Sagging headliner with pano roof
Discussion in '3rd Gen Tundras (2022+)' started by Jkwolfe09, Oct 9, 2022.
  1. Oct 9, 2022 at 5:42 PM
    Jkwolfe09
    Jkwolfe09 [OP] New Member
    Jerren
    Anyone having issues with their headliner/roof sagging and not holding tight on tundras equipped with the pano roof. Mine pops out almost immediately. Looks like it’s held with shitty Velcro.
    Mike....8363 and Carolina Peej like this.
  2. Oct 9, 2022 at 7:03 PM
    Dieseldiagnostics
    Dieseldiagnostics New Member
    Can you post a pic of what it’s doing? I also have a pano roof but haven’t noticed sagging
  3. Oct 9, 2022 at 7:25 PM
    Jkwolfe09
    Jerren
    A pic really won’t show you much unfortunately I just know you can push up on the headliner and you’ll hear a click of sorts but then you’ll hear it pop out and it lose if you push on the area where the controls for the pano roof is
    Carolina Peej likes this.
  4. Oct 9, 2022 at 7:32 PM
    Jkwolfe09
    Jerren
  5. Oct 9, 2022 at 7:35 PM
    gr8fasushi
    gr8fasushi 22 Tundra Limited TRD Off Road
    yes I have the same problem on mine. I push it up and it stays for a few seconds before it drops again
    Gray Hawk and Carolina Peej like this.
  6. Oct 9, 2022 at 7:44 PM
    Jkwolfe09
    Jerren
    It’s fuckin annoying for a 70k truck… held together by max 4 less then 1 inch velcro sections. I’m gonna try double side 3m tape see if that helps
    Mike....8363 and Tundrastruck91 like this.
  7. Oct 9, 2022 at 7:48 PM
    Dieseldiagnostics
    Thanks for posting a pic. My guess is that mine is the same way but I’ll check. I’m curious to see how the headliner is attached. I hope it’s not just with Velcro!
  8. Oct 9, 2022 at 7:56 PM
    Jkwolfe09
    Jerren
    It’s that hard Velcro maybe 3/4 an inch spread out about every 7-8 inches
  9. Oct 9, 2022 at 8:04 PM
    Jkwolfe09
    Jerren
    Going to give this stuff a try
  10. Oct 10, 2022 at 5:50 AM
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    Issues with the moon roofs seem to be getting more common. Saw a couple other posts about people having water leak in to the cab due to a faulty pan.
    Hopefully you can get it fixed up :thumbsup:
    At least it's not leaking!
    Tundrastruck91 and Jkwolfe09[OP] like this.
  11. Oct 10, 2022 at 7:10 PM
    MBTraff
    MBTraff New Member
    I’ve had this same issue on my 1794. dealer knows about it and reported it to Toyota Canada. Toyota Canada asked for some pictures and a video. It looks like it is a Velcro problem. Next visit I’m bringing the good stuff another member talked about above. The tech is a buddy so I’ll just get him to use my stuff instead of replacing the crappy Velcro with more crappy Velcro.
  12. Oct 12, 2022 at 1:09 AM
    TundraTT1794
    TundraTT1794 New Member
    Picked up the 1794 last Friday and noticed this issue today! So annoying.
  13. Oct 12, 2022 at 12:16 PM
    Jkwolfe09
    Jerren
    Yep took mine into dealer for some recall work and told them to fix it.. they said it’s fixed but for how long…
  14. Nov 10, 2022 at 8:16 AM
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    My issue isn't the velcro visibly sagging.. it's the noise it makes when I go over minor bumps. It crackles and pops and is driving me nuts. I took it to the dealer and they verified it, but no fix as of now. Can I just ask them to replace the headliner?
  15. Nov 10, 2022 at 10:13 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    On my 08 I used invisible seam like a tailor used. Most of those double sticks are to thick.
    I also used liquid fabric glue but it leaves a water dot.
  16. Nov 10, 2022 at 1:10 PM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    You really don't want that. If you think what you have now is annoying, wait until a toyota tech has to replace an entire headliner.
    TWJLee and Tundrastruck91 like this.
  17. Nov 10, 2022 at 1:45 PM
    22platitundy
    Any recommendations? The noise is louder than any rattle in the interior (front doors, dash, center console). There's gotta be a fix.
  18. Nov 10, 2022 at 7:36 PM
    Jkwolfe09
    Jerren
    I hear what you hear but only once in a while over a bump or something. But not constant
  19. Nov 11, 2022 at 8:00 AM
    22platitundy
    The roads in my town might be some of the worst in the country. When I'm on well maintained roads, I don't hear it. When I'm on the other 90% of roads, I hear it. It might be something I'll have to live with.
  20. Nov 11, 2022 at 1:49 PM
    22platitundy
    Did this fix it?
  21. Nov 11, 2022 at 1:58 PM
    GG.Offroad
    GG.Offroad New Member
    Austin
    Westminster, CO
    2023 Tundra Limited Hybrid Lunar Rock
    www.ggoffroad.com
    If youre pulling the headline you should take pics of the cable routing and locations for us!
  22. Nov 11, 2022 at 3:06 PM
    Cthulhu
    I had this issue on my 2018. I started early morning, added a helluva lot more double sided velcro (Gorilla brand) around the entire perimeter of the moonroof, and kept it open the entire day using clamps to allow the adhesive maximum time to set and hold. It's been about a year and it has not fallen again, and, no more squeaking noises near the rear dome light housing.
  23. Nov 11, 2022 at 6:42 PM
    Jkwolfe09
    Jerren
    No unfortunately I took it to the dealer and I presume they added more Velcro Toyota bullshit to it
  24. Nov 14, 2022 at 3:26 PM
    Hike5
    Hike5 New Member
    2022 Tundra Limited Crewmax
    How do you pull the headliner off without damaging it? Mine is driving me nuts, I’m thinking of adding a thicker double sided foam to dampen the shakes
    GG.Offroad likes this.
  25. Nov 14, 2022 at 5:57 PM
    GG.Offroad
    Austin
    Westminster, CO
    www.ggoffroad.com
    Im not sure, but when you figure it out, I will pay you for detailed pictures of these connectors (rear view mirror camera):
  26. Dec 14, 2022 at 8:40 PM
    Adam23
    Adam23 New Member
    23 Platinum Tundra
    Did you make any progress on this? My Tundra has 186 miles on it and I already notice this noise:/. Any advice is appreciated!!!
    22platitundy[QUOTED] and Hike5 like this.
  27. Dec 15, 2022 at 9:17 AM
    22platitundy
    No waiting for the Toyota engineer to come through so they can look at it. Dealer said some time after new years. It seems like it would be a simple fix for the dealership, just need to add padding/stronger velcro. But I don't think I can do it myself without damaging something.
  28. Dec 15, 2022 at 9:51 AM
    22platitundy
    Read this thread
  29. Dec 15, 2022 at 9:58 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  30. Dec 15, 2022 at 10:14 AM
    22platitundy
    The same one we're in. The original post is about sagging headliner.
