1st gens to Sedona 2023!!!
Discussion in '1st Gen Tundras (2000-2006)' started by FrenchToasty, Feb 17, 2023.
  1. Apr 13, 2023 at 10:10 AM
    #1621
    SAGE63
    San Diego County
    yup
  2. Apr 13, 2023 at 10:42 AM
    #1622
    AZBoatHauler
    So.Arizona
    GMRS has preset channels like CB.
    des2mtn likes this.
  3. Apr 13, 2023 at 10:45 AM
    #1623
    shifty` Smoking Sodium Pentothal and cigarette butts
    Tundra2, bmf4069 and DJenerated like this.
  4. Apr 13, 2023 at 10:46 AM
    #1624
    AZBoatHauler
    So.Arizona
    Just about time to start getting to work.
    Mater, bmf4069, TRDFerguson and 3 others like this.
  5. Apr 13, 2023 at 12:09 PM
    #1625
    daveeasa
    So looks like these caliraised amber pods come w Deutsch male connectors.
    I could supply some extras for someone to splice back in, or some terminals and connectors if anyone wants to attempt to restore the cut ends to factory fresh.
    Still have no idea how to help w any external switching setup other than doing a relay and a long coil of wire which isn’t all that useful nor universal.
    RainMan_PNW likes this.
  6. Apr 13, 2023 at 12:54 PM
    #1626
    bmf4069 Yup, that's a whole ass truck in a dishwasher
    @Mr.bee
  7. Apr 13, 2023 at 12:57 PM
    #1627
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Going clear on the bumper as well?
    Just a FYI those back tails are going to want to kick up on you when when you go to install. Might end up with a couple scratches on the plastic below the headlight like I did
    bmf4069 and TRDFerguson like this.
  8. Apr 13, 2023 at 12:58 PM
    #1628
    AZBoatHauler
    So.Arizona
    I wish - but I think my wife would try to have the kids taken away. I’m coarse sanding this and the sliders and going to spray them with black Steel-it.
    bmf4069 and Mater[QUOTED] like this.
  9. Apr 13, 2023 at 12:59 PM
    #1629
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    He's gotta build up a good patina first
  10. Apr 13, 2023 at 1:01 PM
    #1630
    AZBoatHauler
    So.Arizona
    :hattip:
    Mater[QUOTED] likes this.
  11. Apr 13, 2023 at 1:03 PM
    #1631
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Hopefully you have a local buddy willing to help you out. If not, please set up a voice recorder. Always love learning new vulgar terms :rant:
    Sunnier, RainMan_PNW, bmf4069 and 2 others like this.
  12. Apr 13, 2023 at 1:05 PM
    #1632
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Aww c'mon. Let him find out the hard way :rofl:
  13. Apr 13, 2023 at 1:07 PM
    #1633
    AZBoatHauler
    So.Arizona
    bmf4069, Tundra2, Mater and 1 other person like this.
  14. Apr 13, 2023 at 1:13 PM
    #1634
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    @AZBoatHauler not sure if you have a stubby wrench set but you’ll need it if planning to do the support brackets. I believe it’s 19mm will check when I get home
    AZBoatHauler likes this.
  15. Apr 13, 2023 at 1:18 PM
    #1635
    AZBoatHauler
    So.Arizona
    I’m guessing you need it for the long bolt on the inside of the frame rail? I have an SAE set from doing the sliders that might work.
  16. Apr 13, 2023 at 1:19 PM
    #1636
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    “Son, remember those scratches you put on the Land Cruiser? Time to make up for it with some scratches on your arm”
    There will be blood after passenger side..
  17. Apr 13, 2023 at 1:20 PM
    #1637
    AZBoatHauler
    So.Arizona
    good thing he still has skinny arms.
    TRDFerguson and Mater[QUOTED] like this.
  18. Apr 13, 2023 at 1:24 PM
    #1638
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Been a LONG time since I've seen a firefly gif.
  19. Apr 13, 2023 at 1:30 PM
    #1639
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    You ever been in a fight with your engine wiring harness? Once your sleeve goes over the frame it’s like sticking your forearm into an box filled with cats
  20. Apr 13, 2023 at 1:31 PM
    #1640
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    See... I want something that I can hard mount into the truck that stays IN the truck that also works with that shit.
    What do I need to look for?
    Also, I'd probably have one of those plugged in, turned off, in the even of getting separated and the truck breaking down. I realize that best chances of survival are staying with the truck, but still in the off chance of self rescue... be nice to have a radio that's portable too.
    I just want to mount something in my truck I don't fucking need. I really need to figure out trailer brake shit but I just don't have the wind in my sails for that right now
    Sunnier[QUOTED] and TRDFerguson like this.
  21. Apr 13, 2023 at 1:33 PM
    #1641
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I whipped a crackheads ass one time with a 48" zip tie. Does that count? That sum bitch was bleeding like a stuck hog
    shifty`, RainMan_PNW, bmf4069 and 2 others like this.
  22. Apr 13, 2023 at 1:34 PM
    #1642
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    @AZBoatHauler might have a good setup to recommend
    kinky
  23. Apr 13, 2023 at 1:42 PM
    #1643
    AZBoatHauler
    So.Arizona
    I put one very similar to this in the console -
    BTECH Mobile UV-50X2 (Second Gen.) 50 Watt Dual Band Base, Mobile Radio: VHF, UHF Amateur (Ham) https://www.amazon.com/dp/B06XK83VRV
    configuring an antenna and running the wire for it are the biggest pain about going this route but reception / transmission is wayyyy better than a handheld.
  24. Apr 13, 2023 at 1:51 PM
    #1644
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    And I can use this for vehicle to vehicle if on a road trip? What kind of range can I expect?
  25. Apr 13, 2023 at 1:56 PM
    #1645
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sorry for the retarded questions. I haven't been to sleep yet, and need to be awake in 2.75 hours for work :rofl:
    DJenerated and bmf4069 like this.
  26. Apr 13, 2023 at 1:58 PM
    #1646
    DJenerated and Jack McCarthy like this.
  27. Apr 13, 2023 at 2:05 PM
    #1647
    AZBoatHauler
    So.Arizona
    Sure - it will talk to anything that can receive / transmit on those frequencies.
    Mine is only 25 watts but with a decent antenna I can hit repeaters that are a little over 20 miles away. That is near ideal conditions though from the foothills down to the valley.
    FrenchToasty[OP] likes this.
  28. Apr 13, 2023 at 2:42 PM
    #1648
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'm thinking once you get to Beau's, you can fix that problem with fire water !
    bmf4069 and shifty` like this.
  29. Apr 13, 2023 at 2:43 PM
    #1649
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Drink the dyslexia away! :D
    BubbaW[QUOTED] likes this.
  30. Apr 13, 2023 at 3:39 PM
    #1650
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    More hellbent on preventing the fun sins at least. They’re still pretty good at upholding the rest of them
    bmf4069 and Azblue like this.
