Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Jun 29, 2024 at 11:19 AM
    #2401
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    How did you secure the Mekede unit into the opening?
  2. Jun 30, 2024 at 12:37 PM
    #2402
    tdiantonio
    tdiantonio New Member
    This is still very much a work in progress..
    I used the baffle Mekede sent me with the plug and play harness I bought from them. The baffle is pretty much the same as the one in the link below. I think its for the 9" to 10.2" version of the android units. If you look closely there are 4 holes on the inside track of the baffle. They lined up with 4 mounting points on the Mekede unit. I secured the unit to the baffle using M3 x35mm machine screws. They were a bit too long and I ended using using some nuts for spacers. I would try using the M3x30mm screws to see if they work better.
    Here is a link to the screw I used; https://www.amazon.com/dp/B08R8HPKTV?ref=ppx_yo2ov_dt_b_product_details&th=1
    Here is a link to the baffle they sent me: https://www.amazon.com/Toyota-Tundra-2014-2020-Installation-Mounting
    I am still working on a way to use the factory radio brackets to mount this. The radio chassis is not a normal single or double din size. There is no easy way to secure it to anything other than the baffle unless you fabricate a custom mounting bracket. The radio will sit on top of the baffle.
    The baffle itself is just ok. It has a slight curve in it to match contour of the center stack. It does have the factory mounting tabs in the upper corners and they fit right into the oem mounts for them. However, the bottom of the baffle leaves a lot to be desired. It has the two mounting points at the bottom which allow the mounting tabs in from the heater controls, but there is no mounting support along the rest of the bottom. If you look at the mounting kit from Dasita (link here) as well as other aftermarket kits..you see support along the entire bottom of the baffle. This is very important!! Without this...the weight of the radio and baffle slightly pushes out the heater controls and you can see a small gap where they meet. Once you notice this...you will always notice this. There is a slight sag and I found myself wanting to push it in more every time I noticed it. I think its only a matter of time before it would sag in the middle too.
    If you look at the Dasita 10.2" radio for our trucks, you will also see the mounting support across the entire bottom of the radio.
    I am working a much longer thread about this that I will publish once I get everything sorted. Feel free to DM me in the meantime.
    purplenova[QUOTED] likes this.
  3. Jun 30, 2024 at 12:51 PM
    #2403
    purplenova
    Tom
    Ohio
    I'm still waiting on them to verify it will fit my 2016 SR5. I'm looking at the 10 inch m7 plus with 6gb ram.
  4. Jul 1, 2024 at 2:19 PM
    #2404
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    Just installed my G12 in my 2011 tundra Sr5. Pretty straight forward and its a massive upgrade.
    Here's where im struggling. Should i use my factory camera that in the tailgate? Its going to the mirror currently.
    Heres my thoughts, I heard that the resolution is cropped and made to fit the mirror and if you send the signal to the head unit it could get grainy on the picture.
    Its also presenting some challenges if i am to go that route.
    Option1 (using Factory camera)I'd have to bounce the voltage down in the mirror and identify the correct wires and i dont have a video source tester. I followed a great video where this was done using a voltage meter and the product they used to change to 9volts i did purchase but not sure how to run/connect it. Then i would have to tap in and use a RCA video style and go into the a pillar to the back of the head unit.
    https://youtu.be/iIZZAtEcBqk?si=pCQehXn2M2TocDDT
    Option 2( buying after market camera) buying an aftermarker camera would insure an easy wiring straight from the back and to the head unit. Ive identified where i can tap into the reverse wire so thats good, but id still have to tap into the mirror because after removing factory camera its going to send blank data to that screen in the mirror and i dont want an error or blue/ black screen.
    Any thoughts on the wiring?
    This is what i bought: Red Wolf Step down.
    https://www.amazon.com/dp/B0945X9JHK?ref=ppx_yo2ov_dt_b_product_detailsdasaita.jpg
  5. Jul 1, 2024 at 2:36 PM
    #2405
    purplenova
    Tom
    Ohio
    Is your G12 an in dash unit or floating?
  6. Jul 1, 2024 at 2:40 PM
    #2406
    hotchops777
    Matthew
    EAST TEXAS
    Its in the dash..
