Double-sided tape removal - need advice
Discussion in 'Detailing' started by Thumper_6119, Apr 18, 2021.
  1. Apr 18, 2021 at 10:33 AM
    Thumper_6119
    Thumper_6119 [OP] I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    The previous owner of my beloved Tundra put on rain guards using the double-sided tape included with guards. They are now worn out and so brittle that they are breaking and coming apart (one broke at highway speeds and produced a loud buzzing as it vibrated in the wind, and it started flying apart). I ordered some Weathertech guards to replace them, but I need to remove the remaining double-sided tape from the old guards.
    Any advice on how to remove this without damaging the paint? Time in the Texas sun has cooked this stuff on, and I am concerned about damaging my paint (worse than what the tape sitting on there for years has already done) in trying to get it off.
  2. Apr 18, 2021 at 10:38 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Apr 18, 2021 at 10:44 AM
    Thumper_6119
    And THIS is why I love this forum! This is perfect. Never heard of such a creature, but I am getting one. Thanks a bunch!
  4. Apr 18, 2021 at 10:46 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    They work great. Used one to get rid of the adhesive when I debadged, and it’s come in handy for other odds n ends projects too.
    Thumper_6119[OP] likes this.
  5. Apr 18, 2021 at 2:40 PM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    I had the same situation on the 02 I bought in December. The old tape was quite hard. I went after it with short bursts from a heat gun and then a plastic blade scraper, which removed almost all of the crud. Then, my detailer hit the remains with Goof Off and a steam gun, which got the rest. Looks pretty good now. I installed WeatherTech in channel visors on the front doors, which almost disappear against the tinted glass, but offer nearly the same function as the old triangular sail vents when the door glass is toggled down an inch.
  6. Apr 18, 2021 at 2:44 PM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    A heat gun on low heat and a nice cloth.Finish it off with rubbing alcohol
  7. Apr 18, 2021 at 4:02 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    These work great! I used it to remove the pinstripes on my daughters car.
  8. Apr 18, 2021 at 4:45 PM
    Elduder
    Elduder New Member
    I can say from experience, if you use straight rubbing alcohol without diluting it and rub long enough you'll come up with paint.
    I use it to remove the butyl seal from the moisture barrier when I sealed my doors for stereo work, it works great but will remove paint. Just an FYI. Not an issue on the inner doors since theyre covered, but wouldnt recommend strait alcohol on clear coat.
  9. Apr 18, 2021 at 4:59 PM
    biebs96
    PA
    A 3m rubber eraser wheel will certainly help you out. Just watch the drill speed.
  10. Apr 20, 2021 at 11:16 PM
    reimord
    reimord New Member
    Eraser wheel is very effective. Although if you are not careful, it will burn through paint.
  11. Apr 20, 2021 at 11:36 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I also recommend the eraser wheel.
    Used a 3M wheel to remove badge residue and my TSS decal.
    Go slow and don't leave it on the paint for extended periods..
    3M Stripe Off Wheel Adhesive Remover Eraser Wheel Removes Decals, Stripes, Vinyl, Tapes and Graphics 4” diameter x 5/8” thick 3/8-16 threaded mandrel 07498 Pack of 1: Power Rotary Tool Accessories: Amazon.com: Industrial & Scientific
    https://youtu.be/FUj96ns1l7w
    Here is a recent thread about a guy removing his 5.7 badge using a heat gun and it took the paint right off..
    I'd wouldn't recommend heating up Toyota's already soft paint with a heat gun.
    de-badge gone bad | Toyota Tundra Forum (tundras.com)
  12. May 31, 2021 at 4:41 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Which one above exactly did you use? Debadging…
    Thanks!
  13. May 31, 2021 at 4:56 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  14. May 31, 2021 at 5:08 PM
    TheBeast
    TheBeast The Beach
    goo gone and eraser wheel.
  15. May 31, 2021 at 8:07 PM
    5150bronco
    Justin
    Bay Area, Ca.
    Thanks guys!
    Goo gone friendly on paint?
    Rubbing alcohol good with paint?
  16. May 31, 2021 at 8:14 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I used Goof Off sticker adhesive remover. Just don’t go crazy with it and you’ll be fine. Goo Gone would be fine too, and I’ve heard people say WD-40 works, but that one seems a little sketchy to me.
  17. May 31, 2021 at 8:45 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    Get a microfiber cloth and Lacquer thinner. wear rubber glues to keep the chemicals out of your liver, and prepare for some serious elbow grease. A heat gun will help but be careful not to heat up the trim and your paint too much. I removed badges this way leaving my paint flawless underneath. All the other methods will scratch your clear coat. After you are done get 3M paint swirl remover, usually only found at automotive paint stores, and a cotton cloth, as cotton acts as an abrasive in itself, to polish out the clear, should leave it extra clean with no residue, The lacquer thinner will not hurt a cured clear and get all the glue residue out. You will be at it for a while, but the wheel and gun will only get swirls in your clear unless you have all the adhesive off and a clean surface to polish. Goof off does work too, but smells horrible, lacquer thinner does the trick.
  18. May 31, 2021 at 8:51 PM
    5150bronco
    Justin
    Bay Area, Ca.
    Thanks a bunch!
    I was worried about something happening to the clearcoat in any amount because I would notice just the slightest difference in the paint.
    yes I will heat up the badges with a heat gun and then I’ll use floss to take the badge off instead of like a prybar.
  19. May 31, 2021 at 8:58 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    There is no reason to heat anything with a heat gun and risk overheating the paint.
    I used heavy fishing line and flossed the badges off.
    Removed the residue with a 3M eraser wheel at the recommended drill speed..
    Used Chemical Guys 38 to polish off any residue by hand, same thing as any other swirl remover.
    Rewaxed the area and I was done.
