Has anyone attempted to upgrade the stock SR5 headlights with Limited and above versions?
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Jul 3, 2022.
  1. Jul 3, 2022 at 7:06 AM
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    I saw an earlier post about the connector plugs possibly being different between the stock SR5 headlights and the Limited and above headlights. I kinda want the higher intensity and DRL marking strip of the higher trimmed headlights.
    Anyone attempted to upgrade the headlights with this version headlight, part: 81150-0C260 (I cut and pasted from Ebay and it is the left side headlight....for reference only). I would only get the headlights without the auto leveling.
    Thoughts....and Happy 4th in advance!
  2. Jul 3, 2022 at 7:41 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ryanwgregg and Buildn like this.
  3. Jul 3, 2022 at 7:54 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  4. Jul 3, 2022 at 8:02 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I'm sorry, I didn't see that..:oops:
    I didn't realize the 2022s had different level headlights.
    I learned something today..
    =JSG=, GODZILLA and Buellride[OP] like this.
  5. Jul 10, 2022 at 6:26 PM
    splashflash
    splashflash New Member
    Art
    Timnath, CO
    2022 SS Red SR5 Sport Premium
    Following for future hope :spy:
  6. Jul 10, 2022 at 7:57 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Same!
  7. Jul 14, 2022 at 3:57 PM
    Psam
    Psam New Member
    Philadelphia
    2019 Tundra Trd Pro voodoo blue
    Following as well. It’s ridiculous that’s it’s a $395 option from the factory installed but over 1k for each side through part store. That makes no sense ‍♂️
    DaveR4x4 likes this.
  8. Jul 14, 2022 at 6:08 PM
    99ways2die
    99ways2die New Member
    Be aware that [at least] Platinum headlamps are CAN-BUS driven.
    The wiring harness on the lamp itself are a constant 12V+, 12V- and about 7 thin wires.
    All of this means that the lamp gets power, and it's functionality is driven by the computer.
    In other words, there are no separate low beam, high beam, parking wires-like we're all used to from the past.
    Tread very carefully and do all your homework, before spending stupid amount of $$ on the high end model headlamps.
    -99
    Durtywrench likes this.
  9. Jul 14, 2022 at 6:39 PM
    splashflash
    Art
    Timnath, CO
    i'm still anxious to see if there's someone that will take a stab at it
    Soupbean77, DaveR4x4 and HusaUrDaddy like this.
  10. Jul 14, 2022 at 7:27 PM
    99ways2die
    I don't know.
    Here's (see pic) the connector from OP's part number, and it's exactly the same on my Platinum.
    What does your/SR5/Limited wiring for headlight looks like?
    -99
  11. Jul 14, 2022 at 11:08 PM
    Buellride
    Olympia
    THE BOULDER
    This is the picture that got me thinking about my SR5 headlight connector, thus asking my original question.
  12. Jul 15, 2022 at 5:51 AM
    99ways2die
    Here's a PDF of headlight with ECU wiring schematic (provided by another member here).
    I'm only speculating, but if SR5/etc has "standard" wiring and higher models have different set up (with CANbus), then you may not be able to run these as easily as you think.
    Getting signal out of a CAN bus is one thing, but going the other way around?
    Hope you guys don't end up taking headlights apart, just to rewire individual components inside of them separately; that would be a bit :/
    I'll hang around just to see what SR5 wiring is like; good luck.
    -99
    Buellride[OP] likes this.
  13. Jul 15, 2022 at 7:46 AM
    IslandStyle
    IslandStyle New Member
    Oregon
    2022 SR5 DC: Blueprint, TRD Premium Off Road AND 2004 SR5 DC: Charcoal
    Ignorant question here but I kind of like the headlights that came with my SR5. They are a huge upgrade over what was on my '04 and look pretty cool. Can someone tell me what the difference is between the '22 SR5 headlights and '22 higher trim versions and why it would be worth making that upgrade?
    TallulahTundra and oxlsu40 like this.
  14. Jul 15, 2022 at 9:23 AM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    They are both LED
    But the higher trim lights have a big white glowing piece at night, and they are all LED.
    The lower trim have halogen style turn signals, and I believe the main headlight housing is a reflector style, while the upper trim looks more similar to a projector style. Whether that makes any difference in light output, I don't know. But the upper trim ones do look fancy at night.
    There is also something about auto leveling, but thats probably just a gimmick. Oh, and the turn signal on the upper trim lights is sequential, instead of just a regular blinking light.
    Upper trim:
    Lower trim:
  15. Jul 15, 2022 at 10:13 AM
    IslandStyle
    Oregon
    Thanks jb. That's a great breakdown. I can see why one would want the higher trim versions.
    j.b.[QUOTED] likes this.