  7. Jul 3, 2024 at 7:52 AM
    #2407
    purplenova
    Tom
    Ohio
    Alright Dasaita fans - i need your input.
    For about a month now, since i attempted the Phoenix Automotive upgrade, that cost me $250 to fail - LOL
    I've been reading almost everything i could find on Dasaita, Joying, Mekede and Atoto. Now my head hurts...
    Dasaita has won out and i hope its a win after all said and done.
    Have narrowed down the choices to these two Dasaita units.
    1. 10.2 G12 - Android 12/13 - 6g/64g ram/rom (option for 8/256) - Qualcomm 665 cpu - LINK
    more of a factory fit - radio frame has tabs for lower heater control snap in.
    Price $634.60
    2. 11.6 G12 - Android 12 - 6g/64g ram/rom (option for 8/256) -qualcomm 665 cpu - LINK
    floating screen may need different dash kit it one provided does not support lower heater control correctly.
    Price $597.55
    Does the 6g of ram propose any performace issues or would that be adequate?
    I think more is always better, but at what point is it excess?
    Looks like everything is identical except for the screen size and price.
    Anything else i should consider, just to muddy the waters more - LOL
    Just found this - appears the GPS antenna plug on both Dasaita's use something
    call a FAKRA plug (whatever that is) so a different adapter is required.
    This is supposed to work to convert Toyota oem to FAKRA
    https://www.discountcarstereo.com/xms-toy.html
    mart1nezdaniel and Newmanater90 like this.
  8. Jul 11, 2024 at 10:27 AM
    #2408
    Newmanater90
    Newmanater90 New Member
    Mark
    2017 Toyota Tundra
    I just ordered your 1st option. the 10.2 G12. I only had one option for the storage size which was the 8G/256.
    I have seen bad reviews about the microphone so I'm seeing if there's an alternative.
  9. Jul 11, 2024 at 10:44 AM
    #2409
    purplenova
    Tom
    Ohio
    im about to order mine as well. Have been going back and forth with Joying on what they claim fits and what doesnt.
    Even though Dasaita is a little more expensive, probably a better unit overall even though specs seems to be the same
    Newmanater90 likes this.
  10. Jul 11, 2024 at 10:51 AM
    #2410
    purplenova
    Tom
    Ohio
    Had to go find this as i read it late last week. Not a direct answer to your question but what one person did to fix the same issue.
    https://www.dasaita.com/community/forum/topic/122067/microphone-background-noise
    On page 3, there is talk about firm ware update to fix the noise.
    Newmanater90[QUOTED] likes this.
  11. Jul 15, 2024 at 11:53 AM
    #2411
    purplenova
    Tom
    Ohio
    You get the G12 installed yet?
  12. Jul 15, 2024 at 12:09 PM
    #2412
    Newmanater90
    Mark
    2017 Toyota Tundra
    No It's still being shipped still. Hopefully by the end of the month. I'm up in Canada and our Polar Bear delivery animals are a bit slow this time of year!
  13. Jul 15, 2024 at 12:10 PM
    #2413
    purplenova
    Tom
    Ohio
    You said Polar Bear Delivery...
  14. Jul 16, 2024 at 2:38 AM
    #2414
    purplenova
    Tom
    Ohio
    They finally got around to answering my question.
    This was their response.
    MekedeTech Mekede M6 Pro Android 13 Car Raido with HDMI in 1280 * 720 IPS 9 inch Touch Screen for Toyota Tundra Sequoia 2014-2018,Bluetooth 5.1 Octa Core 8+128G Head Unit Dash Kit https://www.amazon.com/dp/B0D9K2SYPC
  15. Jul 16, 2024 at 12:23 PM
    #2415
    GoJo
    GoJo New Member
    UTAH
    2019 Tundra SR5 CM Silver Sky
    I just put in for https://www.amazon.com/dp/B0CLY8CJ6W?th=1
    I too read about the microphone issues, but it seemed to be the built in one on the unit itself and not the external plug into the back and route up to the dash somewhere one. Should be here Thursday for me, and hopefully install this weekend, I'm kicking around ideas of where to route the external one. I have seen others utilize their stock location up in the headliner, but not sure if the wiring is going to be long enough to accommodate out of the box or if I will have to modify.
