How much is too much
Discussion in 'Towing & Hauling' started by Tundra family, Oct 26, 2024 at 1:53 PM.
  1. Oct 28, 2024 at 3:33 PM
    #91
    AZBoatHauler
    So.Arizona
    Fresh gear oil - I’d probably go 75-140 for extra protection with that load. I’d put fresh coolant in too. Use s4 (or less if needed) on down grade so you don’t overheat the brakes.
  2. Oct 28, 2024 at 3:39 PM
    #92
    Cpl_Punishment
    Cpl_Punishment I'll bet I get blamed for this.
    Rosy
    2020 MGM SR5 CM 4X4
    I guess you're not familiar with the first million mile Tundra that was used for hot shot duty? I believe it routinely had up to 2600 lbs or something like that in the bed.
  3. Oct 28, 2024 at 5:58 PM
    #93
    Ericsopa
    Ericsopa Old man and the sea
    Okay, I'm out.
  4. Oct 28, 2024 at 6:04 PM
    #94
    PermaFrostTRD
    Northern NY
    Only drive it between 1am & 3am to reduce collateral.
  5. Oct 28, 2024 at 6:27 PM
    #95
    Tundra family
    Tundra family [OP] New Member
    My biggest concern is cross winds as 90% will be flat open interstate. Even that shouldn't be too bad, it's pretty compact.
    It will be about 4 inches lower in the bed for travel.
  6. Oct 28, 2024 at 6:47 PM
    #96
    Tundra family
    Heavier than I thought. Still gonna send it :rofl:
    I've removed probably 100 lbs of that worth of water storage and decreased propane capacity. AGM battery probably makes a difference. 1450 is probably about right
  7. Oct 29, 2024 at 4:32 AM
    #97
    2000 Limited TRD AC 4X4 Thunder Grey 272k miles. 2019 Limited TRD CM 4x4 - SOLD
    Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper - Rhino Vortex rack
    Ha, scale it and you’ll find it’s probably closer to that 1600# mark. You’re over payload for sure (by as much as 450# depending on your trim level), potentially over GVWR and rear axle ratings as well. And the weight is up high making for a poor center of gravity. I wouldn’t send it. Probably wouldn’t drive it anywhere faster than 55mph. And wouldn’t drive it much.
    Fobroader and Cpl_Punishment like this.
  8. Oct 29, 2024 at 4:58 AM
    #98
    Tundra family
    Ya, I don't really plan on moving it too much but when I do it'll be covering some distance. I think between what I've taken out of the truck, out of the camper, and my VERY minimal gear we'll all be surprised by the weight. I'm not going to put it on a scale until it's packed and racked and full tanks of gas. Weigh her at her fattest. Lol
  9. Oct 29, 2024 at 5:45 AM
    #99
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    BAK Revolver X4S, APS I-Boards, RC bed mat, AirLift
    Larry, is that you? Big fan.
  10. Oct 29, 2024 at 6:24 AM
    #100
    Tundra family
    Can I borrow that?
  11. Oct 29, 2024 at 6:24 AM
    #101
    BlackNBlu
    Rich
    MN
    Larry the Enticer belongs to the world.
  12. Oct 29, 2024 at 6:34 AM
    #102
    Tundra family
    "Huh never heard of him"
    *Looks up Larry Enticer*
    This guy is my spirit animal. :rofl:
