Spectre Performance Air Intake?
Discussion in 'Performance and Tuning' started by shayned97, Aug 3, 2020.
  1. Aug 3, 2020 at 11:59 AM
    shayned97
    shayned97 [OP] New Member
    Shayne
    2016 Blazin Blue Tundra TRD Offroad
  2. Aug 3, 2020 at 1:18 PM
    Tisoy281
    Tisoy281 New Member
    I wouldn't expect much out of it except more engine noise.
    Black Wolf likes this.
  3. Aug 3, 2020 at 1:47 PM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Had one on my old Chevy 1500.. Did what I expected, made some noise an looked cool..
    Black Wolf and shayned97[OP] like this.
  4. Aug 3, 2020 at 1:53 PM
    Tundra 2019 tss
    Tundra 2019 tss New Member
    Jerry
    2019 tundra TSS
    I have the KnN version and I get about 2 to 3 mpg more out of it but it also gives a nice throaty sound to it it feels like it might give more horse power but it is hard to tell. i am use to it because I had one on my last Tundra and it seemed to do pretty good.
  5. Aug 3, 2020 at 2:04 PM
    shayned97
    Shayne
    That's most of my expectations. We all know more mpg would be wonderful though haha
  6. Aug 3, 2020 at 3:14 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Dont forgot to install the sticker. Thats another 0.5hp.
  7. Aug 3, 2020 at 3:43 PM
    You already have a cold air intake. That Spectre is pretty much a hot air intake.
  8. Aug 5, 2020 at 9:50 AM
    shayned97
    Shayne
    So it's installed. I wanted to update the thread, looks good, sounds mean. The engine seems a lot less restricted and overall smoother. We will see as I drive it more though....no gas update yet
  9. Feb 10, 2023 at 5:14 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    So did the truck blow up before you could get a gas update?
    Bringing this back to life, I was looking to see if Spectre had a drop in and saw that they had a whole intake system. Thought I would check out if anyone ever pulled the trigger on one. This is about the only thread I see
  10. Feb 10, 2023 at 6:21 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Spectre is Walmart quality in my mind. The Stock unit is a true CAI. This will make more noise and sound cool, but is pulling in hot air....... Best bet IMNSHO is to go with the TRD or AEM drop in filter for more airflow, and CAI.
    High flow filters do NOT make more power, they just allow the motor to spin to redline faster that feels like more power, better throttle response, etc.
  11. Feb 10, 2023 at 6:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I run the Spectre. I'd rather not. I don't have fender liners which leaves the intake wide open to the elements. A lot of LT trucks run this type of setup instead of OEM because it's considered safer when the liners are removed and you're off roading. It also makes a pre-filter easy to install, and clean on the trail.
  12. Feb 10, 2023 at 7:09 PM
    Better to run with a snorkle in the dust. A lot of folks think snorkels are for mainly deep water crossing. Snorkels are ubiquitous in OzzietraIsa where there aren't many water crossings, only red dust everywhere....
    HulkSmurf14 and 831Tun[QUOTED] like this.
  13. Feb 10, 2023 at 7:15 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Very true, a snorkel would be better but that's an involved, custom job as there's no kit fiberglass fenders. I've toyed with the idea but haven't found the motivation. And, I'm not a huge fan of how they look. :notsure:
    Voda48 and Black Wolf[QUOTED] like this.
  14. Feb 11, 2023 at 6:57 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    I can appreciate the opinion. I've run K&N drop in filters in a few cars and found the Spectre to be similar in quality and an economical choice overall. They don't make an option for my wife's GX460 so I went back to K&N b/c the aFe are backordered.
    I've had all sorts of setups in my GTO before settling on an over the radiator style. The Volant CAI sounded awesome and was enclosed to avoid heat soak, but ultimately the OTR style had the best results with my setup.
  15. Feb 11, 2023 at 7:53 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    So I’ve got an idea that I’ll be doing here soon. Removing the maggy intake box and running this maf sensor pipe into this Afe canister. Then running an inlet 5” to the cowl area similar to Kevin. This should hopefully solve our intake issues with LT and fenders.
    https://performancemrp.com/ag-1781672.1781693.1781925.1782154-2017-toyota-tundra-5-7l-v8.html
    https://afepower.com/afe-power-75-11061-magnum-force-stage-1-pro-guard7-cold-air-intake-system
    Black Wolf and 831Tun[QUOTED] like this.
  16. Feb 11, 2023 at 9:27 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Nice HOT air intake :monocle:
    Saltyhero13 likes this.
  17. Feb 11, 2023 at 9:30 AM
    GravityGear
    Aurora, CO
    just get an ump and be done.
    831Tun[QUOTED] likes this.
  18. Feb 11, 2023 at 9:33 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    The Afe is the same but larger canister and not aluminum so less heat soak.
  19. Feb 11, 2023 at 9:37 AM
    GravityGear
    Aurora, CO
    ump is already gigantic. I get you have no fender liners, but it's still not a tube front half.
    831Tun and reywcms[QUOTED] like this.
  20. Feb 11, 2023 at 11:26 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    This is the real solution. Just expensive. Cheaper than a new motor though
