Anyone added a tailgate down warning light?
Discussion in '2nd Gen Tundras (2007-2013)' started by tnbndr, Aug 21, 2021.
  1. Aug 21, 2021 at 8:04 AM
    tnbndr
    tnbndr [OP] New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I want to add a light on the dash that will warn me that the tailgate is down.
    Similar to the open door warning light.
    Anyone done this or seen a thread somewhere were it was accomplished?
    TIA
  2. Aug 21, 2021 at 8:08 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    It's not a bad idea, especially when you have a bed cover. The backup camera let's me know though.
  3. Aug 21, 2021 at 8:10 AM
    tnbndr
    New Berlin, WI
    My backup camera doesn't work anymore since changing over to LED reverse bulbs or some other modification.
  4. Aug 21, 2021 at 8:20 AM
    timsp8
    NY
    coldcanuk and NewImprovedRon like this.
  5. Aug 21, 2021 at 3:00 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
  6. Aug 21, 2021 at 6:41 PM
    Dr_Al
    Dr_Al New Member
    Al
    I don't think they will work very well. First you can't have any paint or the switch will not be grounded. At least up here I would want bare steel exposed to the elements. Secondly those switches are also not really made to be exposed to the elements. I think a magnetic reed switch might be a better option if salt is in your Tundra's future.
    tnbndr[OP] likes this.
  7. Aug 21, 2021 at 6:47 PM
    Danny3737
    I was thinking a hood pin switch like you get with a remote starter. You have to make sure it’s made of 316 stainless steel to keep it from rusting
  8. Aug 21, 2021 at 6:52 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Any normally closed momentary switch should do the trick. I've used these on commercial freezer doors
    Edit: Not any switch. Avoid cheap china switches from Amazon/ebay unless you like to do things twice. Get an eaton,cutler-hammer, usa made switch. There's not really that much price difference and they'll survive the repeated switching and environment for years
  9. Aug 21, 2021 at 6:54 PM
    Dr_Al
    Dr_Al New Member
    Al
    If you get stainless or gold plated and use a ring lug with a wire going to a ground it could work. But you'll need to find a place where you can mount it that the tailgate will push against it but will not be damaged and will hide the wire end. A magnetic reed switch could be mounted on the side by the taillight and a magnet on the tailgate tha would be pretty well protected.
    tnbndr[OP] and Danny3737 like this.
  10. Aug 23, 2021 at 3:12 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Sounds like a wiring issue and not a bulb thing, to be honest.
  11. Aug 23, 2021 at 4:19 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Use a magnetic read switch like home security alarms use.
  12. Aug 23, 2021 at 4:27 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Use a Magnetic Reed Switch like we use for overhead doors in Alarm Systems and then the thing will be armoured really including the wiring.
    Actually if you buy a Sentrol or GRI plastic reed switch and magnet they are sealed pretty tight already anyway and really small ones are available too. I would silicone them onto opposing surfaces and be good to go.
    The Plunger type switches will work too and though they look like they are like the pin switch which is an open metal rust prone switch these are also a reed switch inside and are sealed from the elements too!
    You can also get Alarm Contacts in an Open or Closed version where you would need no other components to light an indicator in the cab except a power tap somewhere.
  13. Sep 12, 2021 at 9:43 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    If you want to get really fancy, get a switch like A.R.E uses on there gas struts for canopy doors its triggers the inside canopy lights when the back glass is open, could easily rig that to easy down strut in the tundras tail gate (behind drivers side tail light) can't remember if the tail gate strut is in compression while close or not under compression. Either way it would work just two different route scenarios for the way the light would be triggered.
  14. Sep 12, 2021 at 9:46 PM
    NueveTundra
    Planet Earth
    05821489-A7C2-4457-8DE5-4EC77BF99742.jpg You can find it as a replacement item
    this will not only be a really clean way to install, but also keep more out of the elements also in a way. Also a pretty much a drill free way also instead of drilling the bed for a switch.
  15. Sep 16, 2021 at 11:06 AM
    tnbndr
    New Berlin, WI
    Searched ARE site and cannot locate that switch as an item. Would you have a link to where you found it.
