SOB Fabrication is officially a vendor!
Discussion in 'SOB Fabrication' started by STravis, Jun 29, 2024.
  1. Sep 4, 2024 at 2:33 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Tri-Cities, WA
    Damn that's a lot! Well @AMarsh it's a no brainer just order the bumper. You won't be disappointed. :spending:
    STravis[OP] and FrenchToasty like this.
  2. Sep 4, 2024 at 3:24 PM
    AMarsh
    AMarsh New Member
    Andrew
    Central Oregon
    2021 Army Green TRD
    Awesome thanks guys! Definitely a no brainer, just need to talk to my usual shop to see if they'll powdercoat, chop the body, and install it. Welding is outside of my DiY scope :D Unfortunately I recently moved even further away from Travis or I'd have him do it.
    STravis[OP] and CaptRussia253 like this.
  3. Sep 4, 2024 at 3:28 PM
    CaptRussia253
    Ruslan
    Tri-Cities, WA
    I cut it up myself. Never done something like that before. Just take your time and measure 3 times.
    STravis[OP], RobertD and AZBoatHauler like this.
  4. Sep 4, 2024 at 3:45 PM
    AZBoatHauler
    So.Arizona
    This. No welding involved, just a cutoff wheel and some brass balls.
    Toes courtesy of @FrenchToasty
    STravis[OP], helidave, AMarsh and 2 others like this.
  5. Sep 4, 2024 at 3:53 PM
    AMarsh
    AMarsh New Member
    Andrew
    Central Oregon
    2021 Army Green TRD
    Ah, didn't realize it bolted on, thought it was welded. How about the powdercoat? @STravis , can you ship it coated or is that for local installs only?
    Not sure if I have brass balls big enough to trust myself a the straight line. :D
    Anyone here have the back-up sensors? Anything that needs to be done with them other then put them into the new bumper?
    CaptRussia253 and STravis[OP] like this.
  6. Sep 4, 2024 at 4:01 PM
    AZBoatHauler
    So.Arizona
    Just stick the sensors in the holes. It’s way harder getting them out of the OEM bumper than putting them in the new one.
  7. Sep 4, 2024 at 5:26 PM
    STravis
    STravis [OP] SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Nope, just bolted on with the factory bolts. We only powdercoat local stuff so it doesn't get beat up in transit. We've had some stuff show up missing the pallet in the past.
    The cutting is easy, we send some instructions with measurements and it's a pretty straightforward process.
    You do lose the RCTA/blind spot sensors, but it does retain the parking sensors.
    CaptRussia253 likes this.
  8. Sep 4, 2024 at 5:26 PM
    CaptRussia253
    Ruslan
    Tri-Cities, WA
    I sprayed mine with bed liner. Way easier to touch up. As for the sensors, I just removed them. Saved like 1/2 lbs and the truck takes off much quicker. :rofl:
    STravis[OP] and AZBoatHauler like this.
  9. Sep 4, 2024 at 7:50 PM
    rcsbguy
    rcsbguy New Member
    Congrats Travis!
