2021 Tundra limited power folding mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by don1, Feb 21, 2022.
  1. Apr 6, 2022 at 12:33 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    To my knowledge, no OEM style tow mirrors come with them
  2. Apr 6, 2022 at 12:38 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Gonna be digging some sweet holes with that tractor to bury what you caught in the trap? The mirrors might be a little big, but safety first and it looks like you've got the start of a good party there.
  3. Apr 6, 2022 at 12:41 PM
    hatchboi
    hatchboi New Member
    I meant for the regular mirrors. Are the pin parts number for the mirror folding button and mirror connector correct? I tried looking for it and nothing showed for it
  4. Apr 6, 2022 at 12:43 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Haha. Feral cats. We have 13 of them. We catch, get em snipped, and roll onto the next. The tractor is my 3 year old's
  5. Apr 6, 2022 at 12:48 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @RainMan_PNW can chime in on that as he's done quite a bit of research on the wiring for mirrors but I believe so.
  6. Apr 6, 2022 at 9:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What’s the question? Busy day at work.
    If you’re adding power folding mirrors to a truck that didn’t come with them, hit this post in my build thread
    https://www.tundras.com/threads/caseys-2021-lunar-rock-trd-pro-build.77317/page-10#post-2163301
    Modified Wiring diagrams, Pinout details, connector pictures, and part numbers are there. Power folding “normal size” mirrors are the same connector and pinouts, just that not all of them have all the options.
    someone asked about memory seats in a Limited - while technically possible, it would require swapping out a shit-ton on components, running a bunch of new wires, and would probably cost you a small fortune. The seats, mirrors, and steering wheel tilt are all integrated, and the actual power components aren’t available separately so it would be major surgery.
    finally - I’ve recently had one of my Boost Auto mirrors apart to trouble shoot something, and I will say two things:
    1. They are built hell-for-stout inside
    2. I can’t see any way to squeeze any kind of puddle light into them.
    texasrho83 likes this.
  7. Apr 6, 2022 at 10:55 PM
    hatchboi
    hatchboi New Member
    ok with the "normal size" mirror from 1aauto, how do i go about getting them to work with my 16 limited. is it just plug and play or do i have do some cutting and wiring? i do have BSM on my truck. also do the oem mirror cap fit on them?
    YotaMan likes this.
  8. Sep 9, 2022 at 12:07 AM
    WhiteJuan
    WhiteJuan New Member
    Juan
    Don1, for the most part I understand your upgrade to the power folding mirrors for the 2021 Tundra Limited.
    I too have a problem not being able to park my Tundra in the garage without getting out and folding the mirrors.
    To be Clear about your solution.
    1) Purchase the replacement switch on Amazon -- https://www.amazon.com/dp/B01KU4KXDO?ref=ppx_yo2_dt_b_product_details. This is a replacement to the existing switch in the 2021 Tundra Limited to add the push button capability to fold and unfold with the push button.
    2) Purchase the 2018 Toyota Tundra Driver & Passenger Side Chrome 2 Piece Mirror Set TRQ MRA04610 from 1A Auto.
    2) Purchase the pins you describe above that will be needed on both the mirror side and the switch side.
    3) Replace the manual mirrors with the 2018 Tundra power mirrors. During the replacement swap pins 9 and 18 on the mirror side connector.
    4) On the switch side, for the mirror folding button, it is unclear how to wire the push button with pin 175265-1 indicated. Could you elaborate a little more on the switch side for the push button wiring?
    Thanks.
    tomeks81 likes this.
  9. Sep 14, 2022 at 6:09 PM
    don1
    don1 [OP] New Member
    Here are few pictures I took that show the wirings
  10. Oct 2, 2022 at 9:29 PM
    WhiteJuan
    Juan
    Mirrors upgraded!
    The following is an update on what was ordered and situations I encountered during the upgrade.
    1) Purchased the replacement switch on Amazon, here is a link to it.
    https://www.amazon.com/dp/B08R75QGGB?ref=ppx_yo2ov_dt_b_product_details
    It is slightly cheaper than the solution Don1 provided and has a small harness. Harness was not used.
    https://www.1aauto.com/2014-18-toyo...ror-set-trq-mra04610/i/1amrp01403/851154/2018
    3) Purchased pins TE 175265-1 for mirror folding button. No problems getting them into the replacement switch.
    4) Purchased pins TE 1123343-1 for mirror connector. Had problems inserting these pins into the plug.
    Looks like the guide on pin is on the opposite side. Had to cut the top part guide of the pin to get it to slide into place. Probably not the exact pin for this plug but I managed to make it work.
    5) Replace the manual mirrors with the 2018 Tundra power mirrors. During the replacement swap pins 9 and 18 on the mirror side connector.
    Turns out it is tough removing those pins from there housing. I just cut pin 9 and 18 and re-routed them by soldering them back together. Used a shrink tube to cover the soldered wires.
    Turn signals on the mirror work. Which is something that is not on the original mirrors.
    I did not test the heated mirrors option, I assume they will work. We'll see this winter.
    Puddle lights are on the new mirrors and were not on the original mirrors. No big deal to not have them work.
    Most time consuming task was routing the wires from the replacement switch to the mirror connectors.
    They have to go through the door jams. Through the wiring boot between the cab and the door.
    Used a rigid fishing tool as that worked out the best.
    Don't have to get out of the truck to park in the garage any more!!! That was getting old.
    Thanks to Don1 for his original posting and follow up pictures as it motivated me to pursue this upgrade.
  11. Oct 2, 2022 at 9:55 PM
    don1
    Glad that it works for you and thanks for sharing these steps. I also have installed several cameras(Front, left side and right side) and controlled them using the buttons on the steering wheel. If interested I can share more infor about the wiring and components I used for this upgrade.
  12. Oct 3, 2022 at 1:08 AM
    WhiteJuan
    Juan
    Yes, please do share. I would be interested.
    I currently have a camera installed on the windshield behind the rear view mirror. Not the best solution but it was a quick add on.
