  1. Dec 27, 2024 at 4:01 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
  2. Dec 27, 2024 at 4:04 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Honestly it's way easier than I ever thought. Repair Geek on YouTube is what educated me and finally got me realizing that this was easy and something I could diy
    bulldog93 likes this.
  3. Dec 27, 2024 at 4:05 PM
    Halozed
    Halozed New Member
    Detroit Rock City
    2020 MGM Tundra Platinum
    Will look that up, thx
    My list of updates and mods is modest but ever growing. Still trying to get my head around suspension and wheels/tires
    Henry1jg[QUOTED] likes this.
  4. Dec 27, 2024 at 4:32 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I got it back! Woot!
    Now, to keep those rats away…
  5. Dec 27, 2024 at 4:37 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Added a coachbuilder 1” shim to both sides and RAS to the rear on the 1mm (white) chip setting.
    Measurements from the ground to edge of wheel well
    BEFORE
    Driver front - 37”
    Passenger front - 37 3/8”
    Driver rear - 39 3/8”
    Passenger rear - 39 3/8”
    AFTER
    Driver front - 38”
    Passenger front - 38 1/8”
    Driver rear - 40 3/16”
    Passenger rear - 40 3/16”
    Just took a quick drive down the road but I notice a pretty significant difference in the feeling of the rear… no bounce and very planted feeling. I wasn’t sure if I would be able to tell, but after installing I’m very impressed!
    Total install time was about 5.5 hours, including two trips to Lowe’s lol.
    Tripleconpanna, BR73 and bulldog93 like this.
  6. Dec 27, 2024 at 4:57 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    I picked up the spray gun and wands that Kellsport sells when I moved to Michigan years ago, definitely worth the investment (or something similar). A gallon of Fluid Film is only $40 and I can usually get 2 trucks out of a gallon.
  7. Dec 27, 2024 at 5:27 PM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I saw one of those racks at Costco, but there were much better alternatives on Amazon.
    TacomaTRD4x402[QUOTED] and Mater like this.
  8. Dec 27, 2024 at 6:14 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Here's the drill rack from Wall Control. This is what I'll probably end up getting.
    1UP and primeiro like this.
  9. Dec 27, 2024 at 6:43 PM
    longhornfan2324
    longhornfan2324 New Member
    Yea it’s went up quite a bit almost doubled since then. Works great through now I’m on to looking at either a 2 post or 4 post lift. Pros and cons of each decisions decisions.
  10. Dec 27, 2024 at 6:48 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
  11. Dec 27, 2024 at 7:40 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Today I did the Revesol steering wheel. He's my take on it. First off, it's nice, very well made and the stitching is real nice pattern, not your regular stich pattern. Everything fits like OEM. I like all the contours it has, also. Now the bad, IMO. It's square. It will probably take sometime to gett use to hold on to a square mold instead of the round OEM style. The backside finger indets feel off also. Lucky for me, when I drive I don't hold my steering with my hand wrapped around it. Most of the time, I either have my elbow on the window sill, holding my wheel with a couple fingers or I hold it towards the bottom the same way. I wouldn't go back to the OEM and not a deal breaker but the square design just doesn't feel right.
    woods, BR73 and RobertD like this.
  12. Dec 27, 2024 at 8:12 PM
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    Just the front, not sure if I can buy a rear later or not but at least it's better then nothing. Super easy to install and use also looks stock is why I like it.
    bulldog93[QUOTED] and RobertD like this.
  13. Dec 27, 2024 at 9:56 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    Just installed my ss3 max fogs. What wire did you use to t tap the backlight to?
  14. Dec 28, 2024 at 5:36 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I'm kind of surprised you don't think they're brighter. I installed the OEM LED's in my '15 years ago, but just recently swapped to the SS3 pro's. The only difference is I went with the standard, not the ambers. I remember hearing somewhere that the ambers use a lower output LED than the standard white, though I haven't ever confirmed it. I was so impressed with the SS3's in the fog light location that I splurged a few weeks later and replaced my aging BD Squadrons to SS3 Max's on my ditch lights.
  15. Dec 28, 2024 at 6:29 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I agree w/25000yota here... I installed a pair of SS3 Pro fogs on the wife's Subi and they are significantly better (brighter, cleaner light output, and better side throw) than even the OE Rigid LEDs in my '21 Pro :notsure:
    250000yota[QUOTED] likes this.
  16. Dec 28, 2024 at 9:12 AM
    French Avocado
    Utah / Wyo
    I am going to do this!
    What retrofitting was required?
    Did you need longer bolts for the rail attachment?
