  1. Oct 25, 2024 at 2:53 AM
    BroHon
    BroHon Everything's clock, is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Exercise drive train, check.
  2. Oct 25, 2024 at 6:27 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Get off the asphalt!
    Jack McCarthy likes this.
  3. Oct 25, 2024 at 6:42 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    It's wet, calm down buck shot.:rofl:
  4. Oct 25, 2024 at 7:13 AM
    455h0le_dachshund
    455h0le_dachshund The older I get, I realize I'll never grow up.
    Dog
    TX...big surprise
    Dragstrip Rocketship
    Awesome handle :cheers:
    No erection! :rofl:
    Tundra2 and BroHon like this.
  5. Oct 25, 2024 at 7:15 AM
    455h0le_dachshund
    Dog
    TX...big surprise
    How well does that oil gauge work?
    Mine sometimes works, but at this point it's rare.
  6. Oct 25, 2024 at 7:52 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    But seriously it works every day. I cleaned the sensor out and where it mounts. That improved it's performance a little. But still reads as expected, low.
  7. Oct 25, 2024 at 7:57 AM
    455h0le_dachshund
    Dog
    TX...big surprise
    I need to do that. But I don't know where to start.
  8. Oct 25, 2024 at 8:00 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Next oil change, after all the oil is drained, unplug the sensor and unscrew it. It's that simple. You can do it np bruh.
  9. Oct 25, 2024 at 8:02 AM
    455h0le_dachshund
    Dog
    TX...big surprise
    Yeah but where is the sensor? On the pan?
  10. Oct 25, 2024 at 8:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Right next to the oil filter
  11. Oct 25, 2024 at 8:03 AM
    455h0le_dachshund
    Dog
    TX...big surprise
    :cheers:
  12. Oct 25, 2024 at 8:05 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Right next to the oil filter on the side of that mount. You've stared right at it if you do your own oil.
    Well... I'm speaking for my 2000AC.
  13. Oct 25, 2024 at 8:33 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Had a few minutes to myself yesterday before my wife and kids got home. I have one of those frame rail spray things that attaches to a garden hose. Used it to rinse out my passenger side frame rail. Will hopefully get the driver side taken care of today. Just prepping to apply fluid film while the weather is still decent.
    G_unit3000, bmf4069, Kimosabe and 2 others like this.
  14. Oct 25, 2024 at 9:06 AM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    What is this frame rail spray thingamabob that you speak of? Pics?
  15. Oct 25, 2024 at 9:51 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Just bought some 6 quarts of Toyota WS ‘gender neutral fluid’ to be politically correct. Plan on doing a drain and fill today while at work helpfully. I’m curious though on two things:
    1. I’ve just swapped out my 2nd bad radiator and I know the trans lines run through it so I’m wondering how much fluid I’ve lost to those two changes or if it’s so minuscule that it doesn’t matter. Will return fluid I don’t use cause it ain’t cheap stuff.
    2. I believe the fsm says to bring trans temp (which should be A/T oil temp #1) on my OBDlink MX+ reader) to 115F before opening check port but even on my drive to work this morning (it was cold at like 35F) the temp only got to like 106F. Would it be higher at idle and switching between Neutral and Drive I assume then?
    G_unit3000, abcinv and bmf4069 like this.
  16. Oct 25, 2024 at 10:04 AM
    bmf4069 Yup, that's a whole ass truck in a dishwasher
    1: I wouldn't worry about it if you got the hoses turned up/capped in time.
    2: just drive around the block in 1st gear around 30mph. That'll warm it up!
    Also, it's called gender fluid fluid. Gah.
  17. Oct 25, 2024 at 10:15 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I knew when buying the cheap Chinese eccentric's it was only a matter of time before they would need attention. Hit some speed bumps hard the day before the MERUS crew started showing up and slipped the two rear adjusters.
    Come to find out the rear china adjusters bottom out on themselves before adequately squeezing the LCA mounts. Torqued to spec I could still spin the adjustment cam with just a little force. Actually amazing they didn't slip any sooner.
    I now have probably 12+ hours into different alignment setups over the last few days. I started with salvaging the original setup based on my paint marks, but was unsatisfied. I knew after playing with it that the original alignment left a little under a degree of caster on the table. ITS MY CASTER AND I NEED IT NOW!
    Used this setup to pull all my numbers
    I never calculated a caster value for the final setup, but based on the previous iterations its somewhere above 2.5
    camber set at -.2
    3/32" total toe.
    Truck drives excellent, and probably the best it ever has. Before I would call it somewhat twitchy and reactive due to the lower caster. Now it's smooth, stable and damn near drives itself.
    This should keep things where I want them until I cut some alignment tabs/plates to take a standard grade 8 bolt.
  18. Oct 25, 2024 at 10:26 AM
    kentuckyMarksman
  19. Oct 25, 2024 at 10:37 AM
    shifty` Light a match to my ass 'cause I'm blowin' up
  20. Oct 25, 2024 at 10:39 AM
    kentuckyMarksman
    My thought was to just flush out anything that might be in the frame rails, let it dry, then shoot fluid film into the holes in the boxed frame rail sections.
    shifty`[QUOTED] likes this.
  21. Oct 25, 2024 at 11:24 AM
    FirstGenVol Brake Czar
    2002 AC
    Yes I do have that exact tool. If you want to borrow it, I'm happy to mail it to you. It's decent. I've only used it once and I think it leaked a little at the base, but it did blow junk out of the box portion of my frame.
    bmf4069 and FrenchToasty like this.
  22. Oct 25, 2024 at 11:28 AM
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
  23. Oct 25, 2024 at 11:39 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Psa if you haven’t cleaned your throttle body and maf lately do it! Truck runs so much smoother mine was filthy. Also replaced sway bar bushings with OEM and the front feels a lot better no more creaky clunk.
  24. Oct 25, 2024 at 1:11 PM
    Outbound
    Aaron
    Northern Alberta
    The old '05 passed provincial inspection today, just needed a foglight bulb and licence plate bulb.
  25. Oct 25, 2024 at 1:51 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I always turn on 4hi in traffic cause it rolls too fast when I left off the brake haha
  26. Oct 25, 2024 at 2:16 PM
    Welcome back to the fray!
  27. Oct 25, 2024 at 3:12 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I had to replace mine as well and tried these LEDs. I've had them in a couple months and they work great. Aliexpress has them for about half the price of AScreenshot_20241025-180741.png mazon
    abcinv and Outbound[QUOTED] like this.
  28. Oct 25, 2024 at 3:57 PM
    tbugnet15
    tbugnet15 New Member
    2001 Access Cab v8 4wd TRD Limited
    Brakes, shocks done. Bed, tailgate back on, bumper and tow hitch too. Drove it around the block for the first time. Rides nice but alignment and a windshield is up next. 5 bulbs need replaced Had to fix the seatbelt buckle and the driver door grab handle. Interior needs seat covers. Body paint will wait till spring
  29. Oct 25, 2024 at 4:10 PM
    455h0le_dachshund
    Dog
    TX...big surprise
    Who are your friends?
    whodatschrome likes this.
  30. Oct 25, 2024 at 4:34 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    These on my truck
