  1. Nov 1, 2024 at 4:41 PM
    #7621
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
  2. Nov 2, 2024 at 2:34 PM
    #7622
    JayDee
    JayDee New Member
    Replaced the crappy non-JBL 9 speaker system dash corner speakers with some Kenwood eXcelon DFC-X3C coaxial speakers. It's amazing how weak the factory speakers are, they are rated 10W at 8Ω. The Kenwoods are rated 50W RMS/120W peak at 4Ω. I order a pair of harnesses to make installation easy as I would have to otherwise tapped into the very short factory harness in the very corner of the window (Yikes).
    Here's a pic of the new verses factory speaker. What you can't see in this pic is that the magnet on the Kenwood is about 3 times larger on the back of the speaker.
    https://ibb.co/26HtX7V
    I bought this particular speaker because I read in the Audio/Video forum that it fits perfectly in a 2022+ Tundra. Well, that wasn't the case and although the speaker fit the space the bracket was too short and the holes for the mounting screws were about 1/2" off on each side. I fixed this issue by firing up my 3D printer and making a set of bracket extensions for each speaker. Just had to cut the end of the Kenwood bracket to keep it from blocking the new hole locations.
    https://ibb.co/1dWh1Gz
    Although it took quite a bit longer than expected to do the install as I had to design and print the bracket adapters I'm overall very pleased with these speakers. Much more clarity in the high end and mid range of the audio spectrum. It also seems to have boosted the output of the door woofer speakers. I had to adjust back the bass a little. It seems the impedance difference in the corner speakers caused the other speakers to get louder. I still need to either replace or disconnect the center dash speaker as it is still factory and seems to be the exact same speaker that was in the corners. So it looks like the factory non-JBL Tundra 9-speaker system has 3 mid-range speakers in dash and no tweeters.
    RatPanda, thomez and Tundrastruck91 like this.
  3. Nov 2, 2024 at 3:59 PM
    #7623
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Washed and Ceramic coated the baby today. 4 hours. Ouch! Can you say back ache!?! But worth it!
    cartage1, RatPanda, thomez and 3 others like this.
  4. Nov 3, 2024 at 7:06 AM
    #7624
    ramnj
    ramnj New Member
    NJ
    2024 Tundra Platinum
    I installed my ARB the same as yours but all self contained and would like to finish setting it up like yours. Do you have a list of what items you used? Thanks.
    ReCKzX likes this.
  5. Nov 3, 2024 at 8:47 AM
    #7625
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    Threw on a set of 1” wheel spacers to give my pro the little bit of poke it needed. IMG_0384.jpg IMG_0385.jpg
    Paul499, Tundraman479, ytank1 and 3 others like this.
  6. Nov 3, 2024 at 2:17 PM
    #7626
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Cleaned the exteior and took some extra time on the wheels/tires. Tires will be more satin look once I let it sit and then wipe it down. IMG_4562.jpg
    dadrocz, mikev25, vichmr and 2 others like this.
  7. Nov 3, 2024 at 3:55 PM
    #7627
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Started operation inside tailgate drop. After 3 months on back order, I got the button from the new Tacoma for interior tailgate release. Found out which slot it fits in (also has same plug and apparently wired for the backlit LEDs although those are in white). Anyone know what went I to that slot initially? Was it the folding mirrors? Had to be something with a momentary on based on how it’s wired.
    Will need to swap the white LED for a blue one and figure out where in the interior I can tap into for the tailgate release trigger. I tested everything outside the truck by tapping into the tailgate button and it works with the door closed so it should hopefully work out inside.
    Just need to decipher the ultimate wiring diagram a bit because I really don’t want to run a harness from the inside to outside of the vehicle.
    RatPanda and dadrocz like this.
  8. Nov 3, 2024 at 9:40 PM
    #7628
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6
    Love those wheels! Can you please provide details on them along with tire size?
  9. Nov 4, 2024 at 5:07 AM
    #7629
    donny.brooke
    donny.brooke New Member
    2024 TRD Offroad dbl cab Lunar Rock
    Are these the XL or Standard version?
  10. Nov 4, 2024 at 6:38 AM
    #7630
    bobsicle
    bobsicle New Member
    Bob
    Red trd or limited
    Retighten everything with the truck’s full weight on the wheels.
    cartage1 likes this.
  11. Nov 4, 2024 at 9:08 AM
    #7631
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    I know I had seen it somewhere in this thread, but can't find it. Has anyone messed with aftermarket tail lights that are supposed to be sequential, but aren't? I have tried two different "plug-and-play" sets that end up not being sequential. One from Amazon, and one from VLAND. Is there a harness that needs to be added?
    These are the VLAND. Also this morning they started doing the fast blinking, as if a bulb is out. Frustrating.
    maldo012 likes this.