    Did you need washers or spacers between the packout plate and rail mounts?
  17. Dec 28, 2024 at 11:53 AM
    250000yota
    Russ
    Berthoud, CO
    They say 10% but I feel they are significantly brighter than the yellows. I do also really enjoy the wider beam than the stock LED fogs. I don’t have any photos of the output with just the headlights, but I’ll see if I can get one after work.
    Henry1jg and batman900[QUOTED] like this.
  18. Dec 28, 2024 at 1:16 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    No, 10% decrease of output is due to other brands utilizing a lens for an amber color. For example, I used to use caliraisedled pod lights with rigid amber lenses - that resulted in a decrease in output.
    There shouldn’t be any decrease in output if the pods were made specifically for its color. So if DD advertise their output for their Amber pods, it should be as such.
  19. Dec 28, 2024 at 5:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Reworked my radio mounting - modified the Dasaita trim brackets and added modified factory brackets to significantly stiffen up the mount while making more room for all the wiring to stuff up inside.
    Also routed cables behind the HU for my Icom radio controller and external speaker.
  20. Dec 28, 2024 at 6:09 PM
    Tripleconpanna
    We run ambers as well...
    I'm guessing, but it looks like your fogs are illuminating about 150-200' in front of you which is pretty good. Remember, the PROs are SAE compliant and have a very distinct 'cutoff' point so as to not blind oncoming traffic. You may get some better performance by angling up just a bit more, but w/that side throw the way it is you'd risk blinding oncoming folks especially on 2-lane highways, etc...
  21. Dec 28, 2024 at 7:43 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Did you order through their site? I tried emailing them and message them through fb and got zero respond. Was considering them but i think i will pass. Plus, i dont like their 3D ring up and center. They had a non 3d version that i inquired about but since they won’t respond. I will look for something else. The cartrimhome wheels is pretty similar, they dont have the finger inlets on the backside. They have 1 thumb groove at the 9 and 3 o’clock position, whereas revesol have 2. No 3d ring either on the cartrimhome wheel. Oh and they actually respond to inquiries..
  22. Dec 28, 2024 at 7:47 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Or you can just go with Baja Designs. :rofl:
    HulkSmurf14 and ATV25 like this.
  23. Dec 28, 2024 at 7:49 PM
    RobertD
    Robert
    DFW, Texas
    Being someone who has reached out to them a lot. I will say they are hit or miss when responding, and they definitely don't speak English. Before they had their website, I would contact them via ebay.
    And to be fair, Revesol was one of the first to release an all black leather wheel at an affordable price since the tundras.com forum showed there was an actual interest and desire for it. So they do listen at times but I'm right there with you, support the company that responds to you.
    https://www.tundras.com/threads/we-...rest-revesol-all-black-steering-wheel.112984/
  24. Dec 28, 2024 at 7:56 PM
    BrandonL812
    Brandon
    I’m always willing to give company a chance, but after a week or two of zero respond. I see no good reason to support them. Honestly i DID msg them through ebay also. On their store page. So that’s 3 places i send inquiries to. Yet, none even gave it a glance. I understand it’s the Holiday and everyone is running crazy. But after 2wks of waiting for a simple, sorry we dont offer that anymore or such. I give.
    RobertD[QUOTED] likes this.
  25. Dec 28, 2024 at 8:00 PM
    RobertD
    Robert
    DFW, Texas
    Completely understand. I have a few companies right now that are annoying me cause I can't get a response.
    This is where @memario1214 shines since he responds so well!
  26. Dec 28, 2024 at 8:01 PM
    BrandonL812
    Brandon
    He’s always on top of it. Quick on the respond too.
    memario1214 and RobertD[QUOTED] like this.
  27. Dec 28, 2024 at 10:06 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Hell - he’ll randomly call you out of the blue and ask you how things are going even!
  28. Dec 28, 2024 at 10:42 PM
    pursuit2550
    Yeah, I ordered through their site for Black Friday. It came out to around $220 shipped. I got the all black wheel with the black 3D center piece. Didn't care for a color option. I also didn't have to email them since I had no questions, so I wouldn't know about their response time. Over all its a nice steering wheel and other than what I mentioned, I really don't regret my choice. I didn't know there was another option. If I would have known I would have looked but I over its still better, to me, over the OEM.
    BrandonL812[QUOTED] likes this.
  29. Dec 29, 2024 at 12:18 AM
    RobertD
    Robert
    DFW, Texas
    I haven't spent enough with him to get to this level of his customer service :pout:
  30. Dec 29, 2024 at 7:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    :anonymous:
    :spending:
