2023 Tundra Backseat for dogs
Discussion in '3rd Gen Tundras (2022+)' started by Mcvic21, May 23, 2023.
  1. May 23, 2023 at 6:07 PM
    Mcvic21
    Mcvic21 [OP] New Member
    Chase
    2023 Tundra SR5 Lunar Rock
    Hey y'all, not sure if this has been asked before but I'm trying to find something for my big dog. The seats go up but there's that tool/storage under the seat making it not flat. I've tried buying multiple covers for the seat with a hard bottom or foam seat extender but he just slides around. I traded in my Ram 1500 for the Tundra and the seats just went up with a flat floorboard I could put his bed down. Anybody know of anything i can buy that will make it flat so i can put his bed down? Thanks!
  2. May 23, 2023 at 6:36 PM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    vtown76 likes this.
  3. May 23, 2023 at 6:47 PM
    Mcvic21
    Chase
    That would totally work if I wanted to do a seat delete. He's almost 9 and 130 pounds with an already sore leg so it makes it tough. So far we haven't found anything that will work. Our next step is to try to build something but we'd rather not if there's a product out there.
  4. May 23, 2023 at 6:52 PM
    TundraTT
    TundraTT Full Send
  5. May 23, 2023 at 7:06 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I know you're looking to just do a purchase. However, you're best and probably fastest resolution is to cut out a plywood platform for the area you're wanting to have your dog on. You'll need to build a few "legs" to elevate the platform just enough to smooth out your humps, obstacles, etc... then cover the surface w/a 1/2" or 3/4" stall mat, and your pup will have a secure, non-slippery, non-destructible area to travel/rest on.
    Another benefit about doing it custom like this is that you'll be able to prevent any gaps between the platform and upholstery which can easily trap arms/paws (especially with an older pup). If it's elevated high enough you can have storage underneath.
    Finally, if you have zero interest in doing this yourself, just take your truck to a car audio place that builds custom boxes, etc. and they'll be able to hook you up :thumbsup:
  6. May 23, 2023 at 8:16 PM
    WoodyOne
    WoodyOne New Member
    Spring, TX
    2023 1794 Blueprint 4x4
    I have something similar for my two dogs, one is 105 lbs and the other is 80 lbs. Works pretty good.
  7. May 23, 2023 at 8:26 PM
    TundraTT
    TundraTT Full Send
    Yup, same here. Holds my 75lb lab and catches most of her hair with it haha
    WoodyOne[QUOTED] likes this.
  8. May 23, 2023 at 8:45 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    The 3 gen Tacoma had the best back seat for doggos!
    Ausfahrt and LunarRockTundra17 like this.
  9. May 24, 2023 at 4:30 AM
    nodak67
    nodak67 New Member
    JR
    not to keen on putting that much weight on those head rest posts. maybe 1 dog but i have 2 gsp's so yeah not wanting to bend those. :)
    Mattedfred likes this.
  10. May 24, 2023 at 4:47 AM
    hoki06
    hoki06 New Member
    I’m working on a plywood platform to make a flat area for the dog when the back seats are flipped up. I only have a picture of my car board template at the moment but I’m about halfway done. I’ll post more when I make more progress this weekend.
    The end goal is a carpet covered platform cut into the same 60/40 split as the seats so I still have flexibility to use the backseat with a dog. It will be covered in outdoor carpet and I might put in access hatches to reach the under seat storage.
  11. May 24, 2023 at 4:54 AM
    nodak67
    nodak67 New Member
    JR
    good luck on that :) , would love some one to make a turn key system like that with a way to anchor it into place.
  12. May 24, 2023 at 5:38 AM
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Please keep us updated!
  13. May 25, 2023 at 5:14 AM
    PoundHard
    PoundHard Knows just enough to be dangerous
    22 SR5 TRD OR Prem
    3" Lift, Defender Flares, EGR Deflectors, Ceramic Coat, UnderCover ArmorFlex, DIY De-chrome, Headwaters Seat Covers
    This is a great idea! I'd love to see where you go with this
  14. May 26, 2023 at 4:58 PM
    hoki06
    hoki06 New Member
    Progress on my dog platform this afternoon. I’m going to cut it 60/40 to match the seats so it’s 1) easier to put in/take out and 2) gives flexibility for carrying dogs and more than 2 people. Before carpeting I still need to figure out a rear support in the center and I’d like to cut two hatches to be able to access the storage underneath. To be continued…
  15. Jun 1, 2023 at 5:48 AM
    hoki06
    hoki06 New Member
    Hatches cut and framed underneath, 60/40 split cut, and covered in cheap yoga mat for some cushion. Wrapping with indoor/outdoor carpet then it’ll be done.
