  1. Feb 26, 2025 at 12:37 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    00h2itr[QUOTED] likes this.
  2. Feb 26, 2025 at 1:38 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Box is in, sans accelerator for now. Those 2 bolts weren't too bad.
    TacomaTRD4x402, woods and bulldog93 like this.
  3. Feb 26, 2025 at 7:08 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    New tires went on yesterday, I can daily drive it but it will take some work to be able to wheel with them. Old - 39x12.50R17, new - 40x13.50R17.
    Here is the new one next to my wife's 37x12.50 spare.
    PXL_20250225_224505506.PORTRAIT.jpg PXL_20250225_224615752.PORTRAIT.ORIGINAL.jpg PXL_20250225_224520674.PORTRAIT.jpg
  4. Feb 26, 2025 at 7:22 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Mean meats! Looks freakin' rad!! Good choice!
    STravis likes this.
  5. Feb 27, 2025 at 1:38 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Mini project to clean up my engine bay and move my passenger fuse block inside, and all but one circuit was going into the cab anyways. Space is limited, but I found a couple M6 captive nuts behind the dash on the right wall above the door wire passthrough. I made a 6.5" tall x 6" wide steel panel for my fuse/ground blocks that will use the captive nuts to mount to the wall.
    Fused battery power via 0Ga wire passthrough from the engine bay into a fused distribution block that will have 75Amp 4Ga going to my amp, and a 50Amp 8Ga going to the smaller fuse block. The larger fuse block is powered by a relay powered from the small fuse block and triggered by IGN2.
  6. Feb 27, 2025 at 4:06 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Swapped out for some new bed rail anchors. The bulky Cali-Raised is heavy duty and nice but when using standard bungee cords or tie down straps the hook cannot grip the handle. Got the new set off from Amazon for decent price, I didn’t want to pay over $100 for some tie down anchors.
  7. Feb 27, 2025 at 4:10 PM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    I like those, I'll have to look on Amazon to see if I can find them. I agree there are some nice ones out there but for the price and as offen as I would use them don't add up for me.
    BR73 likes this.
  8. Feb 27, 2025 at 4:57 PM
    Quicksand_Tundra
    Jon
    Correct. I’ve seen some go for $150-200 for a set. This brand on Amazon is by a company called Reno. $46 a set.
  9. Feb 27, 2025 at 5:03 PM
    Boneskull420
    Tn
    Thanks for sharing
  10. Feb 27, 2025 at 5:20 PM
    Hiking_Yota
    Hiking_Yota New Member
    The micros look great.
  11. Feb 27, 2025 at 5:56 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Still enjoying the truck. Have to adjust and lower the preload on the passenger side coilover this weekend. Same threads showing but drivers side is 1.25 inches lower from ground to fender. Is what it is. If lowering the preload doesn't work I'll have to add a shim to the top.
    Good news is used my ARB compressor to pump up my little nephews basketball while shooting hoops in the driveway. Worth the price just for little things like that.
    Tundra family and Sleeper16plat like this.
  12. Feb 28, 2025 at 6:29 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Doing my first coolant flush n fill right now on my '18 with 39K. Bought it used at 23K so doubt it was ever done. 7years with the factory coolant, seems like it's definitely time.
  13. Feb 28, 2025 at 7:20 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    These are much more affordable, wondering about the build quality and material compared to Cali Raised or Charvonia option.
    I found their bed side anchors: https://www.amazon.com/RENO-Tie-Down-Anchors-66312-0C010/dp/B0DK89YSLZ
    as well as the bed rail anchors above: https://www.amazon.com/RENO-Tie-Down-Anchors-PT785-35050-S1/dp/B0DK88S1BB
  14. Feb 28, 2025 at 8:20 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I ordered both, I am frequently having little issues when I tie down using the oem stuff, I think this will relieve a lot of it. It's mostly holding hooks and placement options, not that the hardware isn't decent on the truck stock.
    TundyManFL[QUOTED] likes this.
