Let’s see your wheels and tires on a crew max
Discussion in 'Wheels & Tires' started by surf760, Aug 6, 2020.
  1. Jan 16, 2022 at 10:04 AM
    #601
    smr1619
    smr1619 New Member
    San Diego
    2019 SR5 Crew Max, 4x4, Cement
    brevard828, Sundog, J&ATundra and 3 others like this.
  2. Jan 16, 2022 at 10:21 AM
    #602
    ThisGuy03
    ThisGuy03 New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
    35x12.50/18 Yoko Geo M/T on black rhino 18x9.5 +6mm OS
  3. Jan 17, 2022 at 3:46 AM
    #603
    thedonn
    thedonn New Member
    i love the stickers on the rear - do you remember where you got them?
  4. Jan 17, 2022 at 3:48 AM
    #604
    thedonn
    thedonn New Member
    this is mine with the suspension installed - 6112 @+1.9 in front , 5160 rear
  5. Jan 29, 2022 at 12:58 PM
    #605
    Cal9er
    Cal9er New Member
    Jeff
    2018 Tundra TRD Sport 4x4
    Can you give info on your powder coat? What color and finish did you go with? I'm looking to do mine. Looks killer!!
  6. Feb 6, 2022 at 8:34 AM
    #606
    bryan s
    bryan s New Member
    NEPA
    2016 202 tundra crew cab
    3 1/2 rough country lift 295/60/20
    Sean492 and kleiker0303 like this.
  7. Feb 6, 2022 at 8:56 AM
    #607
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    275/70R18
    18x9 +18 wheels
    Bilstein 5100s on top setting
    Bumper aero deflectors removed.
    Rubs like hell.
  8. Feb 6, 2022 at 9:50 PM
    #608
    NWPirate
    Zach
    WA
    You rub with 275/70's? Something isn't right, maybe your backspace?
  9. Feb 7, 2022 at 4:56 AM
    #609
    WXman
    WXman New Member
    Kentucky
    I don't know. It's odd. I see videos with guys running +25 offset and 35" tires. There's no way that 7 millimeters of backspacing could make that much difference. Mine rubbed front and rear both. I used a heat gun on the splash guards behind the tires and that seems to be better now. But the front rubs like hell. I took off the air deflectors and it still rubs pretty bad. Have no idea how guys are running 35s on these trucks.
    NWPirate[QUOTED] likes this.
  10. Feb 7, 2022 at 5:09 AM
    #610
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I've got 275*70*18 on 18*9 wheels with +25mm, 5100s in the center clip and no issues. Could be a tire spec or caster issue, that is just strange. My Maxxis are 33.1" tall and 10.8" wide per the specs, check on your Coopers and see if it is different.
    brevard828 and NWPirate like this.
  11. Feb 7, 2022 at 5:18 AM
    #611
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    9D892493-681B-4171-A2C9-12B1A3045D11.jpg 35” Cooper rugged trek on stock nightshade wheels.
  12. Feb 7, 2022 at 5:18 AM
    #612
    WXman
    WXman New Member
    Kentucky
    I measured them unmounted. 33.0" tall.
    Measured them mounted and installed on the truck, got about 32.25" tall which is common once there's weight applied.
    Tread width, not section width, but tread width is exactly 9.0"
    I'm running them at 35 PSI. Tire shop recommends 40 but that would only make the rubbing worse.
    Alignment has been checked by two different shops this month.
  13. Feb 7, 2022 at 6:11 AM
    #613
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    You could shim the bumper out. I believe Coachbuilder makes a "kit" for this exact reason.
    WXman likes this.
  14. Feb 7, 2022 at 7:43 AM
    #614
    malibu dan
    malibu dan GSZILLA
    Daniel
    Phoenix
    2020 SR5 TRD offroad
    6 inch lift. 35x12.5. On 22’s
    patriot 35 x12.5 on fuel 22’s
    J&ATundra and Sean492 like this.
  15. Feb 7, 2022 at 10:18 AM
    #615
    WXman
    WXman New Member
    Kentucky
    Nice. My brother has those same tires. His have the Radar Renegade R/T+ branding on the sidewalls.
    malibu dan[QUOTED] likes this.
  16. Feb 7, 2022 at 11:30 AM
    #616
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    Love your truck !!