  16. Jul 16, 2024 at 12:36 PM
    #2416
    purplenova
    Tom
    Ohio
    After you get it installed, download the following onto it and see what Android version it shows.
    https://play.google.com/store/apps/details?id=com.finalwire.aida64
    GoJo[QUOTED] likes this.
  17. Jul 16, 2024 at 12:52 PM
    #2417
    GoJo
    GoJo New Member
    UTAH
    Will do, I saved that link you sent above too as well in case I run into similar microphone road noise issues. I hardly make/receive calls whilst driving anyway so it wasn't a huge concern for me when I read about it.
  18. Jul 18, 2024 at 1:01 PM
    #2418
    purplenova
    Tom
    Ohio
    Just jumped on the Dasaita bandwagon.
    Just ordered this unit
    Little expensive but, had all the options i wanted so why not.
    Hopefully the sound quality for the mic isnt as bad as some say.
    Probably going to need this adapter to retain factory GPS antenna
    GELCW and GoJo like this.
  19. Jul 18, 2024 at 1:16 PM
    #2419
    GoJo
    GoJo New Member
    UTAH
    Same as mine it looks like! Mine should be here today, I'm just patiently waiting...
  20. Jul 18, 2024 at 1:17 PM
    #2420
    purplenova
    Tom
    Ohio
    Keep me in the loop. Interesting to see how easy the install will be
  21. Jul 18, 2024 at 1:22 PM
    #2421
    GoJo
    GoJo New Member
    UTAH
    "should" be fairly easier from the reviews/videos I have seen, just so trim tools needed and 10mm. It all seems plug and play from there, minus the factor GPS antenna cable if you want to keep factory GPS. Ill probably run it with the new HU's and see how well it does first (I forgot about that initially until you posted up)
  22. Jul 18, 2024 at 1:24 PM
    #2422
    purplenova
    Tom
    Ohio
    I just ordered that fakra harness i posted a link for. Hopefully it works as designed. One less cable to worry about.
  23. Jul 18, 2024 at 7:57 PM
    #2423
    GoJo
    GoJo New Member
    UTAH
    Its in! All working well, except the microphone... doesn't seem to be picking up anything, tried both the onboard and external microphone. I haven't yet checked the firmware but will do that tomorrow and resume troubleshooting. As for GPS on the unit, it seems to work ok even with me mounting the antenna directly to the top of the unit and stuff it back into place. Ill be using Android Auto for most everything anyway so navigation should be pulling from my phone at that point.
    BR73 and purplenova like this.
  24. Jul 18, 2024 at 8:08 PM
    #2424
    purplenova
    Tom
    Ohio
    See if this helps
    https://youtu.be/HlLfsiywiIs?si=EyqSQBDYH_Afg7Ub
  25. Jul 19, 2024 at 9:32 AM
    #2425
    GoJo
    GoJo New Member
    UTAH
  26. Jul 19, 2024 at 9:34 AM
    #2426
    purplenova
    Tom
    Ohio
    That's good to hear because I'm gonna have to do the same.
  27. Jul 19, 2024 at 9:40 AM
    #2427
    GoJo
    GoJo New Member
    UTAH
    Yea I am liking it so far, still need to tinker around with it. Fits extremely well in the dash, like it was suppose to be there! Wife is coming around to possibly getting one for herself in the Rav4 now too :p
  28. Jul 19, 2024 at 9:48 AM
    #2428
    purplenova
    Tom
    Ohio
    My wifey also has a RAV... Nice
  29. Jul 23, 2024 at 9:12 AM
    #2429
    GoJo
    GoJo New Member
    UTAH
    Got one for the Rav4 now too.. but due to it being a Limited I had to contact Dasaita to get the proper wiring harness. They were very responsive and will be shipping out a harness this week!
  30. Jul 23, 2024 at 9:24 AM
    #2430
    purplenova
    Tom
    Ohio
    Nice
    Looks like my delivery will be tomorrow, so maybe this weekend install.
