  1. Oct 3, 2023 at 1:29 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Can you imagine all the important information you've had to eradicate to make room for things like, wheel back-spacing?
    Might just try to trust 4WP, they have some specials right now and have a store in town.
  2. Oct 3, 2023 at 3:32 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    changed my rear diff fluid today. easy peasy
    can anyone tell me what this date represents. it's for next year... is that when fluid needs to be changed (there's no record of this fluid being change). I bought this truck a few weeks ago and just going through everything right now.
    also... when changing the front diff fluid... should i order new fill/drain plugs and gaskets? they look original, but not terrible.
    thanks guys!
    also i'm not sure if that darker metal is a leak... it's definitely smells like oil... but it's not recent. almost like the person who previously changed the fluid made a mess and didn't clean it.
    Voss, -Woodsman-, oscardog86 and 2 others like this.
  3. Oct 3, 2023 at 3:55 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    That’s where it goes! Thank y’all!
    NUDRAT and BubbaW[QUOTED] like this.
  4. Oct 3, 2023 at 4:50 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I would think that’s a year/month/day format.
  5. Oct 3, 2023 at 5:17 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Went out and disconnected the battery just now. Getting ready to remove my OEM air bag and install the Sienna cover I found along with steering controls. Hopefully the wiring is already there. I will move over my airbag inflator to the Sienna cover. I was going to move the bag too but it appears to be riveted to the plastic cover and I don't want to mess with it. I'll just leave the bag as is and install my Tundra inflator behind it.
    NUDRAT likes this.
  6. Oct 3, 2023 at 5:21 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Installed a bedrug drop in mat this weekend. I already love it
    today began installing the pop and lock. Ran out of daylight but all I have to do tomorrow is connect the wires into the kick panel and then go back and tighten all of the wires to the frame. I did find that it was easier to take the wire in through a grommet right at the edge of the driver seat, instead of going around the firewall and back in through the hood latch as they recommended.
    Was relieved to see that the underside of the truck seems to be in very good condition for 17 years old and over 300,000 miles. But I will know more when I get the shocks and lift kit put in in two weeks along with LBJ and timing belt
    The parts should be here this week so I can replace the outer belt weatherstrips on all 4 doors, driver power window motor and regulator, remove and repair/tighten both driver and passenger mirrors that have been rattling.
    also, about to see if I can make the drivers back portion of the seat foam before installing my Durafit seat cover. I’m just gonna break down and order the bottom foam. I already installed the passenger side and am very pleased
    then some work with detailing clay and buffing
    a pretty busy two weeks, but it feels so good to get this truck back in in good shape again
  7. Oct 3, 2023 at 5:24 PM
    shifty` I'm a member of a country club
    On the 'routing wires outside' topic, not sure if it helps, but I wrote out some extra details on how to get wires outside the cab via the floor in this dashcam writeup: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1624#post-3199439
    Galladanb and Weagle[QUOTED] like this.
  8. Oct 3, 2023 at 6:14 PM
    Weagle
    Prattville, AL
    I found that one you mentioned right on the edge of the driver seat. It was a rubber grommet and already had some wires coming through it.
    I think I read where others said there was barely enough wire. Probably a double cab like mine. Anyway coming up right on the edge of the driver seat under the carpet made it much much easier
    shifty`[QUOTED] and Galladanb like this.
  9. Oct 3, 2023 at 6:29 PM
    artsr2002
    'Yonder
    Whelp. My new steering wheel buttons don't come with a connection for the cruise control. My current no buttons setup plugs into the clockspring and the cruise control stalk with a ground pigtail for the horn. The buttons harness connects from the clockspring connnector to the left side buttons module and the ground pigtail for the horn but no connector to go to the cruise control module. My buttons came with spare wires. Can I install the missing white wire for the cruise into the empty slot on the clockspring connector and just splice the ground wire with the existing ground wire in the connector? Is that all that goes to the cruise control module just a positive and a negative wire? It only has 2 wires going to it's connnector. I e attached a pic of the current harness and the new one.
    -Woodsman- likes this.
  10. Oct 3, 2023 at 6:36 PM
    artsr2002
    'Yonder
    My current connector only has the circled 3 wires. Blue goes to the ground plug of the horn and black I assume is the ground going to the cruise control plug. The empty spot in the middle should be a white white gray wire going to the cruise control plug.
  11. Oct 3, 2023 at 7:34 PM
    Toyoda Tundra
    New Aisin Timing belt kit done a few days ago. Cleaned throttle body, oil change and air filter coming soon.
