TPMS on full size spare?
Discussion in 'Wheels & Tires' started by UTAHRTK, Sep 12, 2020.
  1. Sep 12, 2020 at 7:21 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    Does anybody know what TPMS I should procure for my spare Method 701/ 295/70r17?
    Should I even get the TPMS for the spare? Thanks
  2. Sep 12, 2020 at 7:23 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Can a 5th sensor even be configured to work? I know Toyota supports it on some models but Tundras only have 4 sensors stock.
  3. Sep 12, 2020 at 7:32 AM
    GODZILLA Introverted Troglodyte
    Wyoming
    2024 Ferd F150 XLT, 2019 Super Tenere
    Trying not to mod it
    Yes. Tundras have 10 "slots" for sensors in their memory. You can have two full sets register to the truck, and it will only read the rolling sensors.
  4. Sep 12, 2020 at 7:33 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I am not certain on prior years. However, on my ‘19 (18+ years) yes, a fifth sensor can “ride inside the spare”. I was informed by the stealership that my rig “was smart enough” to only register/read the signals of the “rolling” tires... I have now done three 5-tire rotations and absolutely no issues.
  5. Sep 12, 2020 at 7:35 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Dang it!
    I must type super slow...
    You got me again Adam :goingcrazy:
  6. Sep 12, 2020 at 7:36 AM
    Wyoming
    I may type faster, but I was just paraphrasing info that you have provided (more than once) on the forum.
    ElNopal[QUOTED] likes this.
  7. Sep 12, 2020 at 7:37 AM
    Wyoming
    I know that there are different angles for the sensors, but I don't know what one you need for those wheels. I'd reach out to Method to see what they recommend.
    P-Factor and Black Wolf like this.
  8. Sep 12, 2020 at 7:50 AM
    UTAHRTK
    SOCAL
    Thanks!
  9. Sep 12, 2020 at 7:51 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Typically OEM alloy wheels AND aftermarket wheels will use a 20° angled sensor.
    OEM steel wheels will have 40° angled sensors.
    While some have used 40° sensors inverted in an alloy or aftermarket wheel, it is not recommended.
    I thought I had the part number for your sensor year... still trying to find it.
    AggiePhil likes this.
  10. Sep 12, 2020 at 3:03 PM
    UTAHRTK
    SOCAL
    I grabbed this off of TundraTalk - from DT: "The only time the Tundra O.E. sensors do not work with aftermarket aluminum wheels is when the sensors come out of the factory steel wheels (different valve angles)". I may get an OE sensor and have some place program it- or I may just say screw it and not worry about sensor in spare.
    Thanks for searching part #.
  11. Sep 14, 2020 at 2:44 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    okay, I have finally dig through some more of my notes...
    This is OEM one I remember a friend mentioning he ended up getting for his 2017.
    42607-0C070
    Best of luck!
  12. Sep 14, 2020 at 4:14 PM
    UTAHRTK
    SOCAL
    Cool Thanks.
    ElNopal likes this.
  13. Sep 16, 2020 at 4:36 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Just ordered one for my spare...thanks for the reminder.
  14. Sep 17, 2020 at 5:22 AM
    UTAHRTK
    SOCAL
    I went ahead and did not have TPMS installed on spare. Matching spare in stock location and it feels good to know its there.
  15. Sep 17, 2020 at 7:45 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    what version of Techstream are you using? I just setup my buddies 2018 and it only has 5 slots. I would like to set mine up with 10 due to snow tires.
  16. Sep 17, 2020 at 11:05 PM
    Wyoming
    I'm not using it at all. I may have been misinformed, but I believe it was in a thread here that it was stated 2019+ trucks had 10 slots for sensors.
  17. Sep 18, 2020 at 7:05 AM
    Caveman
    Caveman New Member
    Wait a minute, i do a five tire rotation and have to bring my truck in every time to have it reprogrammed. My tire shop uses just a small hand held device that plugs into the obd2 then walks around the tires.
    Where can i go or what program can i get to do this. Would save me time off time waiting in line at the tire shop.
    I like this idea
    ElNopal likes this.
  18. Sep 18, 2020 at 8:54 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    @pickeledpigsfeet, @AzureNightmare, Adam, was just relaying what I had mentioned previously in another TPMS thread...
    I was told by the stealership in January of this year that up to "ten slots" for sensors for my '19 Tundra are possible. I have not confirmed this as of yet because I am just getting my winter "set-up" figured out. However, what I can confirm IS that I have done 3 five-tire rotations thus far WITHOUT incident. The truck has done exactly what the tech at the stealership said it would do for the rotations side of things...
  19. Sep 18, 2020 at 9:29 AM
    Wyoming
    You shouldn't have to do anything. Just rotate and drive. Worst case you do the registering/programming that I THINK is in the manual.
    Can't remember which is for sensors and which is for pressure, but you either hold the button under your dash for 3 seconds, or you press it three times. Then drive above X speed and learns the ones that are spinning. My brain is mush right now, so definitely read up on the owner's manual.
    ElNopal likes this.
  20. Sep 18, 2020 at 9:44 AM
    Caveman
    Caveman New Member
    If i can get it to memorize the five, i would save a couple hours of waiting in line at the tire shop. Thank you this is great.
    ElNopal likes this.
  21. Sep 22, 2020 at 3:42 PM
    UTAHRTK
    SOCAL
    Just heard back from Method- they stated the torque is 85 -95 foot lbs with a minimum of 7.5 turns. This is for 17" methods on 3rd gen ( 14 x 1.5 et lugs). I will back them off 5 foot lbs from the current 100 ft -lbs they are torques at; not sure how much that matters but I damn sure don't want those lugs breaking. BTW- you dudes quasi hi-jacked this thread. Bahahahaha.
  22. Sep 6, 2023 at 10:27 AM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Tundra Limited 4x4 CM QS / 2000 Tundra Limited 4x2 AC Black
    Does it matter if the TPMS sensor is OEM for the spare? Was going to have Americas Tire put one of their TPMS in the spare. Does it matter if only the spare sensor is not OEM?