  15. Feb 28, 2025 at 9:03 AM
    TundyManFL
    Nice - please let us know how they work out.
    woods[QUOTED] likes this.
  16. Feb 28, 2025 at 9:15 AM
    seydou
    seydou Distinguished Member
    Did you drain driver's side too?
    1lowlife likes this.
  17. Feb 28, 2025 at 9:23 AM
    TacomaTRD4x402
    Southern California
    Nah, I just went based off of what most videos and tutorials recommended. Just drained the passenger side. No need to remove the wheel. Was able to get a hose in there and loosen the 10mm
    Total drained was just about half a bucket..
  18. Feb 28, 2025 at 10:21 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I almost bought the Reno ones, but got the MZS ones that are fairly similar https://www.amazon.com/dp/B0DHXVL2SM put them on last night.
    WHAT A B*TCH one of the 4 bolts was. I had to soak w/ wd40, hammer in a T30 bit (which stripped the bolt), tried a removal bit, then a dremel cut a slot for a large flat screwdriver which didnt work, then ended up sawzall metal blade to cut the bolt head off. The damn threaded bolt base came out by hand w/ my fingers. go figure.
    woods likes this.
  19. Feb 28, 2025 at 10:26 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    Installed the VLEDS tail conversion kit, WOW it lights up the cul-de-sac.
    Install was very quick. maybe 20 minutes from unboxing to operational.
    unboxed, and bulbs conncted to VLEDS wire harness.
    left side done, you can see BOTh top and bottom light up as running lights, and both light up as brake lights.
    right side is stock.
    REVERSE is bright, so bright.
    this switchback is also the turn signal in Orange/Amber now and it too is very bright.
    Might end up removing that tailgate brake light bar...
  20. Feb 28, 2025 at 10:39 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    What PN#'s did you order?
    ATV25 likes this.
  21. Feb 28, 2025 at 10:48 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    I ordered this kit https://www.vleds.com/2.5g-tundra-vt-v6-extreme-tail-light-conversion.html with 5000K reverse bulb color. "V6 Extreme".
    I had a discount code for 20% off automatically applied. That Winter Sale ends Friday, Feb 28 at 4pm PST.
    The ends up being these parts
    1x 2.5G_TUN_V6_VT_PARTS 2004525
    2x V6_BULB_921_S-R 2004171 red short bulb
    2x V6_BULB_EXT_WA_5K 2004613 5K white/amber switchback bulb
    2x V6_BULB_R 2003597 red bulb
    2x V6_CNTRL_EXT_WA 2004898 switchback controller
  22. Feb 28, 2025 at 11:00 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  23. Feb 28, 2025 at 3:08 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Scored an open box ARB twin air compressor from Facebook Marketplace and just had to get it mounted with some goodies from SDHQ
  24. Feb 28, 2025 at 3:24 PM
    AZTundra
    Paul
    Phoenix, AZ
    Is that bracket on the left side part of the SDHQ compressor mount or was that purchased separately (where the fitting and the switch are located)?
  25. Feb 28, 2025 at 3:27 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    bulldog93 and AZTundra[QUOTED] like this.
  26. Feb 28, 2025 at 4:02 PM
    AZTundra
    Paul
    Phoenix, AZ
  27. Feb 28, 2025 at 4:14 PM
    jackienguyener
    Jackie
    2016 Tundra 1794
    AZTundra[QUOTED] likes this.
  28. Feb 28, 2025 at 6:51 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    got mine from @memario1214 and pretty happy with them. He’s the OG of that kit which vled, well.. i say no more..
  29. Feb 28, 2025 at 7:17 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Damn you ! I had to order a set after seeing yours. I have had very good luck with VLEDS products.
  30. Feb 28, 2025 at 9:43 PM
    00h2itr
    00h2itr New Member
    Carolina's
    Absolutely loving my set of VLED's that @memario1214 sent me. Add in the hot tails harness and you've got a winner!
