SOLD: ScanGauge II
Discussion in 'Marketplace' started by OverSquareEng, Dec 2, 2023.
Thread Status:
Not open for further replies.
  1. Dec 2, 2023 at 6:11 PM
    OverSquareEng
    OverSquareEng [OP] New Member
    2006 Sequoia Limited 4WD
    ***SOLD***
    Selling my ScanGauge II, bought it new, have had it for about a year. Everything works great and even comes preprogrammed for 05+ first gens for trans pan temp, trans converter temp, trans converter lock up status, and gear position.
    ***SOLD***
    455h0le_dachshund likes this.
  2. Dec 14, 2023 at 8:47 PM
    OverSquareEng
    Lowered from $80 to $60.
  3. Dec 19, 2023 at 1:18 PM
    OverSquareEng
    Sold locally
    The Black Mamba likes this.
  4. Dec 19, 2023 at 1:27 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Curious, did you replace it with something you found that you like better?
  5. Dec 19, 2023 at 1:29 PM
    455h0le_dachshund
    455h0le_dachshund Human tongue feels aluminum plate, it's a missile
    Reverend Hotdog
    TX...big surprise
    Do you still have the x-gauges available for those things? Mine is just the trans pan temp, I think.
  6. Dec 19, 2023 at 1:30 PM
    OverSquareEng
    Do you have an 05+ 1st gen?
  7. Dec 19, 2023 at 1:31 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yes
  8. Dec 19, 2023 at 1:34 PM
    OverSquareEng
    Cool, let me know if they work for you. They were working on my 2006 Sequoia.
    Transmission Fluid Temp - Pan(F)
    TXD: 07E021D9
    RXF: 032100000000
    RXD: 1808
    MTH: 00090005FFD8
    Trans Fluid Temp - Torque Converter (F)
    TXD: 07E021D9
    RXF: 032100000000
    RXD: 2808
    MTH: 00090005FFD8
    Torque Converter Lockup (On/Off)
    TXD: 07E021DA
    RXF: 046125DA0000
    RXD: 2901
    MTH: 000100010000
    Gear Position (1, 2, 3, 4, 5)
    TXD: 07E021DA
    RXF: 046105DA8000
    RXD: 2C04
    MTH: 000100010000
  9. Dec 19, 2023 at 1:38 PM
    OverSquareEng
    Yeah, check it out:
    https://www.tundras.com/threads/ios-obd-trans-temp-monitoring-solutions.131276/page-2#post-3374208
    Mainly went this direction for a larger screen and the ability to swap between multiple pre-setup screens.
    Downside is that I can't figure out how to get torque converter lockup status and gear position to display on either app. But ultimately those aren't super critical for my use-case.
  10. Dec 19, 2023 at 1:51 PM
    The Black Mamba
    DFW
    Imma keep it stock
    I remember that thread. I quite following it a few months ago:( I'm a bad member
Thread Status:
