Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Aug 31, 2021 at 7:21 PM
    #241
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
  2. Aug 31, 2021 at 7:22 PM
    #242
    shifty` I’ll teabag a piranha tank
    Huh. Never knew someone made camel socks. Go figure!
  3. Aug 31, 2021 at 7:36 PM
    #243
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    On a serious note... I'll be attaching links to various parts I find on company pewter. Links are to OEM source that @w666 posted. This is so I can click on phone, and order from there. Not putting any personal finance info on company pewter...
    Fan Shroud $88.59
    Lower fan shroud insert $59.91
  4. Aug 31, 2021 at 7:50 PM
    #244
    Did you get a desk job? Haha jk, but seriously, we just had a stupid meeting and the garbage putters were brought up, and the brass was like “yeah we’ve known those have been issues, you guys are pretty much at the end of the list to get them replaced” hahaha
    Tundra2[QUOTED][OP] likes this.
  5. Aug 31, 2021 at 7:59 PM
    #245
    Tundra2
    Noah
    Western Kentucky
    So Summit just sent me an email. Earliest they can get me parts is late November :rofl:
    So, how about rockauto? Anybody got any good links for me?
  6. Aug 31, 2021 at 8:23 PM
    #246
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Which parts were through summit? Seems like rock auto is pretty reliable. You can always save 5 percent by just googling for a discount code.
  7. Aug 31, 2021 at 8:24 PM
    #247
    Tundra2
    Noah
    Western Kentucky
    The timing belt, and water pump kit... something that is on the tip of the spear for my needs at the moment.
  8. Aug 31, 2021 at 8:31 PM
    #248
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I need to bleach my eyes
  9. Aug 31, 2021 at 8:34 PM
    #249
    Just the tip! I’m excited!
  10. Aug 31, 2021 at 8:35 PM
    #250
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
  11. Aug 31, 2021 at 8:47 PM
    #251
    Tundra2
    Noah
    Western Kentucky
    :spy:
  12. Aug 31, 2021 at 8:49 PM
    #252
    Tundra2
    Noah
    Western Kentucky
  13. Aug 31, 2021 at 8:52 PM
    #253
    Lil Steve
    Gilbert, AZ
    w666 and Tundra2[QUOTED][OP] like this.
  14. Aug 31, 2021 at 8:53 PM
    #254
    I didn't do mine, wish I had. Although I haven't had any issues with it. Yet. $26 is cheap insurance.
    Tundra2[OP] likes this.
  15. Aug 31, 2021 at 8:58 PM
    #255
    Tundra2
    Noah
    Western Kentucky
    I can't thank either of you guys enough. Y'all must have them fancy desktops. Tablets, and Cell phones ain't where it's at for part viewing.
    The work computer is like some sort of damned tablet/laptop hybrid thingy. Not worth a damn for anything, but company paperwork. :(
    Lil Steve and FrenchToasty like this.
  16. Aug 31, 2021 at 9:01 PM
    #256
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Dunno about Toyota, but certainly have seen them go out.
  17. Aug 31, 2021 at 9:04 PM
    #257
    Tundra2
    Noah
    Western Kentucky
  18. Aug 31, 2021 at 9:06 PM
    #258
    Lil Steve
    Gilbert, AZ
    Don't forget to use the discount code!
  19. Aug 31, 2021 at 9:15 PM
    #259
    Tundra2
    Noah
    Western Kentucky
  20. Aug 31, 2021 at 9:19 PM
    #260
    Tundra2
    Noah
    Western Kentucky
    @Lil Steve prder placed with discount which saved me $16 + change. :hattip:Shipping was $57 + change. Total investment $386.88
    I need a spreadsheet :oops:. I'll be canceling my summit order.
    All items are expected to be here by September 9th at the latest. :)
    NUDRAT and Lil Steve like this.
  21. Aug 31, 2021 at 9:37 PM
    #261
    NUDRAT
    NUDRAT 6 lug life
    SW CT
  22. Aug 31, 2021 at 9:43 PM
    #262
    daveeasa
    @Tundra2 when you did the DEPO clear corners, you re-cycled the OEM base to stuff in a 3157 switchback? Or did your DEPO's come with a 3157 base? Mine have a crappy round bs base but I have my OEM corners so I figure just use those.
  23. Aug 31, 2021 at 10:06 PM
    #263
    Tundra2
    Noah
    Western Kentucky
    I was going to ask that very question when they call me, and tell me the frame is ready. :rofl:May spray it inside anyways, and ask for forgiveness later.
    You need these bulb sockets. Any toyota vendor of your choice. Here's a link to mcgeorge.
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-turn-signal-light-socket-front-9007599106
    These convert from 3157s to 1157s which is what size bulb switch backs I used on my V6. If you just pop in a 3157 led you will lose the parking light feature as it's how the 3157 bulb adapter is wired.
    The following link is for the bulbs I used on my V6. They have gone up significantly since my purchase.
    https://www.vleds.com/shop-bulb-numbers/1157-led/1157-70-hv-wa-c.html
    You will also need an LED compatible turn signal module or load resistors. I went with the high dolla smart tap on the V6 and the budget turn signal relay on the corolla. Both work goooood from diode dynamics
    NUDRAT[QUOTED] and shifty` like this.
  24. Aug 31, 2021 at 10:10 PM
    #264
    daveeasa
    Ah, you purchased adapters, thanks.
    I'm re-wiring the whole enchilada so while I may need load resistors, I don't need anything other than something to get me bulb pins via connector.
    The plan is
    full strength white DRL (maybe ignition switched or maybe with dedicated switch or maybe attempt to upgrade the stalk to one with DRL, no idea yet)
    parking light in amber at half strength
    full strength turns with flashy flashy
    So I'll need dimmers and some way to have turn trump parking light.
    I think you use the whites as parking lights? I definitely don't want that and I definitely don't like my halogens on as DRL's which is how my truck works right now. That will be a waste of precious resources once I get high performance halogens in there.
  25. Aug 31, 2021 at 10:27 PM
    #265
    Tundra2
    Noah
    Western Kentucky
    Sounds like you've got it all figured out. Rewiring shit is just out of my expertise. Hell, I needed help with a simple relay box for switches... but hey. I'm one hell of a parts changer :rofl:
  26. Aug 31, 2021 at 10:33 PM
    #266
    daveeasa
    Yeah, man, spent the last 30 minutes coming up to speek on ck vs not ck, that's some detail I wish I didn't have to learn.
    Hey, so, on radiators, I need one too, and Dan's source wants $1600 so I'm not too interested in that option. I was going to try calling some of these yahoos tomorrow. I'm guessing you'd rather not drop big $ on that part? I don't really want to throw more plastic in mine...
    https://www.mishimoto.com/toyota-tu...GYAi9Q5LX5951hgizq4AReNDQZ75wcv0aAludEALw_wcB
    https://www.coldcaseradiators.com/product/00-06-tundra-47l-aluminum-performance-radiator
  27. Aug 31, 2021 at 10:39 PM
    #267
    Tundra2
    Noah
    Western Kentucky
    I'll be honest. I don't know jack shit on radiators. Going budget for now until I get everything buttoned up, and working as proper.
    I may go with one of the two links you provided in the future as those both appear to be quality. I'm sorry that I can't help further. Perhaps @SouthPaw would be able to chime in or @empty_lord
  28. Aug 31, 2021 at 10:45 PM
    #268
    empty_lord
    05 rollover special
    Holy shit $1600??
    NUDRAT, SouthPaw and Tundra2[OP] like this.
  29. Aug 31, 2021 at 10:46 PM
    #269
    empty_lord
    05 rollover special
    Go with Denso or OEM. They work for 90%of people. I just went fancy to avoid potential issues when towing.
    NUDRAT and Tundra2[QUOTED][OP] like this.
  30. Aug 31, 2021 at 10:48 PM
    #270
    Tundra2
    Noah
    Western Kentucky
    Denso works fine for me. One day this truck will be a tow rig, but that's a good ways into the future. Denso was on the Rockauto order.
