Maestro link and call buttons on wheel
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jamoose, Jun 26, 2023.
  1. Jun 26, 2023 at 8:53 AM
    Jamoose
    Jamoose [OP] New Member
    An installer is putting in a new system to a 16 tundra. Took an initial review of install on Saturday and was told that call accept functionality on the wheel is lost and was a function/result of the maestro link. Head unit is an alpine halo. Is this accurate or an install issue? Truck is still with installer so trying to see if I need to accept this or push on the issue. Has anyone else been successful with this? Thanks.
  2. Jun 26, 2023 at 8:59 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I have an 18 1794. I installed an aftermarket head unit with Maestro and still retained all call functions on the wheel. I even changed the volume up/down and track back/next to the way they should be.
    27bluenote likes this.
  3. Jun 26, 2023 at 9:06 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    The maestro unit itself may not have been programmed correctly to correspond with the right buttons
  4. Jun 26, 2023 at 9:35 AM
    He needs to verify the upload to the Maestro but all of the functions on the steering wheel are supposed to work.
  5. Jun 26, 2023 at 9:41 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got a 17 that I upgraded the head unit, I had the maestro module installed and all steering wheel functions work and call functions work. I changed it out so I can use CarPlay. Everything works.
  6. Jun 26, 2023 at 4:52 PM
    Jamoose
    Thanks for the response everyone. I called the company that makes maestro (name escaping me at the moment) and they also confirmed. I have relayed the information to the installer and he said he would look back into it. Appreciate the help. Always important to know you’re barking up the right tree.
    Tundra234 likes this.
  7. Jul 1, 2023 at 6:02 AM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    I still have full functionality.
  8. Jul 1, 2023 at 6:09 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    One of the features of the maestro is to specifically maintain the steering wheel controls. But you have to program the unit prior to install. I installed an alpine hall unit and the maestro and maintained the steering wheel controls and have had zero problems
  9. Jul 1, 2023 at 7:56 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I’d be a little nervous using a professional installer that doesn’t know how to program a maestro. Took me all of 5 minutes to figure out how to program it. I could be wrong but it makes me think he doesn’t know what he’s doing or is too lazy to do it right.
  10. Jul 1, 2023 at 8:07 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    So maybe he realized he needs to
    Undo some of the work to fix programming HU issues and doesn't want to be bothered? So trying to get you buy that this is the best you'll get.
  11. Jul 1, 2023 at 11:02 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    No professional should have issues programming the Maestro.
  12. Jul 1, 2023 at 12:30 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
