Sensor replacement
Discussion in '1st Gen Tundras (2000-2006)' started by TommyII Tundra, Mar 27, 2024.
  1. Mar 27, 2024 at 3:19 PM
    TommyII Tundra
    TommyII Tundra [OP] New Member
    Harry
    2000 Tundra
    The check engine light came on and the parts store said it was PO155 code - bank 2, sensor 1.
    It is a 2000 Tundra 4.7. Is it hard to replace? Looks like it is under the manifold.
  2. Mar 27, 2024 at 3:32 PM
    It’s on the underside of the exhaust manifold. You can see it if you crawl underneath. Not hard but you need the right hardware to do it. I use a 2ft flex head 1/2” drive ratchet with a special O2 socket to accommodate the wiring. Need to spray it down with rust penetrant for a few days and then attack it by going back and forth with the ratchet to break any rust bond.
  3. Mar 27, 2024 at 3:49 PM
    shifty` Kill another whale with your power
    Couple things:
    • Only use Denso brand parts - this is one of those sensitive sensors that you should use the OE part to replace
    • Only use the Denso "Exact Fit" part, not the universal; you don't want to cut the harness for any reason
    • DO NOT buy the part off scAmazon, fleaBay, or any other vendor who has little or zero control of their supply chain, there are counterfeits on the market (Summit Racing, RockAuto are great options, often cheaper)
    • Ideally, replace the upstreadm and downstream sensor on the affected bank (i.e. passenger side is bank 2) to avoid other issues
    You can look up the correct sensor part numbers at www.densoautoparts.com
    Or if you give more details about your truck (i.e. V8, I assume? Is it 2WD or 4WD? What trim level?) I'm happy to pull part numbers for you.
    bfunke likes this.
  4. Mar 27, 2024 at 5:15 PM
    bfunke
    bfunke Tundra Curmudgeon
    +1 what Shifty’ said - no exceptions. Get the correct socket makes the job easier.
  5. Mar 28, 2024 at 9:18 AM
    TommyII Tundra
    Harry
    2000 Tundra
    The parts guy said it was on the top of the engine but he was wrong as it is where you guys say it is. The downstream one was just replaced by a shop. It is a 4wd SR5, 4.7. Where do you get the socket? Around here the shop repair rates have gone through the roof. If possible you have to do the work yourself.
  6. Mar 28, 2024 at 9:31 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Local auto parts stores will rent the tool to you. They give your money back when you return it.
  7. Mar 28, 2024 at 10:56 AM
    Tekton makes a solid one. Search for: Tekton Oxygen Sensor Socket
    Make sure you get the correct size.
  8. Mar 28, 2024 at 12:20 PM
    TommyII Tundra
    Harry
    2000 Tundra
    Do you have the part #? It is a 2000 4wd SR5, 4.7.
  9. Mar 28, 2024 at 12:27 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
