Why can't I find a replacement air intake hose for my 2000 sr5 v6 tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by Corey77, Nov 23, 2024.
  1. Nov 23, 2024 at 4:52 PM
    Corey77
    Corey77 [OP] New Member
    Corey
    2000 Toyota tundra
    Air intake hose
  2. Nov 23, 2024 at 6:01 PM
    bfunke
    bfunke Tundra Curmudgeon
    17881-62140 discontinued by Toyota like a number of early FGT parts. May want to search wrecking yards. Might also be able to adapt the Dorman part for several years.
  3. Nov 23, 2024 at 6:02 PM
    bfunke
    Yoshiparts.com claims to have it.
  4. Nov 23, 2024 at 6:10 PM
    shifty` No Water in the Water Fountain
    Dorman has a decent repop, as I recall. I just had to drop one in a 3rd gen civic. That said, junkyard is your friend. That engine was used in a wild array of Toyotas, including the Highlander and 4Runner, maybe Sienna if I’m not mistaken?
  5. Nov 24, 2024 at 3:54 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I don't thing the 3.4 was ever used in a FWD platform -- only 4WD & RWD trucks and SUVs (probably some RWD cars outside North America) My '03 Sienna had a 3.0 VVT.
    @Corey77 I know the 3.4 was widely used in the Tacoma, and 4Runner -- in fact it's rare to find a 3rd Gen 4Runner ('96-'02) without the 3.4. You'd have to do a little research to see if the air intake on those vehicles is the same as your Tundra. When I had a 4Runner I was a member of 4runners.com and there was always someone parting out a vehicle. I just looked, and there are two being parted out there now. Again, do your research because I don't know for sure if the intakes are the same.
    https://www.4runners.com/forums/3rd-gen-4runner-parts-marketplace-1996-2002.78/
    shifty`[QUOTED] likes this.
  6. Nov 24, 2024 at 5:44 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Or you can get an aftermarket modular tube like what @455h0le_dachshund suggested here...
    https://www.tundras.com/threads/supercharg-5vz-or-2uz-swap.150701/#post-3759756
    I have my stock airbox from my 3.4 that has the stock tube that I'll most likely not use because I want to buy the Airaid modular tube. If you verify the fitment between my Tacoma and your Tundra, I can sell you mine. My guess is it should fit. Alternatively, I'd check junkyards or OfferUp/FB marketplace. I just found a couple on OfferUp local to me. They are out there, you just gotta hunt them down.
  7. Nov 24, 2024 at 5:55 AM
    455h0le_dachshund
    455h0le_dachshund Human tongue feels aluminum plate, it's a missile
    Reverend Hotdog
    TX...big surprise
    I think the air box is different on tundra, but I think the hose is identical on all 5vz engines
    TacomaTRD4x402 likes this.
  8. Nov 24, 2024 at 7:28 AM
    TacomaTRD4x402
    Southern California
    Just snapped a couple pictures of mine from my rebuild. Looks almost the same from OPs pic except for one end..
    And part numbers of each piece..
    OP, @Corey77 if your local to So Cal, we can test fit and work out a deal. Like I said, I'm looking to put that modular tube on mine.
  9. Nov 24, 2024 at 7:35 AM
    TacomaTRD4x402
    Southern California
  10. Nov 24, 2024 at 7:48 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  11. Nov 24, 2024 at 8:02 AM
    TacomaTRD4x402
    Southern California
    Hopefully it'll work for OP, if he even comes back. That was his first and only post.
    Only difference I see is where it connects to the TB but that shouldn't prevent it from working.
    1lowlife[QUOTED] likes this.
  12. Nov 24, 2024 at 8:48 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I have the OEM intake tube for my 06 2uz if that helps. I don't need it. Would trade for a Philly cheese steak sammich or beer. :D
    1lowlife likes this.
  13. Nov 24, 2024 at 11:10 AM
  14. Nov 24, 2024 at 3:45 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  15. Nov 25, 2024 at 5:30 PM
    bfunke
    OPs part is 17881-62140
  16. Nov 26, 2024 at 6:23 AM
    w666
    Maryland
