2022+ Tundra Lowering Kit
Discussion in 'Suspension' started by ChefKevin, Mar 22, 2024.
  1. Mar 22, 2024 at 5:15 AM
    ChefKevin
    ChefKevin [OP] New Member
    Kevin
    2022 white tundra
    I’m sure it’s been asked before but by now i would’ve figured someone would have made a few different lowering kits for the newer tundras. Yes i know there’s the SOS 2/3 lowering kit for ones with rear air suspension but are there any for ones without the rear air suspension? I’m looking for more of a 3/5 or even 4/7 drop
  2. Mar 22, 2024 at 5:24 AM
    Eurodriver
    Eurodriver New Member
  3. Mar 22, 2024 at 7:05 AM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    Welcome to the forum. I see this is your first post. If this is intended to be comedy, you knocked it out of the park.
    If you're truly interested in lowering your tundra, I hope you find what you're looking for. I think you may find there isn't much aftermarket support for that style though.
    DogRunner2 and ChefKevin[OP] like this.
  4. Mar 22, 2024 at 7:08 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Interesting. Most here want to lift their trucks, stick on huge poked out knobby tires to pretend they are tough off roaders, and kill their MPG. LOL. That's what the aftermarket mostly offers up.
    The TRD Sport trim is a bit lower, so you could get those parts and swap them out... but probably not as low as you are looking for?? But, IMO, anything lower than that would be just as goofy as the lifts I see.
    DogRunner2 likes this.
  5. Mar 22, 2024 at 7:21 AM
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    Pretend they, themselves are tough off-roaders, or their Tundras are tough off-roaders?
    I feel like lifting your truck and installing knobby tires is a misguided way to display toughness. Personally, if I was going to attempt to fain toughness, I'd start lifting weights, constantly reference my military service (even when it's not relevant or even if I had any to honestly reference), go to an MMA gym once but talk about it constantly, drink non-Bud light American beers, grill tasty meats and generally be boisterous. I suppose lifting a truck and installing knobby tires would fit in with that costume, but you couldn't rely solely on it. In my opinion, of course.
    Unless you meant to pretend to make the truck tough. Then I totally agree. You definitely need to start with armor and recovery to make a truck more tough. But if your goal is just to pretend you truck is a tough off-roader, a lift and huge knobby tires is a solid technique.
    KrissyMattAlpha likes this.
  6. Mar 22, 2024 at 8:18 AM
    ChefKevin
    Kevin
    2022 white tundra
    Lifted trucks aren’t really my style
    eddiefromcali likes this.
  7. Mar 25, 2024 at 7:56 AM
    WrekEE
    WrekEE New Member
    Where are you located where lowered trucks are in.
  8. Mar 25, 2024 at 8:13 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Havent seen anything yet. I've been on the hunt for a "real" drop kit as well and no one has put out anything yet. A friend is a Belltech dealer and she hasnt seen anything yet either. Sucks, gotta wait or go custom
  9. Jun 3, 2024 at 6:31 AM
    Pegasus1794
    Pegasus1794 New Member
    JAMES
    NC
    '24 Wind Chill 1794
    Following. I’d be happy with a just springs & shocks to lower the rear to “level” it.
  10. Jun 3, 2024 at 9:16 AM
    theTupper
    theTupper New Member
    Jake
    2024 Limited Crewmax HV, Lunar Rock
    I've only seen one example of a lowered Gen3 and it was a guy in one of the FB groups. He may be on here, but I can't recall having seen him post. I know that's not overly helpful but, as I'm sure you've seen, lowering is the opposite of what most folks are looking to do (if anything).
    Good luck in your search!
  11. Sep 5, 2024 at 7:53 PM
    rchoi
    rchoi New Member
    2024 Limited TRD OR
    Following as well. I to would like to lower rear to level. I use my truck for truck things so I have airbags to level loads. I have 4x4 because boat ramps get slippery and sometimes need the extra traction. I do off road a bit but nothing crazy. I've even been considering cutting 1 or two coils off, but I would prefer not to have the stiffer rate that comes with that. Any body have any information on other models that have same physical spring shape? From what I find it looks like 4runner springs won't fit. Maybe a Landcruiser?
  12. Dec 30, 2024 at 3:22 PM
    rchoi
    rchoi New Member
    2024 Limited TRD OR
    Just ordered this from Amazon. .5 inch lift on a Tacoma should result in about a 2" drop for rear of Tundra. Will post results.
    https://www.amazon.com/dp/B0D6QLK5KV?ref=ppx_yo2ov_dt_b_fed_asin_title
  13. Dec 30, 2024 at 5:21 PM
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
  14. Jan 1, 2025 at 5:25 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    3rd Gen oem Sequoia springs will lower 3rd Gen Tundras by 1" to about 1-3/4" depending on the trim. Find them on the cheap on Facebook marketplace.
    vtown76 likes this.
