Brighter back up lights
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Apr 18, 2021.
  1. Apr 18, 2021 at 8:27 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Has anyone tried LED back up lights with success?
    I tried the license plate lights, very impressive.
    ant8262 likes this.
  2. Apr 18, 2021 at 9:00 AM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    I changed all my lights to led. Used jdm. I will see if I can find my Amazon order. My windows are dark tinted and the backup lights are bright enough I can see a lot more. Also bright enough to let my backup camera see very well in color at night.
  3. Apr 18, 2021 at 9:53 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I changed every bulb in my Tundra with LEDs.
    I've had good results with Alla Lighting LEDs found on Amazon.
    Also with Sirius LEDs, some can be found on Amazon, some I had to order from the them directly.
    LED Headlight, LED Fog Light, LED Exterior Light, LED Interior Light – SIRIUSLED (siriusledlights.com)
    I used amber LED for the front and red LEDs for the rear.
    evydv5id_2ff78ffdc2a12e6c7570963dd8821c87341ce71d.jpg 389ealpn_93fbf76900714999bd83c041bf1caf921c010db2.jpg
    jsdbgq4y_29059d2f704872a338643e5f1f543c269a053489.jpgf6tu5ctc_e0200cc3999bfdebe151df9d25ef6d97fe3cb3fc.jpg
    I have diodedynamics LEDs for backup lights.
    Paid over $90 for them 5 years ago.
    There are cheaper options available now though..
    bqt7rnq1_b68b067c084fcb8f793bfdf91e4fa2be89d0a05d.jpg qwx6m7ri_490e1f0c8e6aff001eb1618597e53385d2e84db9.jpg
    I would avoid Headlight Revolution.
    EVERY bulb I ever bought from them failed within months.
    The contacts are so thin they break easily from normal vibrations of driving.
    Sure they replaced them, but why have to have a spare set of bulbs for when the HR bulbs fail?
    Don't forget to replace your cargo and third brake light bulbs..:thumbsup:
    ant8262 and BlueRibbon4x4 like this.
  4. Apr 18, 2021 at 10:03 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I switched over to LED backups lights. You can hook up some LED pod lights to your back up's. I bought these (link below). I installed them into my rear bumper but I'm going to wire them on a separate switch so I can turn them on when I want.
    https://www.ebay.com/itm/2X-5-Flush...umper-Reverse-Pods-4-Row-Driving/392569568876
    ant8262 and Darkness like this.
  5. Apr 18, 2021 at 11:51 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    And here I thought I was the only one w issues w my Headlight Revolution LEDs!!
    1lowlife[QUOTED] likes this.
  6. Apr 18, 2021 at 1:00 PM
    Cummins3500
    Logan
    Diode dynamics for all the bulbs and rigid flush mounts sr series for my reverse lights. Definitely makes a camper top way easier to deal with
    assassin10000 likes this.
  7. Apr 18, 2021 at 1:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Apr 19, 2021 at 5:22 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    alb1k, Filthyphil and Tundra2 like this.
  9. Apr 19, 2021 at 8:10 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Are there other sockets to use the other 2 bulbs?
  10. Apr 19, 2021 at 8:49 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
  11. Apr 19, 2021 at 9:53 AM
    tvpierce
    Maine
    No. I thought I’d add them to either my wife’s Prius, or my daughter’s Matrix since they are both in the Toyota family. Oddly, neither one uses the 921 bulb. (?)
    Personally, I like having spares on hand, so it works out for me.
    If you’re really concerned about the cost, there are cheaper versions but I can’t vouch for their luminance level.
  12. Apr 19, 2021 at 7:41 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I put rear light pods in my bumper and they are great. They are made by NiLight (Amazon) and have held up great for almost two years now. I have a light bar up front by them as well and it’s never given me issues.
    I also put in these in for reverse bulbs and in the cargo lights. They advertise 500 lumens but I don’t think they are quite that bright but they are brighter and clearer than the halogen 921’s.
    Aucan 20pcs Super bright LED’s
    https://www.amazon.com/dp/B076V9XXW6/ref=cm_sw_r_cp_apip_bHENuUDLBh4hg
    Just today in my Silverado, I put these in the reverse lights and cargo lights. I feel these are significantly brighter than the others in my tundra. I believe part of it is due to the lens facing out of the bulb to help focus the light.
    JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine https://www.amazon.com/dp/B01GGK6QDW/ref=cm_sw_r_cp_api_glt_fabc_ATQNSS66G0VQQJAHNVT8?_encoding=UTF8
    Glock 40 likes this.
  13. Apr 20, 2021 at 4:59 AM
    bmf4069 Something something Miller Lite
    GODZILLA likes this.
  14. Apr 20, 2021 at 5:18 AM
    Not all but some of these cats used to have 1sties, they come and post in our section because they miss it and wish they still had a 1st
    Tundra2, bmf4069[QUOTED] and BubbaW like this.
  15. Apr 20, 2021 at 5:59 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    GTR Lighting Ultra Series reverse lights are on a different level.
    Tundra2 likes this.
  16. Apr 20, 2021 at 6:24 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What's the CRI of these?
    Tundra2 likes this.
  17. Apr 20, 2021 at 6:57 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Some are very knowledgeable and offer up good info....it’s all good ! To all them turd geners, don’t come up in here throwing your 3rds are better than 1st :boink:
  18. Apr 20, 2021 at 7:10 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    When you wired the auxiliary pods in what direction did you go? Did you run a new switch and wire all the way back or did you tap into something that was already there. I have a custom bumper with light pockets and am looking to add pods for scene lighting for camping and auxiliary backup lighting. Just wondering if there’s a hack. I’m guessing you don’t really want these on every time you backup so then a new wire and switch would be a necessity.
    Cummins3500 likes this.
  19. Apr 20, 2021 at 7:58 AM
    Cummins3500
    Logan
    I tapped into my trailer wire plug for the reverse pods. Keeps me from being tempted to turn em on when somebody tailgates :anonymous:
    Skey44 and Glock 40 like this.
  20. Apr 20, 2021 at 8:03 AM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    I want to know more about putting LED pods in the rear bumper!
    Did you wire them to the reverse lights?
    How did you cut into the bumper?
  21. Apr 20, 2021 at 8:41 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Gen 1, Gen 2, Gen 3, they all have light bulbs..
    And yes, I had a Gen 1 for 10 years, it had light bulbs too..
    Try to help a bother out just to get kicked in the dick..
    Don't be hatin' just because you don't have a 5.7.
    See you around in the rearview mirror...
  22. Apr 20, 2021 at 8:56 AM
    Atlanta, GA
    Off the top of my head I am not sure! I'd have to check back in with you on this one. :)
    onesojourner[QUOTED] likes this.
  23. Apr 20, 2021 at 11:24 AM
    SouthPaw
    2000 Limited 4x4 AC
    I used an Amazon dremel ($20) to cut the bumper and wired them to a separate switch. I wanted the option to run them whenever. They do have a wireless remote that offers strobe/flash and it actually works really well.
    abcinv and Skey44 like this.
  24. Apr 20, 2021 at 12:51 PM
  25. Apr 20, 2021 at 2:07 PM
    jcrob33
    jcrob33 New Member
    JR
    Oh interesting. this might be something I do this summer.
  26. Apr 20, 2021 at 2:23 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, the LEDs in the taillights alone just did not cut it for me. If someone is tailgating me I hit my cargo light which has LEDs. I see no need for a separate switch. If you need to turn them on while not backing up just turn key on, set brake, and put shifter in reverse.
  27. Apr 20, 2021 at 2:25 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    I wired my BD S2 Pro flush mount for both. They come on in reverse or with a switch. I didn't add a diode, so the reverse lights and backup camera come on with the switch also. For the trigger I ran to the reverse light. Yes I have a second gen, but it has wires.
    Skey44[QUOTED] likes this.
  28. Apr 20, 2021 at 3:05 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I have a turd gen, also wires are involved. Are you not concerned with blinding the general public?
  29. Apr 20, 2021 at 3:27 PM
    JMB
    Chesapeake, VA
    If you're asking me, no. I only want to see when backing up after dark. I only use them from the switch when I need light, such as night fishing on the beach. Casting light on the water brings bait fish in, which in turn brings other fish, or so the theory goes.
    I've only turned them on a couple of times while driving, with no one behind me, to see what an anytime rear camera looks like. Made me a little queasy.
    abcinv likes this.