    But to be honest... I had to look at this picture for a few minutes to figure out what was bugging me about it... Then i see it... Looks like the passenger rear tire is about to fall off...:eek2:
  17. Feb 7, 2022 at 11:51 AM
    #617
    chriszulli
    chriszulli New Member
    New Jersey
    2020 MGM Tundra TRD Sport
    Method 316 17" wheel, KO2 tires 33", Bilstein 5100s all around
  18. Mar 10, 2022 at 2:15 PM
    #618
    77Cruiser
    77Cruiser New Member
    Josh
    2021 Black Tundra
    I assume you have a lift of some type? Do those tire rub at all?
  19. Mar 10, 2022 at 2:55 PM
    #619
    biebs96
    PA
    i have 5100s on the middle setting in the front and that is it. No rubbing.
    RustyShackle323 likes this.
  20. Mar 10, 2022 at 5:31 PM
    #620
    thedonn
    thedonn New Member
    I think with a 33.1 tire you should be ok if the alignment is right. remove the rear splash guards and heat up the front plastic (not the mudguards). this takes a bit of work - usually with a heat gun and a basketball to push the plastic forward after it is unbolted. some I think have cut away some of the front plastic as well. I have bumper shims but I have quite a bit of room. every set up is different though....mine are 295 70 18 (34.3 tall) and +25 offset
  21. Mar 11, 2022 at 7:56 AM
    #621
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    3/1 Life with 20x9 0 offset XD wheels. 295/60r20 Toyo's.
  22. Mar 11, 2022 at 8:02 AM
    #622
    MightyTundraGA
    MightyTundraGA New Member
    Ray 10s, Cooper XLT 275/70/18 w rough country 1.75in leveling kit on the front. Stock rear. All they had to remove was the front of wheel front mud flap.
  23. Mar 11, 2022 at 8:28 AM
    #623
    Borges911
    Borges911 New Member
    Jeremy
    Western Arizona
    2018 tundra SR5 Crewmax TRD
    17" Vision manx2 wheel with 285/70/r17 nitto terra grappler g2
  24. Mar 17, 2022 at 2:06 PM
    #624
    ryan2828
    ryan2828 New Member
    18x9 +12 offset. 295/70r18’s
    WXman, hANNAbONE, ATV25 and 2 others like this.
  25. Mar 18, 2022 at 6:43 AM
    #625
    Anelson1
    Anelson1 New Member
    2020 Super White Crew Max
    Tint
    KMC Dirty Harry +18mm
    Toyo MT 35x12.5r18
    brevard828, Sundog, ATV25 and 2 others like this.
  26. Mar 18, 2022 at 7:39 AM
    #626
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    What lift?
  27. Mar 18, 2022 at 7:50 AM
    #627
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I'm so late to this thread...haha
  28. Mar 18, 2022 at 7:56 AM
    #628
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Cypress, TX
    2018 SR5 X Series Tundra (sold) - why, why, why
  29. Mar 18, 2022 at 10:50 AM
    #629
    tweetlessfeags
    tweetlessfeags New Member
    2016 Platinum Tundra
    OME Nitrocharger Dakar Leaf pack+Add a leaf RCI Engine/transmission/differential/gas skid Bash Fabrication Weld-On Sliders Method 703-17" 0 offset ARB Dual compressor Victory 4x4 Engine bay compressor mount Cooper STT PRO 315/70/r17 Decked Drawers Cali Raised Led Ditch Lights WeBoost Reach OTR w/ Rhino Rack Aerial Mount Piaa SuperWhite Headlight bulbs Meso Customs Interior Light Kit Dometic CFX3 55IM Dobinsons Snorkel SnorkelUpgrade Precleaner GFC V1 AluCab Shadow Awn All the Tint
    17" Method 703 0 offset
    315/70/r17 Cooper STT Pro
    3'OME nitrochargers with dakar leaf+ add a leaf
  30. Mar 18, 2022 at 4:23 PM
    #630
    Anelson1
    Anelson1 New Member
    Tint
    King 2.5 coilovers w/ adjusters set at 2.5” of lift with .5” coachbuilder shim on top of the coilovers. Rear has King 2.5 shocks w/ adjusters and a lift shackle at 1.75”.
