  1. May 30, 2023 at 3:07 PM
    True!
  2. May 30, 2023 at 3:11 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I've got the belt, idler, and tensioner (kit on RockAuto) coming along with a couple gallons of Pentosin.
  3. May 30, 2023 at 4:49 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Painted rims with plasti-dip “gloss”.
    Sprayed my tails with VHT niteshades - time for some VLeds
  4. May 30, 2023 at 6:18 PM
    Bowzer
    Bowzer New Member
    Throw a couple dryer sheets in a bucket of warm to hot water. Soak your favorite rag and those will come right off my friend...
    I'm still working on some use for love bugs. If they tasted better we could make some kind of special peanut butter...
    Moreblacktss and NewImprovedRon like this.
  5. May 30, 2023 at 6:32 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Thanks. I confirmed it’s my skid / Cat plates.
    300BLK[QUOTED] likes this.
  6. May 30, 2023 at 6:50 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Had to change out the battery today. It had been acting up for a month or so, I had to jump my truck this morning after it sat for the 3 day weekend then had to jump again after work, so it is gone. Went thru 2 odyssey battery's in under 5 years, so I went with a cheaper option.
  7. May 30, 2023 at 7:17 PM
    Florida AF
    Logan
    North Florida
    oh, i know how to handle them. Wanting to is a different story lol. great comment though for those who dont know.
    I am about to take my girl on a mid state trip thursday so I already have the treatement ready for her return!
    Bowzer[QUOTED] likes this.
  8. May 30, 2023 at 10:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Seems like that was what things looked like when the water pump was going on my 2008...
  9. May 30, 2023 at 10:06 PM
    RainMan_PNW
    Casey
    Clark County, WA
    that was about where my 2008 went.
    The second one lasted over 180k
  10. May 31, 2023 at 12:16 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Good cause our Sequoia is at 125-130k and I don't know if it's been done before we got it
  11. May 31, 2023 at 5:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I have a website that auctions off secondhand items (usually Amazon items) that were returned. You’re allowed to go look before you bid. I found a cat shield that I ended up paying $5.81 for. Downside, there’s a big ass dolphin cut out and I think the corners are bent down some (I can bend back). Upside, all hardware is there and $5.81 is a lot cheaper than replacing cats. Just need to install now.
  12. May 31, 2023 at 5:55 AM
    RobertD
    Robert
    DFW, Texas
    You can always cut a different shape into the center. For 5.81 you have a lot of wiggle room to customize
  13. May 31, 2023 at 6:00 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah I was thinking about options I can do with it. I don't have a welder or anything like that but I could at least cut it into a rectangle. Or just pretend I'm a miami dolphins fan :anonymous:
  14. May 31, 2023 at 6:06 AM
    RobertD
    Robert
    DFW, Texas
    Or throw up a Hitch Hikers Guide to the Galaxy quote and call it a day. I'm sure anything from that book would confuse the heck out of anyone under your vehicle :rofl:
    WVI, Sleeper16plat and the red like this.
  15. May 31, 2023 at 6:07 AM
    wiltech
    wiltech New Member
    Tony
    Lafayette, IN
    2018 Inferno Limited
    Grab a sharpie and write, "So long and thanks for all the fish" underneath it and call it good
    bulldog93, WVI, the red and 4 others like this.
  16. May 31, 2023 at 6:11 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    These are great :rofl:
    Pork of the Sea lol
    RobertD[QUOTED] likes this.
  17. May 31, 2023 at 6:22 AM
    wiltech
    wiltech New Member
    Tony
    Lafayette, IN
    It's either that or: "Laces out, Dan!"
  18. May 31, 2023 at 7:02 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Well, I discovered a different issue after forcing the water or winching through the mud: it is hard to fill up the tank at the gas pump now. The pump cuts off unless the flow is kept very slow. Need to crouch under the truck and check the charcoal canister's vent. Or maybe it is half full of water, need to take it out, drain and dry up then. I had a similar issue with my old Volvo: there was a spider net in the vent, and a spider died apparently being high up ;)
    Probably a good idea to relocate the canister's vent as well.
  19. May 31, 2023 at 12:32 PM
    WaterWolfHunter
    WaterWolfHunter New Member
    Picked up this 2021 in March. First upgrades completed today;
    Yokohama Geolander M/T G003 275/70/18 - Perfect size imo for the actual type of off roading I do. Not a fan of wheel poke.
    Bilstein 5100 all around
    A.R.E Overland cap
    Only drove it home from the off road shop and haven’t had a chance to really look it over but a quick look and the A.R.E Overland cap looks like it’s missing a rivet piece and one of the side windows has some pretty rough finishing.
    Most everyone has tire favorites. Mine are Super Swampers but since I’m in my 40's now and not a teenager driving my dads 1979 Jimmy, I went with something that I have no experience with but will get me safely to Wegmans and home…don’t see much on these Yokos here but I’ve seen these absolutely be abused and still slay off road and snow after 30k miles.
    Yes, I can easily feel the weight difference and they are way louder compared to the Yoko A/Ts.
    If anyone lives close to Rochester NY area and wants the Bilstein 4600’s I took off for free let me know.
    Looking forward to taking the rig and seeing how it does in the bush up in northern Ontario on a fishing trip in a few weeks.
  20. May 31, 2023 at 12:45 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Nice Truck! GLWS
  21. May 31, 2023 at 1:17 PM
    Welcome northern neighbor.
  22. May 31, 2023 at 1:19 PM
    Great 1st post offering free shocks.
    Just be careful about selling the tires. Read this.....
    https://www.tundras.com/threads/buy-sell-trade-rules.203/#post-2358
  23. May 31, 2023 at 3:35 PM
    WaterWolfHunter
  24. May 31, 2023 at 5:06 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    All you need is a matching Tow Hitch cover! Phins Up!:)
  25. May 31, 2023 at 5:16 PM
    I didn't think so, since your first post you were giving something for free.:thumbsup:
    WVI likes this.
  26. May 31, 2023 at 5:16 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Had my tint put on today. I got my 17 SR5 about a month ago. Didn’t go ceramic like my little commuter car, can’t tell the difference really tbh. Feels good to be back in the tundra world. I had a 21 limited double cab in cavalry blue and frequently posted all my mods about a year ago. Pic is my current little stable lol. Sorry if it’s not allowed - My ES300 is a 1999 with only 64k miles.
    P.S. - Morimoto xb’s in amber getting delivered tomorrow for the truck
  27. May 31, 2023 at 6:28 PM
    I remember your 21...it was a nice truck. The XB's are nice. I love mine. Get rid of all that chrome though lol.
    bulldog93, the red and Cl8NL[QUOTED] like this.
  28. May 31, 2023 at 6:47 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Thanks! The gears are turning for how I wanna go about that lol. I found a Tacoma forum post where some guys with quicksand used an off-the-shelf can of Rustoleum in “Gloss Khaki” that is a very passable match. I bought a few for $6 vs actual factory paint code cans. I don’t think I’ll do the $800 sparksparts grill here unless the home job turns out horrible. I’ll pass on the ecoological shells too (at least on the grill).
    the red likes this.
  29. May 31, 2023 at 6:53 PM
    I always bought my paint from automotivetouchup.com. They were an exact match. Yeah I am not font of the shells either.
    bulldog93 and Cl8NL[QUOTED] like this.
  30. May 31, 2023 at 8:59 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Go Browns!
