I'm hoping for as well.
    Thanks!
