2016 LED headlight bulb ID?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Adventundra, Jan 30, 2025.
  1. Jan 30, 2025 at 6:11 PM
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Passenger side headlight is out and I YouTubed how to take the grill off to access the bulb….only to find out that the bulbs I bought were not like the ones in there…& in a hurry to reassemble the headlights and grill before it got dark…I forgot to take a pic of the bulb that was in there. I’m not familiar with LED bulbs. It had a wire that plugged in like this w the screw on collar. And the bulb itself looked like this Sylvan bulb but this one for sale does not have a plug in wire coming out the end of the bulb. I did notice a small black screw on the side like this pic but what the heck is that for?
    I will take off the grill again tomorrow and get some pics but was wondering if anyone knows what I am dealing with. Definitely annoying to have it take off the grill and partial front fender to change a friggen headlight bulb. Also, anything else I shud do in there while I have the grill off?
  2. Jan 30, 2025 at 6:23 PM
    There are so many Amazon products, syles, and knockoffs that we can't guess or determine what you have until you post pictures of what is installed.
  3. Jan 30, 2025 at 6:26 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya! Thanks! Thats what I kinda figured after searching for 30 mins looking for the damn thing and seeing more Friggen LED bulbs than you can shake a stick at!! Can’t believe I forgot to snap off a pic. Welp…I will get practice taking the grill off again tomorrow…in the rain. Ugh
  4. Feb 1, 2025 at 4:24 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Just 1, assuming you have OEM halogen housings replace them with some that are designed for LED bulbs.
  5. Feb 1, 2025 at 6:15 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    If the housing is made for a halogen bulb then the beam from the LED will not produce the correct beam pattern..
  6. Feb 1, 2025 at 6:26 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    You can get good beam pattern if you get the diode dynamics set. But they are expensive though. I would save up and get the oem led headlights instead. Plus it look better. It update the front end real nice..
    Adventundra[OP] likes this.
  7. Feb 1, 2025 at 6:45 AM
    Sent you a PM
  8. Feb 1, 2025 at 8:24 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Alright fellas! Back at it ripping grill off to fix a headlight bulb.
    WTF am I looking at??
  9. Feb 1, 2025 at 8:34 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Also…any idea where to get these press clips cuz a few broke taking grill off…
  10. Feb 1, 2025 at 8:36 AM
    AZTundra
    Paul
    Phoenix, AZ
    Looks like some sort of aftermarket led lights installed into the factory oem headlight housing. I would probably pull both and just go back to standard bulbs for both headlights. If you want to go led save up for some oem led headlights and use the ihacker harness which is the route I took with my 2017.
  11. Feb 1, 2025 at 8:40 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    How do I go back to standard bulbs w the current situation? How much $ am I saving up for OEM headlights? Do I need an ihacker harness …looks like there is a harness already.
  12. Feb 1, 2025 at 9:36 AM
    agrestic1
    2016 CrewMax
    The original 3 prong plug is what to look for. Looking at your pics, there is a harness going into the black box. Looks like the OEM plug is connected to that harness ??
  13. Feb 1, 2025 at 9:39 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya. Yep…there’s a plug that goes to harness. Now I have to buy the 3 prong plug?? Mite as well splurge now for whatever fits back in there.
  14. Feb 1, 2025 at 9:53 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  15. Feb 1, 2025 at 9:53 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
  16. Feb 1, 2025 at 10:01 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I guess you would replace the entire old kit with your new kit.
    Over the years people have not had good results putting LED bulbs in the halogen housings.
    Light patterns and scatter seem to be the issues.
    I understand the 2018+ OEM LED upgrade is a big investment, and you already have an LED bulb setup.
    If you are dead set on having LED bulbs in your halogen housings, I'd suggest VLEDs.
    They make great products..
    V50 MONOCHROME SERIES H4 9003 H19
    There is a short install video in the link.
  17. Feb 1, 2025 at 10:09 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks! At this point I will pay anything to be done with this BS and just have some headlights.
    I will watch the video to see what’s involved.
  18. Feb 1, 2025 at 10:18 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Can’t find video link.
  19. Feb 1, 2025 at 10:52 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    It is on the page, I can't link it separately..
    It's just a short clip on securing the bulb.
  20. Feb 1, 2025 at 11:05 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I swapped my housings out for some Profile LED retrofits with LED DRL bar. Ranks up there with best mods.
  21. Feb 1, 2025 at 11:06 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Watched it. Thanks! Don’t think I even have the wire clips. I wud rather just find one that has the silver press button that goes into my existing collar….i just found a pair at my local fancy truck store…but they tried selling it to me even though it didn’t have the memory/smart box….it just had the 3 prong plug n no box. I bailed out of sale. He said my old one had a fan and that’s why I had a memory box.
  22. Feb 1, 2025 at 11:14 AM
    BrandonL812
    Brandon
    From the picture. You need to remove the rubber weather shield boot off the back of the headlight.. the led bulb you took out, it came off it's housing.. remove the rubber boot and you will see the spring that hold the bulb down..
    Adventundra[OP] and 1lowlife like this.
  23. Feb 1, 2025 at 11:17 AM
    BrandonL812
    Brandon
  24. Feb 1, 2025 at 11:19 AM
    BrandonL812
    Brandon
    1lowlife and Adventundra[OP] like this.
  25. Feb 1, 2025 at 11:22 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I concur.
    I would think something has to be holding that collar in place..
    https://youtu.be/s1YH9gYPloo?si=33Vy4O513EyWKFeJ&t=342
    EDIT: You already posted it...:cool:
  26. Feb 1, 2025 at 11:26 AM
    BrandonL812
    Brandon
    Yeah. These typical cheaper led bulbs all over Amazon and ebay have those collar on them to help people "clock" them after install..this way the led go straight up and down.
  27. Feb 1, 2025 at 11:26 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  28. Feb 1, 2025 at 11:42 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I’m quitting for the day…been at this since 10:30. Mentally and physically drained. Gota take kid to Boy Scout aquarium sleepover and will keep researching this crap tomorrow. Thanks for your support!! Lol
    1lowlife likes this.
  29. Feb 1, 2025 at 12:34 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Sometimes quitting is a good thing. A few weeks ago I was going to quit after dropping oil cap in hard to reach spot. I thought I am already dirty so might as well change PCV valve. Got in a hurry and snapped nipple on intake.
  30. Feb 1, 2025 at 1:02 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Yikes!! That’s something that would happen to me!! I got the kind of luck that…if it was raining titties…I wud get hit in the head w a dick!! Lol
    BrandonL812 and 1lowlife like this.
