ALCON BBK
Discussion in 'Deals & Group Buys' started by 19PlatinumCrew, Feb 7, 2024.
  1. Mar 9, 2024 at 4:42 AM
    #121
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Rey you have a source for the spacer if anyone is interested...thanks
  2. Mar 9, 2024 at 4:44 AM
    #122
    19PlatinumCrew
    Dave
    GROUP BUY FOR ALCONS ENDS 3-15-24 @ 9:00
  3. Mar 9, 2024 at 6:51 AM
    #123
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I do not but I’ll do some digging. Shop buddy had them laying around.
  4. Mar 9, 2024 at 6:56 AM
    #124
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    @snivilous we need some dust shield spacers made for all these big brake kit folks
  5. Mar 14, 2024 at 11:10 AM
    #125
    19PlatinumCrew
    Dave
    Allright everyone this GB is over tomorrow at 9:00 Eastern Time if your gonna pony up today is it...mine came in today
    reywcms likes this.
  6. Mar 14, 2024 at 11:14 AM
    #126
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    my rears showed up last week. May try and install them tomorrow if I have time before our trail run Saturday
  7. Mar 14, 2024 at 12:58 PM
    #127
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Fatty…
    reywcms[QUOTED] likes this.
  8. Mar 14, 2024 at 4:11 PM
    #128
    19PlatinumCrew
    Dave
    I probably can't keep up with you Ray but I'll be able to stop as well
  9. Mar 14, 2024 at 5:48 PM
    #129
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    One rear done. Will wrap up tomorrow then bed these suckers in
  10. Mar 15, 2024 at 4:13 AM
    #130
    19PlatinumCrew
    Dave
    Rey did you change to a different brake fluid, if so did you drain the system
  11. Mar 15, 2024 at 5:42 AM
    #131
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes I went with amsoil dominator fluid. I have a pressure bleed system from agm products makes swapping the fluid out easy. The cap needed for the Toyota reservoir took a while to come in from the other vendor I sourced it from.
    https://agm-products.com/collections/tools/products/brake-pressure-bleeder
    bulldog93 and texasrho83 like this.
  12. Mar 15, 2024 at 8:41 AM
    #132
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Incase people don’t think you need the rears. Here’s the difference in size. Yes absolutely get the full kit.
    bulldog93 and SAGE63 like this.
  13. Mar 15, 2024 at 8:59 AM
    #133
    Chad D.
    Chad D. New Member
    Western Oregon
    They’re just like brakes, but bigger!
    My man, you will love that setup.
  14. Mar 15, 2024 at 9:01 AM
    #134
    Chad D.
    Chad D. New Member
    Western Oregon
    Getting a little off topic, but can’t we also use Techstream to power bleed our brakes via the ABS stuff? I haven’t tried it, but believe it’s a thing.
  15. Mar 15, 2024 at 1:30 PM
    #135
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Not sure haven’t heard that.
    coTony likes this.
  16. Mar 15, 2024 at 1:31 PM
    #136
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Ok. Can confirm the rears make a significant difference in performance than only running the front.
    SAGE63 and coTony like this.
  17. Mar 15, 2024 at 2:09 PM
    #137
    coTony
    Tony
    Sun Lakes, AZ
  18. Mar 15, 2024 at 4:06 PM
    #138
    19PlatinumCrew
    Dave
    Well if you missed this Group Buy keep an eye out for Possibly another one later in the year......thanks everyone that took advantage of the 15% off.....
    stuckinohio, SAGE63 and reywcms like this.
  19. Mar 15, 2024 at 4:55 PM
    #139
    SAGE63
    San Diego County
    Wow!
  20. Mar 15, 2024 at 5:09 PM
    #140
    SAGE63
    San Diego County
    Just saw this GB... damn nice...
    I just recieved my T2S Parker raffle prize of the Stillen Rotors and brake pads.
    but just wow...
  21. Mar 16, 2024 at 4:18 AM
    #141
    19PlatinumCrew
    Dave
    This Group Buy is OVER.....CLOSED
    coTony likes this.
  22. Mar 25, 2024 at 12:59 PM
    #142
    Warren-RB
    Warren-RB New Member
    Looks like you have a rear drum parking brake, why you need this fatty wheel spacer?
  23. Mar 25, 2024 at 1:01 PM
    #143
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    For the fatty rear shock clearance during articulation.
  24. Mar 25, 2024 at 1:04 PM
    #144
    Warren-RB
    Thanks and it's a good precaution. Do you have to do the front as well?
  25. Mar 25, 2024 at 1:05 PM
    #145
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Negative not needed on the front since the control arms are pushed out wider. Once I move to a custom fabricated rear end we will make it wider to not need the spacer.
  26. May 5, 2024 at 8:33 AM
    #146
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    How is the pedal feel compared to stock with the full kit?
    I’m guessing it would cause a longer softer pedal based on piston size, but I haven’t done all the math to check.
    I completely missed this group buy, but I’d be down for a full set if another group buy happens.
  27. May 5, 2024 at 8:52 AM
    #147
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Pedal feels great
  28. May 5, 2024 at 10:00 AM
    #148
    Chad D.
    Chad D. New Member
    Western Oregon
    Agreed. Pedal is much firmer (less squish) than stock. I drove a friend’s 2017 last weekend and had forgot how much of a difference there is…. Felt like I was putting his pedal all the way to the floor.
  29. Jun 16, 2024 at 12:20 PM
    #149
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Hey all. If anyone kept their takeoff and are interested in selling them I am interested. I cannot put on BBK with 18 inch wheels so I am going to dress up the stocks when I put on my new rotors, pads and braided brake lines. Having a set that I can dress ahead of time will save a ton of time. So, if interested in selling please let me know. Another option would be to grab yours and give you mine when I get them off the truck if you wanted a stock set. I am in the Houston area. Thank you!
  30. Jun 16, 2024 at 12:27 PM
    #150
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Why can’t you run BBK with 18s?
