Cats or no cats on my 03 2UZ? (Poll)
Discussion in '1st Gen Tundras (2000-2006)' started by 455h0le_dachshund, Jun 28, 2024.
To cat or not to cat?
  1. Chop em
    37.5%
  2. Keep em
    62.5%
  1. Jun 28, 2024 at 6:22 PM
    455h0le_dachshund
    455h0le_dachshund [OP] Human tongue feels aluminum plate, it's a missile
    Reverend Hotdog
    TX...big surprise
    So I recently scored a used URD o2 simulator that has solved my several years long PO420/PO430 issue.
    Technically my 03 will need to pass TX emissions inspection until Jan 2027. But I'm seriously considering chopping the cats off and straight piping from the JBA long tubes into the TRD catback. I'm wanting a little more power and sound. I already removed the resonator.
    TX doesn't do a sniffer test. Just plugs into the OBD2. So the o2 sim should pass inspection. My mechanic doesn't do a visual inspection and honestly doesn't give a shit lol. He's the one that recommended I tried the o2 spacers. Anyways...
    Whatcha think?
    :sawzall::welder::burnrubber:
  2. Jun 28, 2024 at 6:35 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I'm not taking any legal responsibility from what happens......
    do it.
  3. Jun 28, 2024 at 6:38 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  4. Jun 28, 2024 at 6:38 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  5. Jun 28, 2024 at 6:44 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I doubt theres much gain removing the high flow cats. Maybe at 7500rpm, but not below 5k.
  6. Jun 28, 2024 at 6:57 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Might be worth it for the extra rumble noises
  7. Jun 28, 2024 at 7:03 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  8. Jun 28, 2024 at 7:28 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Anybody have any real world experiences with straight pipes on a 2uz?
    By that I mean straight pipes where the cats should be.
  9. Jun 28, 2024 at 7:52 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    You know those loud af chevy trucks that sound great at idle (if you like a choppy cam) but sound like dogshit the rest of the time?
    i bet that how straight pipes would be on a 2uz. Decent at idle & full throttle, but garbage in between. Needs 11:1 compression & a cam rowdy enough to need new valve springs.
    whodatschrome likes this.
  10. Jun 28, 2024 at 8:11 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    To clarify I just meant straight pipes where the cats should be, but with a muffler.
    Are you referring to just straight pipes?
    I've heard a few trucks with no muffler and they sound terrible, IMHO.
    My buddy had an 01 tundra with the stock exhaust chopped after the resonator and a turn down pipe. Sounded like dog shit IMHO.
  11. Jun 28, 2024 at 8:12 PM
    If you want to go that route, hollow them out instead. Not exactly legal but much less likely to get caught since an inspector only needs to look under the vehicle to see if they exist.
  12. Jun 28, 2024 at 8:27 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    If they were the old OEM cats that were failing, that would be ideal. But since my mechanic DGAF (as mentioned, he recommended I tried the o2 spacers to beat the inspection computer) he doesn't care about the visual inspection. Just gotta trick the state computer.
    Anyways, since these cats are new, if I remove em, I'm scrapping em for some $, or keeping em just just incase, until Jan 2027, then scrapping em.
  13. Jun 28, 2024 at 8:51 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Plus if anyone looks under they'll see the o2 sim and the o2 spacers anyways.
  14. Jun 28, 2024 at 9:00 PM
    Do they really stand out?
  15. Jun 28, 2024 at 9:12 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Don't worry, this was just a testing phase.
    I went back and zip tied the box to the top of the transmission cross member and sucked up most of the slack in the wiring harness.
  16. Jun 28, 2024 at 9:29 PM
    It doesn’t make sense why they would do it there when it could be done in the dash.
  17. Jun 28, 2024 at 9:52 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I’d be tempted to leave the cats, even though you’re truck is a “dedicated offroad only vehicle”. The cats can still do their job, and it’s not like our stock 4.7 engines produce enough HP to gain any perceivable power gain by deleting them.
    HBTundra likes this.
  18. Jun 28, 2024 at 10:01 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Holes in the hood.
  19. Jun 28, 2024 at 10:07 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    :notsure:
    This one's not the off roader. This one is the lowered street queen. Goals are to make it faster.
    Eventually I want to do a remote mount turbo, cams, and 05-06 intake manifold.
    4.10's and new LSD this August. Maybe do the manifold then too.
    Probably do the GX brakes as well.
  20. Jun 29, 2024 at 2:32 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Leave cat. When you go turbo ditch them. Fi hates backpressue until then any potentisl fine is not worth it. Will u make more powervw/o them....yes. but. I would not risk it. Just my .02.
  21. Jun 29, 2024 at 3:17 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  22. Jun 29, 2024 at 4:15 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  23. Jun 29, 2024 at 5:21 AM
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Good on the clean up of the wiring... knew you could do better :rofl:
    Looking at the poll... Your cutting them anyway aren't you :cool::D
    455h0le_dachshund[OP] likes this.
  24. Jun 29, 2024 at 5:25 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Haha undecided at this time.
  25. Jun 29, 2024 at 5:41 AM
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    Cut em after the turbo adding project post 2027 to keep you and your mechanics noses clean. All fun and games till the ticket books come out.
    BroHon and 455h0le_dachshund[OP] like this.
  26. Jun 29, 2024 at 7:09 AM
    Tripleconpanna
    See attached videos....
    :popcorn:
  27. Jun 29, 2024 at 7:15 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I was at work before. But now I heard em, those sound terrible.
  28. Jun 29, 2024 at 7:57 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    When I replaced the entire exhaust on our Civic I accidentally purchased the SoundFX versions of resonator AND muffler. (might have been the cheapest?)
    When you open it up it sounds like i'm driving some teenagers hoopty rice burner. :facepalm::anonymous:
  29. Jun 29, 2024 at 8:27 AM
    Tripleconpanna
    Do it... :devil:
  30. Jun 29, 2024 at 8:53 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'm thinking about running a fat pipe & resonated tip.
    need to cut off and rehang the hangers, and make an adapter cone.
    shifty` and Tripleconpanna like this.
