2023 70K review - warning messages
Discussion in '3rd Gen Tundras (2022+)' started by obgod3, Feb 21, 2025.
  1. Feb 21, 2025 at 6:00 PM
    obgod3
    obgod3 [OP] New Member
    NC
    2023 Tundra Limited
    Quick video of the 2023 with 70K on it. 2 years old. You’ll see im getting some warnings about mid-video, I dont see any codes and either thinking the windshield sensor/camera is bad or a bad calibration post windshield replacement. Open to suggestions. It does disable cruise for me which I really like using.
    Anyway the truck is doing great and I’ll have a new engine in the next couple months. Couple things in the video, drivers window skipping is one.
  2. Feb 21, 2025 at 6:53 PM
    NTX_Tundra
    NTX_Tundra New Member
    I have a 23' with 67k and have had no issues so far either. How are your brakes holding up? Have you done the spark plug changes every 40k?
  3. Feb 22, 2025 at 2:33 AM
    obgod3
    NC
    2023 Tundra Limited
    Did rear brakes but front are still holding well. Have not done the spark plugs yet, service hasn’t even recommended them. However Im getting ready to do the diffs and transfer case services. As long as I can figure out the warning messages issue, headlight, rsa malfunction stuff, Otherwise I might look for a ‘25 platinum.
  4. Feb 22, 2025 at 2:52 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    If you are seriously thinking of a 25, don't waste a few grand on the cases being serviced!
  5. Feb 22, 2025 at 6:56 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Transfer case and Diffs should be a couple hundred at the most if you do them at home plus a few hours of your time.
  6. Feb 22, 2025 at 7:13 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    obgod3[OP] likes this.
  7. Feb 22, 2025 at 8:40 AM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
    Coming from someone with a short commute, when my windshield was replaced the window technician relayed that it took him a couple times to get things calibrated correctly.I just attributed it to he was new to the process.
  8. Feb 22, 2025 at 9:15 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Thanks for the update.
    FYI, I was getting a "Front Camera Unavailable" warning message that would come on, then go away, about every 10-15 minutes while driving. I also experience the same error messages that you showed on your video a couple of times during that period. It was definitely NOT related to any obstructions of the camera or sensors.
    The dealership determined it was a faulty front camera and replaced it. That was a few months ago and so far no more warnings or malfunctions.
  9. Feb 23, 2025 at 5:49 PM
    obgod3
    NC
    2023 Tundra Limited
    Thanks for the info, I’ll let my guy know. They owe me a recalibration anyway.
  10. Feb 24, 2025 at 5:11 AM
    ARB1977
    ARB1977 New Member
    Anthony
    24 Tundra CM SR5 4x4 CSM build date 05/24
    22whatwedo, Tom976 and captainnemojr like this.
  11. Feb 24, 2025 at 5:13 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    isn't that nice of them! Do you know why, or what benefits either might give?
    Thanks for the new info!
  12. Feb 24, 2025 at 5:16 AM
    ARB1977
    ARB1977 New Member
    Anthony
    No clue. What ever you do don’t use gear oil. Any other gen gear oil yes.
    woods[QUOTED] likes this.
  13. Feb 24, 2025 at 6:36 AM
    nodak67
    nodak67 New Member
    JR
    does it disable both cruise modes?
    or do you only use radar cruise and not constant speed cruise (which doesnt require the camera or radar)
  14. Feb 24, 2025 at 7:19 AM
    obgod3
    NC
    2023 Tundra Limited
    good question, I’ve only ever used radar cruise, didn’t know I could go manual on it. Next time it happens I’ll try it.
  15. Feb 24, 2025 at 7:30 AM
    nodak67
    nodak67 New Member
    JR
    all you have to do is hold the cruise button for like 5 secs to engage constant speed cruise control
    obgod3[QUOTED][OP] likes this.
  16. Feb 24, 2025 at 7:41 AM
    Matt2015Tundra
    2023 1794 CrewMax
    FYI, when my front camera was malfunctioning, and I was getting the same error warnings, it would disable radar cruise and the front collision detection, but regular cruise still worked.
    obgod3[OP] and nodak67 like this.
