TRD Pro Skid plate not fitting??!?!?!??!
Discussion in '2.5 Gen Tundras (2014-2021)' started by jstyle, Nov 5, 2020.
  1. Nov 5, 2020 at 3:51 PM
    jstyle
    jstyle [OP] New Member
    Josh
    2016 Magnetic Gray Offroad CrewMax
    So I’ve been on my back for the last hour trying to figure out a way to make the skid plate fit and it’s not even close. I can get all of the hole lined up, I can even get the bolts started. But every time I start tightening down the skid plate hits this (see attached) before it’s even close to tight. What am I doing wrong?
    I have a 2016 TRD Offroad. I do have Bilstein 6112 up front and 5100 and add a leaf on the back but I can’t imagine that would affect it.
    Any ideas????
  2. Nov 5, 2020 at 3:54 PM
    Do you have the other spacers that go with your diff drop kit?
  3. Nov 5, 2020 at 3:58 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's because you have a lift installed. They don't play well together.
    Zero One Actual likes this.
  4. Nov 5, 2020 at 3:58 PM
    Kelvin
    Kelvin New Member
    Remove the diff drop or go with the ^ above advice from @ColoradoTJ and find the rest of your kit.
    Zero One Actual and Black Wolf like this.
  5. Nov 5, 2020 at 4:03 PM
    Mark73
    Mark73 New Member
    MGM 2020 Tundra TRD PRO
    ReadyLift SST 2” plus 2 Lift Kit, Coach builder +3 shackles & drop kit, Nitto RG 295/70/18
    Call David at Coach Builder and ask him for the spacer kit he sells to give you more separation.He’s a great guys with a lot of knowledge on Tundras.
    Zero One Actual and ItsNickROFL like this.
  6. Nov 5, 2020 at 4:04 PM
    jstyle
    Josh
    I had the local off-road shop do the lift and that’s all the parts I have... other than what I got with the skid plate.
  7. Nov 5, 2020 at 4:05 PM
    The diff drop comes with skid plate spacers. You really don't need the diff drop kit on a 6112 lift.
    mtntop and reneaux like this.
  8. Nov 5, 2020 at 4:11 PM
    jstyle
    Josh
    I think the guy that did my 6112’s only moved it up like an 1.5” not much at all. Can I just back that bolt out I’m pointing to and then remove the spacer and put the bolt back in? It’s it going to do something crazy when I drop that bolt?
  9. Nov 5, 2020 at 4:13 PM
    jstyle
    Josh
    Do I need to support it or... I just don’t want to do something stupid...
  10. Nov 5, 2020 at 4:17 PM
    timsp8
    NY
    Put a jack under it. But I’d almost leave the diff drop kit and order the skid plate spacers.
    Black Wolf and reneaux like this.
  11. Nov 5, 2020 at 4:19 PM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Put a jack under your differential first then loosen it. Just for safety though it shouldn't fall much, if any.
    Remove the diff drop spacer. It is not needed no matter what height your 6112s are at. Then your skid will fit without additional spacers.
    From what I read on here, diff drop spacers can do more harm than good anyways.
  12. Nov 5, 2020 at 4:20 PM
    jstyle
    Josh
    Thanks. You guys are AWESOME!
  13. Nov 5, 2020 at 4:22 PM
    jstyle
    Josh
    The other shitty part is that I had the Skidplate shipped to me... and the stuff in the “hardware bag” is missing as well. Frustrating for sure.
  14. Nov 5, 2020 at 4:26 PM
    glowblue
    glowblue From time to time
    VA
    Ive read the same thing. I have a 2.5” 6112 lift and did not put on the diff drop hardware. Some folks say put them on to ease the CV axle angles and extend the CV axle lifespansome say don’t. What are the pros and cons?
  15. Nov 5, 2020 at 5:02 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I dont think that it helps with the CV axle angle but more to do with keeping the front driveshaft U joint angles equal on the front and back.
  16. Nov 5, 2020 at 5:12 PM
    Blueknights75
    Ron
    Clayton, NC
    PROs do not have a diff drop kit which made me feel comfortable in not installing a diff drop when I installed my leveling shocks.
    GELCW and reneaux like this.
  17. Nov 6, 2020 at 11:35 AM
    reneaux
    2017 SR5 CM 4x4
    I read that since it only adds the spacer to one side, it causes your differential to tilt, which then displaces more oil to one side and away from your input shaft bearing(?) which will then cause premature wear.
  18. Nov 6, 2020 at 1:35 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    As the differential ring gear turns oil climbs up the ring gear and onto the pinion gear then makes it's way to the pinion bearings. A tilt to the diff would not effect pinion bearing lubrication.
    Wynnded and reneaux[QUOTED] like this.
  19. Nov 6, 2020 at 2:21 PM
    timsp8
    NY
    Yeah what he said. This is a rear, but same concept. It starts around 3:10.
    https://m.youtube.com/watch?v=9-yG3D3JBRs
  20. Nov 6, 2020 at 2:35 PM
    Diff drop kits always use two spacers.
  21. Nov 7, 2020 at 4:19 AM
    jstyle
    Josh
    Mine certainly has two spacers. I’m gonna remove the spacers this morning and try to put the skid plate on... Again...
    GELCW and Black Wolf[QUOTED] like this.
  22. Nov 7, 2020 at 4:42 AM
    Good luck! It might fit now with the spacers off.
  23. Nov 7, 2020 at 5:31 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Don’t know if you got the issue sorted, but I bought this with my Pro skid to install with my diff drop kit. Worked great.
    Readylift 67-5443 TRD Pro Skid Plate Adapter Kit https://www.amazon.com/dp/B07QCHHWTC/ref=cm_sw_r_cp_api_fabc_OeQPFb98Q5FWW
    Ted4311 likes this.
  24. Nov 8, 2020 at 5:28 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    You have a lift installed. Your whole skid plate will need to be dropped the same amount that you added to the diff drop. I dropped mine and had to get longer bolts and made custom aluminum spacers to put between the skid plate and its bolt mounting points. That will cure your crash condition.
    BlueRibbon4x4 likes this.
  25. Nov 8, 2020 at 5:38 PM
    AZTundra
    Paul
    Phoenix, AZ
    I assume this was resolved by now?
  26. Nov 8, 2020 at 6:34 PM
    jstyle
    Josh
    Holy shit... So here I was thinking I could just swing those bolts loose take the spacers out and put the bolts back in... WRONG.
    I dropped the diff this afternoon and after fucking it for a while I realized the bolt holding the diff up were much long than I could go without the spacer. So after considerable amount of cursing and blood trying to get the nut on top to stay while mounting the bolts back up I had to put the diff back up. OMG what a pain in my ass trying to get that nut to get threads so I could put the diff back up in the right spot, there is like 0.0 room especially on the driver side. Sigh... looks like I need to find the original bolts some where some how.
  27. Nov 8, 2020 at 10:09 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did you not get the bolt back when the lift was installed? When we do the lift at the dealership you get back the lift box with all the stock hardware in case you want to return it to stock.
  28. Nov 9, 2020 at 5:57 AM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    I have pro comp 65225k leveling kit. Do I need any special hardware to place a skid plate on my truck. Just trying to make sure before ordering/installing. TIA
  29. Nov 9, 2020 at 6:17 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    This, my diff drop kit came with skid plate spacers that accommodated the lowered differential.
  30. Nov 9, 2020 at 6:50 AM
    jstyle
    Josh
    To be honest they may have given it to me at some point but I can't find it anywhere.