  12. Nov 4, 2024 at 9:41 AM
    #7632
    Foolishfrog
    Foolishfrog New Member
    Mitch
    2024 6.5 Pearl Platinum for towing camper
    So, he queried curiously, how did you apply heat to the shrink in that little space. With my luck, I’d melt the whole thing.
  13. Nov 4, 2024 at 9:42 AM
    #7633
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    heat gun...doesnt take much to get it to shrink
  14. Nov 4, 2024 at 2:41 PM
    #7634
    svcabron
    svcabron New Member
    Added some black tailgate letters to the Stormtrooper.
  15. Nov 5, 2024 at 8:54 AM
    #7635
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    For 80 delivered I put in the black tail pipe cover from Toyota on. Going to go pick up the bed cover tomorrow that I got from the same sale
  16. Nov 5, 2024 at 10:00 AM
    #7636
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    24' Limited 4x4
    I was initially gonna do your same setup haha but made more sense that the air outlet be in the bed. This is the stuff I used to go from the compressor to the bed.
    -ARB Switch/Coupling bracket P/N: 3501050
    -ARB 3 meter SS braided hose P/N: 0740206
    -ARB 90 degree fitting P/N: 0740110
    Optional
    -ARB Coupler P/N: 740112
    -ARB coupler cover P/N: 740113
    Reuse
    -Brass bulkhead fitting
    -Switch
    cartage1, ramnj[QUOTED] and VCheng like this.
  17. Nov 5, 2024 at 2:06 PM
    #7637
    mach1man001
    mach1man001 New Member
    Rob
    2024 Limited Crewmax
    I had my windows tinted. Lol
  18. Nov 5, 2024 at 2:19 PM
    #7638
    eddiefromcali
    Eddie
    100% Stock
  19. Nov 6, 2024 at 2:22 AM
    #7639
    ramnj
    ramnj New Member
    NJ
    Thank you!
    Hye_Tundra[QUOTED] likes this.
  20. Nov 6, 2024 at 1:47 PM
    #7640
    Ncousins1
    Ncousins1 New Member
    Niko
    Gainesville, FL
    2024 Tundra 1794 TRD Offroad
    Finally got around to lift, wheels, and tires.
    Lift: Westcott Designs 3in front 1.5in rear
    Wheels: SCS Gen5 17x8.5 in +20 offset
    Tires: Nitto Recon Grappler 35x12.5
    SnowToy, obs1921, Burns and 19 others like this.
  21. Nov 6, 2024 at 3:58 PM
    #7641
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Love that color!!!!!
    svcabron likes this.
  22. Nov 6, 2024 at 5:12 PM
    #7642
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Any sway bar rub?
  23. Nov 6, 2024 at 10:34 PM
    #7643
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    It does not, the cats are further back. I put on a cat shield to protect them
  24. Nov 7, 2024 at 2:51 AM
    #7644
    SilveradoSwap
    Thanks.
    Wheels are Vossen HF6-4 Terra Bronze 22x9.5 @ 20 offset
    Tires are Toyo Open Country AT3 305/45R22 (32.8x12x22)
  25. Nov 7, 2024 at 6:12 AM
    #7645
    Ncousins1
    Niko
    Gainesville, FL
    no, everything clears just fine
    ARCOVT23[QUOTED] likes this.
  26. Nov 7, 2024 at 6:16 AM
    #7646
    Ncousins1
    Niko
    Gainesville, FL
    Also knocked out swapping the chrome mirror caps with paint matched and added smoked sequential turn signals
    before
    after
  27. Nov 7, 2024 at 10:08 AM
    #7647
    H2ODoggy78
    H2ODoggy78 New Member
    Yancy
    SA, TX
    2024 TRD OR
    3" Rough Country Vertx Lift, 35X12.50X20 Ridge Grapplers
    Damn! That looks very nice! I really like how the midnight multicam on the flares blends with the paint color of the truck. I am planning on putting the Pro flares on my '24 TRD OR as well. My truck is white though. I don't think it will look as good as yours, but still should look good. I also have the TRD wheels with 35"X12.50"X20" Ridge Grapplers.
    KClav and mikev25[QUOTED] like this.
  28. Nov 7, 2024 at 12:26 PM
    #7648
    23MAXBlue
    23MAXBlue New Member
    Ed
    2025 Celestial Silver Limited Hybrid IForce
    Hard trifold worksport aluminum cover and a OEM tailpipe finisher.
  29. Nov 7, 2024 at 2:26 PM
    #7649
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    Put some American flag stickers on. I had them on my last tundra and have always liked the look.
    cartage1, RatPanda, KClav and 3 others like this.
  30. Nov 8, 2024 at 2:27 PM
    #7650
    223Wylde
    223Wylde New Member
    Jeff
    Cottage Grove, MN
    2023 Tundra TRD Pro MGM
    XL version, and also they are horizontally slotted, so you can adjust about an inch in-out, I mounted mine all the way out.
