Compustar/Drone Mobile Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by QKoehler, Nov 11, 2020.
  1. Nov 11, 2020 at 7:07 PM
    QKoehler
    QKoehler [OP] New Member
    Quinn
    19 TRD Sport CM
    Hey,
    Recently bought a 19 CM Sport set up by someone with my brain! Loving the truck! It has the compustar remote start on it and works great, but i want to try the mobile app out. It requires a serial number for the unit which indont have. Anyone know what to do? If im SoL its all good too lol
  2. Nov 12, 2020 at 11:18 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Have you called compuStar and asked for guidance?
    I put a compustar remote starter and alarm in my 2000 tundra. It was still working over 20 years later when I sold the truck. amazing.
  3. Nov 12, 2020 at 12:22 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood Amp Tech12volts JL Tweeters Dasaita G13 Head Unit Fumoto Oil Valve Driver Side Grab Handle
    Try this -
    Open the drivers door
    End of the dash - plastic end cap - Red Circle in pic
    Pop that off
    The control units are normally put in there (Mine Is anyway)
    You might be able to see the serial number on the unit or manipulate it to where you can see it...
    TheBeast likes this.
  4. Nov 12, 2020 at 1:21 PM
    nodak67
    nodak67 New Member
    JR
    decent installers put the drone mobile sticker in the drivers door jamb with the serial number on it. otherwise you will have to find module to get the serial number.
  5. Nov 12, 2020 at 8:27 PM
    QKoehler
    Quinn
    19 TRD Sport CM
    I did contact compustar via email and they got back to me today with similar information as purplenova, great advice thank you. Pretty sure i found it however app says its invalid. In the email i got from Compustar sounds like they may need to release the number for reregistration on their end. So i sent them the code tonight and am gunna hope for some good news tomorrow. Thanks for the help guys!
    edit: spelling
  6. Nov 12, 2020 at 10:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum..
    This module is what you are looking for, not the actual Compustar remote start/alarm.
    Is that what you found?
    https://www.dronemobile.com/products/x1max-lte
    I'll post all this in case someone else finds this thread in a search.
    If by chance you have the older GSM Drone modules, you'll need to purchase one of these LTE modules.
    You can find them on Amazon for $109.
    https://www.amazon.com/DroneMobile-Vehicle-Alarm-System-Black/dp/B081NVB8GG
    I had to replace mine, but I got my stuff in 2015.
    But being you have a 2019, you should have this newer module.
    Here is a link to install and activation if you need it.
    https://help.dronemobile.com/s/article/How-to-Install-Your-Replacement-X1-Module
    As @nodak67 stated, a good installer will put the sticker on the door jamb, like I did.
    Very happy with my Compustar RS/alarm and the Drone app.
    purplenova likes this.
  7. Nov 13, 2020 at 6:09 AM
    purplenova
    Tom
    Ohio
    I guess there is a second module attached to the Compustar unit ?
    I did not know that. Thanks for the info.. :thumbsup:
  8. Nov 13, 2020 at 7:20 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Yes there is the actual Drone mobile module I referenced above.
    It receives and sends the app info to the actual RS/alarm..
    But you were right about the location.
    Mine is directly behind the panel you referred to.
    But I have the remove the lower panel to access it.