  16. Jun 3, 2023 at 2:18 PM
    DJM
    DJM New Member
    I want to make something like this! Thanks for sharing your design.
  17. Jun 3, 2023 at 3:52 PM
    TundraTT
    TundraTT Full Send
    That’s pretty damn good!
    If I were to add to your design, I would use these anti fatigue squares or something similar. Lots more cushion than mats for long hauls. I lined the cage in the police car for my k9 with them and I don’t hear one complaint from back there haha
    Performance Tool W88988 12" X 12" Protective Diamond Shape Anti-Fatigue Interlocking Floor Mat (12 Square Feet) , Grey https://www.amazon.com/dp/B004GBOZIW
    Black widow TRD likes this.
  18. Jun 3, 2023 at 6:35 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
  19. Jun 3, 2023 at 9:24 PM
    BlueprintShane
    BlueprintShane New Member
    Thanks for sharing. I'm looking for inspiration to make something for our dogs too. As mentioned above, I considered an inflatable bed.
  20. Jun 4, 2023 at 5:51 AM
    Paul Moll
    Paul
    Idaho
    I find that an important attribute is for it to be a rough surface so they get good traction, especially for braking and turning.
    I wanted something easy to remove as well as cheap. Thus the plywood with Costco rubber mat.
    Please share what you end up with. Always looking for good ideas.
  21. Jun 4, 2023 at 3:01 PM
    hoki06
    hoki06 New Member
    Finally finished my platform today. The whole project took way longer than expected but I’m a perfectionist so I should have known this would happen.
    Made a rear support that stays in the truck and uses the factory push connectors under the seat to hold some custom aluminum tabs and keep it in place. Wrapped everything in carpet and then added pull tabs for the hatches.
    Overall I’m very happy with the final product. I might add some dowels to lock the two pieces together better but we’ll see how it works for a while first.
  22. Jun 4, 2023 at 3:26 PM
    ReCKzX
    ReCKzX New Member
    That is legit.
  23. Jun 4, 2023 at 4:12 PM
    AND
    AND New Member
    Washington, PNW
    Can you post of pic of the bottom to see how you made the hatches?
  24. Jun 4, 2023 at 4:21 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Curious on how much the platform weighs to see if it’s easily removable. I'd like to do this since our GSD head hits the headliner when he sits up on the seat.
    The big baby.
  25. Jun 4, 2023 at 6:31 PM
    hoki06
    hoki06 New Member
    Here’s a bottom view. It’s framed with 1x3 and then I cut reliefs where the hatch sits to allow for the carpet thickness so it’s flush on top.
  26. Jun 5, 2023 at 4:44 AM
    hoki06
    hoki06 New Member
    I considered thicker but didn't want too much to the point that the stability would be affected. We have dog beds we throw in for long haul rides if needed. Out last dog slept on the hardwood as much as his bed so it should be fine either way.
    It's not light which is one of the reasons I did the 60/40 cut. It's much more manageable now. With the whole thing complete finally, it's pretty easy for flip up then support and pull it out without hitting anything.
    TundraTT[QUOTED], AND and Mattedfred like this.
  27. Jun 5, 2023 at 11:56 AM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    Amazing build! great job =) if desired.. could you still drop the seat down on top of platform?
  28. Jun 5, 2023 at 12:06 PM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    This is why I want to make one too. I just marked out a cardboard template & when I dig out my saw & can get some wood & get started ( mine is a CM )
    Mattedfred[QUOTED] likes this.
  29. Jun 5, 2023 at 12:42 PM
    Paul Moll
    Paul
    Idaho
    Every GSD I've ever know is a big baby !!
    FoopaKing likes this.
  30. Jun 5, 2023 at 12:48 PM
    hoki06
    hoki06 New Member
    Thanks! The seats cannot flip all the way down as they are designed to rest on top of the under seat storage. I suppose you could still sit on the seats but I'd worry about damaging the seat bottom or hinges.
    bcj001[QUOTED] likes this.