  16. Jul 15, 2022 at 11:36 AM
    OnThaLake
    OnThaLake New Member
    Good grief that's a lot of contacts for a headlight supposedly controlled by canbus.
    I see the 2 power contacts I'd expect, but for canbus I wouldn't expect to see more than 2 or 3 contacts.
    I don't think Toyota would use such a high pin count connector without some other reason....
    Edit: just saw the schematic you shared.
    Looks like they have 3 wires going from the headlight to the level sensor in the rear of the truck. Surprised Toyota took a hybrid approach, I would've anticipated the level sensor to also be on the canbus by a module in the rear. Yikes.
    Still, way more positions in the headlight connector than is actually used. Hmmm.....
    I have heard that the lower level MSR (multi surface reflector) LED headlights are quite good.
  17. Jul 15, 2022 at 12:34 PM
    TJF805
    TJF805 New Member
    2022 Tundra SR5 TRD Sport
    I have an SR5. I was pleasantly surprised by how bright the headlights are. I live in an area with plenty of unlit roads and with the low beams on I can see just fine. Kick on the fog lights and you have a pretty impressive area of light in front of the truck.
    raylo, TallulahTundra, RLHULK and 2 others like this.
  18. Jul 15, 2022 at 8:54 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    What does the SR5 DRL look like?
  19. Jul 16, 2022 at 4:25 AM
    splashflash
    Art
    Timnath, CO
    There are none. If you leave the "drl" setting on, it just means the headlights are on during the day
  20. Jul 16, 2022 at 5:24 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    True the headlights on my SR5 are impressive. Plenty of good bright light over a wide area.
    TJF805[QUOTED] likes this.
  21. Jul 16, 2022 at 7:32 AM
    OnThaLake
    With the popularity of blacking-out car parts, I'm surprised that the MSR headlights aren't the more popular type. They look blacked-out, and I think they look better than the projector headlights. They are also slightly serviceable, having a replaceable turn signal bulb, making them slightly less likely to have an expensive LED failure in the future.
    I am starting to see a lot of 20teen vehicles with failed LED DRLs now. One headlight will have dead or dimmed out LEDs, looks janky, and the LEDs can't be repaired, if you have OCD it'll cost big $$ just to get the DRL working again.
  22. Jul 16, 2022 at 8:17 PM
    TundraDriver$$
    TundraDriver$$ New Member
    Colin
    22 Tundra
    More I read the more I want the 10 yr 200k warranty
    OnThaLake[QUOTED] likes this.
  23. Jul 17, 2022 at 11:14 AM
    OnThaLake
    Make sure it covers LED lighting.
    My wife has a 2020 Corolla hatchback, she hit a mattress on the freeway, messed up the LED headlight a little bit, I thought about buying a new headlight, it is $1200! For a Corolla that cost $20,750. 2 headlights would be nearly 12% of the original cost of the car.
    So, I just JB welded it.
  24. Jul 18, 2022 at 5:45 AM
    TundraDriver$$
    Colin
    22 Tundra
    I don't know where you are but you just bought a truck that costs minimum $40k and you want to screw around with the electrical system. If you break it who is paying to fix it. I can guarantee it is not Toyota. You want the headlights you should have bought them with the truck. I would not do this.
    Soupbean77 likes this.
  25. Jul 18, 2022 at 6:30 AM
    EarlyRiser
    EarlyRiser New Member
    2020 Black Tundra SR5
    Modding our vehicles is quite popular around here. It isn’t for everyone though.
  26. Jul 26, 2022 at 10:51 AM
    TundraDude1987
    TundraDude1987 New Member
    Brad
    2022 Tundra SR5 4x4 TSS OFF
    TRD Pro Grille
    Still waiting for insight if it's at least possible. Surely some one has tried it
  27. Jul 27, 2022 at 5:56 AM
    TundraDriver$$
    Colin
    22 Tundra
    By the time I have the ceramic coat, clear vinyl paint protection tonneau and running boards I have 100k Canadian into it. I am not going to be screwing around with the electrics on a truck that I have a 10 yr warranty on.
  28. Nov 28, 2022 at 3:04 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I ordered mine without the premium led but curious if they only Lou have 2 options for headlights or do they have a couple variation on DRL and headlights combinations . I’ve been looking for info but don’t see much
  29. Oct 19, 2023 at 4:51 PM
    johnson156
    johnson156 New Member
    Ron
    2022 Lunar Rock TRD OR
    Following, found a cheap set of Sequoia TRD PRO headlights that I'd like to utilize.
  30. Oct 19, 2023 at 4:52 PM
    johnson156
    Ron
    I also messaged iHacker and gave him the link to this thread, here's to hoping...