  16. Sep 16, 2021 at 12:22 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    @tnbndr take the LED bulb out of your highmount brake light.
    tnbndr[QUOTED][OP] likes this.
  17. Sep 20, 2021 at 4:41 PM
    tnbndr
    New Berlin, WI
    Pretty sure the high mount is not LED but I will check.
  18. Nov 6, 2021 at 11:32 PM
    NueveTundra
    Planet Earth
    Yikes some how this one missed my feed. Here ya go , sorry for the late response.
    https://www.siraweb.com/gas-prop-switch
  19. May 28, 2022 at 10:16 AM
    tnbndr
    New Berlin, WI
    I bought one of these but it won't work for the tailgate as the strut is compressed when the tailgate is open which would close the switch, cutting the circuit thus turning off a warning light. It is a normally open switch and this application would need it to be normally closed.
    Oh well, worth the try.
  20. May 28, 2022 at 10:23 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Look for a mercury switch, or a tilt sensor for an aftermarket alarm.
    This is very easy to do. Mount the tilt switch inside of the tailgate , run the wires trough the factory camera opening to the cab and add a small led.
  21. May 28, 2022 at 5:22 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    I put this in the tailgate:
    DaierTek 3Pcs Door Jamb Flange Light Hood Mount Pin Switch Nickel Plated Universal with Rubber Boot for Car Truck Boat 20A 12VDC https://www.amazon.com/dp/B081MTFTDL
    I use it to automatically turn on the bed lights, but you could turn on a warning lamp by grounding the light to the switch.
    Drill holes and remove paint so the switch is grounded.
    Connect light ground wire to switch.EBA6D005-03A4-4DD6-B7EC-4B8D63AFF220.jpg
    Glue a screw to your finger so you can fish it through the brake light opening behind the switch. Maybe you'll figure out a better way lol.A4D223AA-7EF7-4AB5-9E2B-CD5B4909E633.jpg
    Trim the plastic plunger to the right length so the tailgate closes properly.
    bulldog93 likes this.
  22. May 28, 2022 at 5:52 PM
    Sounds like troubleshooting the camera would be a better option....
    1lowlife and landphil like this.
  23. May 28, 2022 at 6:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Well I be damned. I thought I was the only one on the planet that has ever glued hardware to my finger to get it started. I used crazy glue, and thankfully for me, a co-worker suggested wearing a nitrile glove when he heard my plan. The combo is brilliant, and doesn’t hurt.
  24. May 28, 2022 at 6:05 PM
    GNTundra likes this.
  25. May 28, 2022 at 6:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    :eek:
    :101010:
  26. May 31, 2022 at 7:47 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
    Funny this thread should pop up. My buddy installed a switch on his Taco to indicate when the tailgate is down. Turned out so nice, I've been considering it for my Tundra since with a tonneau cover, I can't see if it is down in the mirror and I don't remember to check with the camera.
    PhotoNerd likes this.
  27. Jun 19, 2022 at 3:13 PM
    Hyperforming
    Hyperforming New Member
    2007 Double Cab XSP
    I’d love to have one. Can’t count how many times I’ve ended up at work or across town with the trash still sitting on my tailgate. I’ve got a long driveway and will 100% forget it’s there by the time I get to the trash cans. ‍♂️
  28. Jun 21, 2022 at 8:03 AM
    tnbndr
    New Berlin, WI
    Trash would be ok, what about a shotgun and all your hunting gear??
  29. Jun 21, 2022 at 9:41 AM
    Hyperforming
    2007 Double Cab XSP
    That’s no good at all
  30. Jul 7, 2022 at 8:09 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    A few weeks ago I was stopped at a traffic light and noticed unusual activity in my mirror. I looked up at it to see a very sharply dressed woman in her mid 40s climbing out of her Mercedes SUV and walking up to my truck. We made eye contact as she reached my tailgate. She smiled at the curious look on my face, lifted my gate up and closed it. I smiled back sheepishly and mouthed "thank you”. She politely waved and boarded her 80,000.00 black beauty. The light turned green and off we went.
    I need a flashing light.
