RAT
Discussion in 'General Tundra Discussion' started by DADKILL, Feb 21, 2025.
  1. Feb 21, 2025 at 7:02 AM
    DADKILL
    DADKILL [OP] New Member
    22 Tundra Limited 4x4
    They frigging love to crap and piss on my gen 3 engine cover. The little bastards don't chew on the wiring thank God. I suspect it's perfect for them when it's cold with the heat shield pad under the hood and the 2 inch gap between the engine cover, so it's cozy in the winter.
    This particular a$$hole is smart. He won't go for any bait that has previously worked. (Cheese, peanut butter, slim Jim, berries) though he did trigger one with a piece of banana. The peppermint oil spray isn't deterring him either. I've relented and put out a commercial style bait box, (which I didn't want to do because the poison is a cruel way to die, and I didn't want predators getting poisoned) , but I'm out of ideas.
    Oh.. by the way, I'm 6'3" but still have issues reaching all the way into the engine bay to clean it. I saw a little cheap foldable step stool at home depot for $4.99.... looks too little, but hold 300lbs and it's frigging perfect and allows me to reach everywhere in the engine bay. I urge you guys to get one.
    Advice on the rat issue would be appreciated.
  2. Feb 21, 2025 at 7:25 AM
    2mchfun
    Pine sol soaked rags, snuggle dryer sheets, and bars of pink dove soap live under my hood in various places 24/7/365. Zero issues.
    DADKILL[OP] likes this.
  3. Feb 21, 2025 at 7:25 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    So Honda makes duct tape with capsaicin (basically pepper spray) in it. It's designed to be wrapped around wiring and then rodents won't touch that wiring. If I were you I'd consider applying it to any visible wiring, knowing that you're little furry friend is so determined to snooze in your engine bay, it'll only be matter of time before he decides to nibble on some wires.
    Alternatively, I've heard good things about electronic rodent deterrent devices that use strobe lights and sounds and you mount these devices in your engine bay.
    DADKILL[QUOTED][OP] likes this.
  4. Feb 21, 2025 at 7:29 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    A delightful kitteh.
    FrenchToasty and DADKILL[OP] like this.
  5. Feb 21, 2025 at 7:33 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Also keep in mind that rodents are averse to well-lit areas. So perhaps some rope lights or flood lights could be placed under and/or around your truck when it's parked overnight?
  6. Feb 21, 2025 at 8:00 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    Bastages! I know you said the bait didn't work, but I've had success with baited rat traps with peanut butter behind the front tires and a sonic deterrent under the hood. I've not found essential oils to be very effective - I've tried peppermint, eucalyptus, and rosemary (good Young Living EOs) in water sprayed liberally around the engine bay. You might also consider blocking the passages into the cabin as described here.
  7. Feb 21, 2025 at 10:27 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I had rat pellets on my engine cowl a couple of years ago. Shortly after I noticed it, my windshield washer lines started leaking. The little bastards seemed to really like the tubing and ate holes in several places. I freaked out worrying that they might have gotten to the wiring somewhere (or would in time). I was on a mission at that point.
    I tried all sorts of things. The oils, sprays, snap traps, moth balls, various deterrent totems in the engine compartment and wheel wells, etc. Snap traps had good results, but the rats were still savaging my washer lines. After completely replacing the tubing twice, I broke down and tried bait boxes. (I don't like bait boxes because it is a horrible death, I don't want to poison predators, and I don't want to go on a hunt for rat corpses decaying in my garage).
    The bait boxes and snap traps worked and are still working to this day. (I bait my snap traps with a small, rolled up balls of cheese that I smear peanut butter on. Then I jam the ball down onto/into the trap trigger). Those methods haven't worked well for some people, but it is currently working very well for me. I haven't had any evidence of rodent activity on or in my truck since using those two methods. YMMV
    I have been using the TomCat brand refillable bait boxes (that I picked up from Home Depot). They state on the box that they are pet and child safe, but I think that refers to the bait box itself and not the poison inside. And I have had to dispose of several little corpses that I've found in my garage and outside areas around the house. So far, I've had to locate 2 decaying rats that died in out of the way places in the garage. FYI
  8. Feb 21, 2025 at 12:22 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    You could try sticky traps. All they are is an adheasive strip and when the rodent steps on it, thats it, they can't get off. You just throw the thing away.
    Only thing is, you might have to remove them before you start your vehicle.
  9. Feb 21, 2025 at 4:38 PM
    shoot-staight
    shoot-staight New Member
    Brett
    2007 SR5 double cab, 2020 SR5 double cab
    Well I thought i was alone... Yea, I had Rats sleeping on engine cover too. The waste grain from my backyard flock brought them to the area. Caught one in a live trap baited w dog food right under my skid plate. (I wont speak to what I did to him) but thought that was that. Then saw more fresh droppings. Set trap again. No success. Put sticky trap on my engine cover. They were too smart. I relented and put baits out. After a week or so I saw no new droppings or signs of them- till about a month later my buddy was looking my truck over and saw something on my skid plate. A dead decomposing rat. So the bait got him but he was still using the truck.
  10. Feb 21, 2025 at 5:00 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Park where there's light, works better than anything.
  11. Mar 6, 2025 at 1:15 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    A friend of mine has been using moist cat food for baiting raccoons. He’s had very good results. You might could try that
  12. Mar 6, 2025 at 1:41 PM
    CringyDad
    CringyDad New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    Try baiting your traps with a partially chewed Snickers. It's the only thing that works for rats in my attic.
  13. Mar 6, 2025 at 1:58 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Tundra Cat?
  14. Mar 6, 2025 at 2:04 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    the easiest option ive found for me and rodents is a few large cotton balls placed on each side of the engine bay then i hit them in 100% peppermint oil i put in a spray bottle. refresh every 1-2 weeks. it's super strong and since peppermint i get a faint fresh smell in the cab. only the 100% oil has worked that i get through Amazon. the rodent control stuff in hw stores also some use peppermint but it's super watered down and doesn't last. no dead rodents to clean up. they just go find something else to live in. all my outside cars have the cotton balls.