  12. Oct 3, 2023 at 7:59 PM
    dirtnsmores
    Southern CA
    Which bedrug did you order and how much? I couldnt find one for our double cabs
    Weagle[QUOTED] likes this.
  13. Oct 3, 2023 at 7:59 PM
    dirtnsmores
    Southern CA
    Yup you're right. Thanks!
    PenderBen[QUOTED] likes this.
  14. Oct 3, 2023 at 8:08 PM
    artsr2002
    'Yonder
    Sitrep.....the airbag is back in the truck along with the buttons. I spliced the cruise control connector back in and took the truck for a spin. Cruise works as usual. The wheel buttons are not backlit. Guess I didn't check the AliExpress listing close enough. Lol.
    Next step is to get the adapter to interface them to the aftermarket Kenwood head unit I'm using. Recommendations of which cheap unit to grab?
    Axxess? Metra? Other?
    I have also included a pic of the plug in the underside of the clockspring I hope I don't need to run additional wires. Lol.
  15. Oct 3, 2023 at 8:10 PM
    Weagle
    Prattville, AL
    It is the universal drop in. You have to cut it. enough left to cover the tailgate if desired.
    Ordered it from realtruck and it was here in 2 days
    dirtnsmores[QUOTED] likes this.
  16. Oct 3, 2023 at 8:13 PM
    dirtnsmores
    Southern CA
    Was it hard to cut and get it to fit correctly? I'll be ordering in the next few months!
  17. Oct 3, 2023 at 8:18 PM
    artsr2002
    'Yonder
    It appears that perhaps my clockspring doesn't have all the necessary wiring in it. Also I found another thread where clearly I am missing 3 additional wires in the bottom clockspring connector that run to the plug at the back of the factory head unit. Doh! This may become mighty expensive if I have to get another clockspring. If that's the case I'll just revert to the JBL Click as my steering wheel controls. Lol.
  18. Oct 3, 2023 at 9:17 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If you want backlit I may have the extra set still. Just pay shipping.
    Hmmm. I thought the 05 & 06 came pre-wired for controls. Maybe it's a DC thing?
  19. Oct 3, 2023 at 9:22 PM
    artsr2002
    'Yonder
    Assasin send them my way. Pm me please. Also I found another thread with the attached pic which shows the 4 wires my DC doesn't currently have.
  20. Oct 3, 2023 at 9:24 PM
    artsr2002
    'Yonder
    I didn't unplug the connector but I bet the clockspring has the wires in I'm just needing to add the wires to my connector and run them to the back of the head unit.
  21. Oct 3, 2023 at 9:26 PM
    Weagle
    Prattville, AL
    I tried a few different blades, but just a good utility knife with a sharp blade ended up being the best.
    it turned out well. I went overly conservative on the trimming so I could get a little practice,
    and just trimmed more often until I got it right.
    so there was plenty for me to experiment and still fully cover the truck bed edge to edge, and the tailgate
  22. Oct 3, 2023 at 9:38 PM
    dirtnsmores
    Southern CA
    Did it also get the sides of the bed or just the bottom?
  23. Oct 3, 2023 at 9:43 PM
    Weagle
    Prattville, AL
    Just the bottom. I don’t believe it would’ve made it but about halfway up at best on each side
  24. Oct 3, 2023 at 10:08 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Here's what I've got for you:
    4runner buttons/circuit board (orange backlit)
    Grey housing
    OEM harness
    4 extra pins which I think are the right ones for your housing.
    The other side had no buttons, so I didn't snag it at the yard. I think thats a land cruiser option to get all of them.
    NUDRAT likes this.
  25. Oct 3, 2023 at 10:12 PM
    artsr2002
    'Yonder
    Sweet. Thanks.
  26. Oct 4, 2023 at 5:48 AM
    I recommend the Axxess ASWC-1 control unit, and also buy the Metra 70-8114 harness to make its install plug-and-play. It's a no-brainer.
    artsr2002[QUOTED] likes this.
  27. Oct 4, 2023 at 10:11 AM
    -Woodsman-
    -Woodsman- New Member
    NC
    05 SR5 DC Tundra 4WD
    Window tint. Had them match the back windows.
    sportbike37, txagg, 805Tundra and 9 others like this.
  28. Oct 4, 2023 at 11:31 AM
    dirtnsmores likes this.
  29. Oct 4, 2023 at 11:59 AM
    Just a slangin ..... slaaaangin'.....
    I need to get this wiped up, diff drop in to see if it helps, and some Norma 100-120mm clamps to re-clamp these jokers if the drop doesn't help...
    Voss, TX-TRD1stGEN, abcinv and 3 others like this.
  30. Oct 4, 2023 at 12:03 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
