2017 SR5 DRL/Front Turn Signal LED Bulbs
Discussion in 'Lighting' started by 1999cutiger, Nov 7, 2020.
  1. Nov 7, 2020 at 6:27 AM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I need to replace the DRL/Front Turn Signal bulbs on my 17 SR5. I ordered an LED pair from Lasfit but they are not compatible with the 17 wiring...I got a hyperflash after 45 minutes of use.
    As I understand it, the 17 wiring is different from the 18 and up models.
    I want to get some amber LED’s asap that are fully compatible.
    Please let me know what you 17 guys are using.
    Thanks in advance for your help.
  2. Nov 7, 2020 at 6:45 AM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    VLEDS is what I have
  3. Nov 7, 2020 at 6:49 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  4. Nov 7, 2020 at 7:03 AM
    AZTundra
    Paul
    Phoenix, AZ
    Vleds vr6 with your choice of led bulb.
    16 blue crewmax likes this.
  5. Nov 7, 2020 at 7:25 AM
    1999cutiger
    Do I need any other adapters or just the VR6 bulbs?
  6. Nov 7, 2020 at 11:44 AM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    I only needed one resistor per side leds front and back; just mounted a resistor behind the tail light assembly, there's a perfect mounting location there.
    or you can run these types of Lasfits, they're insanely bright; have them on both my 4Runners.
    https://www.amazon.com/dp/B07KXKKH9...olid=3P3TVC0MIRK83&psc=1&ref_=lv_ov_lig_dp_it
  7. Nov 7, 2020 at 12:26 PM
    1999cutiger
    Those are the Lasfit bulbs I had...they did not work properly. After 45 mins of use, I got a hyperflash. Do they work with the resistor installed? I bought the bulbs with the CK socket...not sure if that is the issue or not.
    They seem to be excellent quality with great output...they just don’t work properly in my truck.
  8. Nov 8, 2020 at 11:18 AM
    Shifless Joe
    Mesa AZ
    2016 TRD Off-Road
    I run a single resistor on each side behind the front headlights on the 4Runners (better mounting location), even with those those style Lasfit's; must be why I haven't had any issues.
  9. Nov 8, 2020 at 11:20 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Check out as my build page. I listed some LED switchbacks that have been working great since I got them. You will have to run resistors, and I did that through my tail lights since it was easier for me
