  1. Mar 10, 2025 at 9:59 AM
    #8971
    Daedalus
    Daedalus New Member
    Ordered both from Ebay, the actual skid plate that mimics the TRD one is on the way, should be here later in the week.
    The rough country cat shield/trans plate was from their ebay store as well, free shipping.
    Total was about $360 for both i think.
    RatPanda likes this.
  2. Mar 10, 2025 at 1:41 PM
    #8972
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I have the same cat shield, been on for about a year and no issues.
    Daedalus[QUOTED] likes this.
  3. Mar 11, 2025 at 9:23 AM
    #8973
    matador473
    matador473 New Member
    2022 TUNDRA 1794
    Not bad just followed the instructions. Note the driver side wire is tan not purple.
  4. Mar 11, 2025 at 4:43 PM
    #8974
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    Added sound deadening material to all four doors thanks to this forum for ideas on application and assembly. Was pretty fun to do honestly and recommended highly if you like to tinker. It’s not hard at all to remove/install door panels. I may do the back wall or floor down the road but honestly already happy with the results.
    The doors close with more thud, it’s noticeably more quiet inside, sound from stereo seems sooo much better, driving it feels awesome and tight, and less pesky rattles! Sorry my explanations suck but just trust me and do it.
    Recommendations:
    - Bought a box 76sq ft. - would have divided the total by 4 so I knew how much could be applied per door. Ended up with about 8 sheets leftover but if I knew would have spread those out and just doubles up or applied to inside door skin.
    - front door puddle lights are easier to plug back in if you knock them out of door panel and pull wire through. Light just pops back on.
    - the front doors/mirror area covers are a pain to pop off. There are two white clips that you’ll have to get out of the mirror mount area to reinstall the cover (put on cover first) I ended up breaking one of them so be aware. Ordered box of 30 from Amazon.
    - take your time. All in all probably took hour per door.
    astrength22, SnowToy, Yaboy and 9 others like this.
  5. Mar 11, 2025 at 4:50 PM
    #8975
    Dudeman PNW
    Dudeman PNW New Member
    24 Limited Hybrid Crewmax SS Red
    Pull out your front seats and use the leftover on the floor. A bit more involved but worth it. I also added Dynapad to mine and it’s so much quieter.
    astrength22, Yaboy, BlackNBlu and 5 others like this.
  6. Mar 11, 2025 at 4:55 PM
    #8976
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Can’t even let the cuts on my hands heal and already getting more ideas lol. Thanks Dudeman.
    Dudeman PNW likes this.
  7. Mar 11, 2025 at 5:08 PM
    #8977
    Dudeman PNW
    If you do the floor, I wouldn’t recommend the Dynapad. Functionally it works well but it was hard to get everything back together. I had to modify the kick panels slightly to get them to fit. I believe the Dynapad is about 5/8” thick. If I did it again I would use sound skins or the Resonix product.
    BlackNBlu and Woodrow bangs like this.
  8. Mar 12, 2025 at 7:16 AM
    #8978
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    Finally picked up my GFC. Pretty happy with it so far.
    Skiomax, 2020Platinum, Yaboy and 8 others like this.
  9. Mar 12, 2025 at 10:35 AM
    #8979
    minium
    minium New Member
    Do you want to sell the OEM shifter knob? I removed mine incorrectly when installing larger cup holders and the retaining pin popped out.........
  10. Mar 12, 2025 at 1:05 PM
    #8980
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Do you still have your Leitner? I'm curious if there's been any issue
  11. Mar 12, 2025 at 1:17 PM
    #8981
    pmichelsen
    pmichelsen New Member
    2013 Rock Warrior 2024 Platinum Hybrid
    Today I dropped it off at the shop, on the list: TRD axles, ICON upper control arms, ICON coil overs (front), ICON shocks (rear), Dobinson springs (rear), and new wheels and tires. I've been waiting to do this since May of last year when I was originally going to do the TRD 3" lift.
  12. Mar 12, 2025 at 2:42 PM
    #8982
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    what bike rack is that?
  13. Mar 12, 2025 at 3:47 PM
    #8983
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Installed the Heritage grill.
  14. Mar 12, 2025 at 4:09 PM
    #8984
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    Installed factory color matched side view mirror covers
  15. Mar 12, 2025 at 4:11 PM
    #8985
    nastycucumber
    nastycucumber New Member
    Ontario
    '25 Tundra
    Added a 2 channel dashcam. For now powdered from the front usb port. Going either 12v tap or dome light or even fuse tap for parking mode.
    Dash cam is VIOFO 229 plus. Ran the power wire to the right , under the dash, footwell and usb port. The rear camera to the left , A pillar , plastic trim by the doors, up the C pillar and by the rear window weather strip.
    Rear support made my a very good neighbor of mine - from here - https://makerworld.com/en/models/830855-toyota-tundra-rear-camera-mount#profileId-775203
    Korj26 and ramnj like this.
  16. Mar 12, 2025 at 4:41 PM
    #8986
    Dudeman PNW
    Truck looks good!
    ramnj[QUOTED] likes this.
  17. Mar 12, 2025 at 5:55 PM
    #8987
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    Loved the GFC on my Tacoma, can't wait to get one for the Tundra. Congrats & Enjoy!
    Dirtsurfer83[QUOTED] likes this.
  18. Mar 12, 2025 at 8:15 PM
    #8988
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    It’s the second generation Recon Rack, before 1up bought them out
    eddiefromcali[QUOTED] likes this.
  19. Mar 12, 2025 at 8:16 PM
    #8989
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    Thanks! Pretty stoked on it, my 9 year old son likes it even more, tree fort on wheels, haha
  20. Mar 12, 2025 at 9:53 PM
    #8990
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Working on my bumper install and got my lights today. Strands Lighting Division has some unique DRL’s for the rounds and cubes.
    Committed now- old CBI stealth bumper coming out
    Test fit
    Had to build new fog light mounts in the center for my diodes
    Options!
    Driving light DRL’s
    SnowToy, cody.tx, Mr Rick and 8 others like this.
  21. Mar 13, 2025 at 8:59 AM
    #8991
    Prescott87
    Prescott87 New Member
    Jonah
    Brentwood, Ca
    2022 Supersonic Red Limited
    TRD Filters, De-Badged, TRD Pro Grille
    Dropped off the Tundra yesterday for the new engine. They told me it should be done by Saturday.
    They gave me the Taco as a loaner. This thing is not built for anybody over 6ft haha.
  22. Mar 13, 2025 at 11:15 AM
    #8992
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Dropped off my truck to get the engine replaced, as well as getting some other little things looked at, and they gave me a ‘24 4Runner as a loaner. I’ve been a passenger in one before, but never driven one. Wish they gave me a new one so I could drive the new power train. I miss my truck already - this thing is gutless and gets the same mileage as my truck on e-load 35s lol.
  23. Mar 13, 2025 at 12:13 PM
    #8993
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Awesome neighbor, looks great
    nastycucumber[QUOTED] likes this.
  24. Mar 13, 2025 at 12:17 PM
    #8994
    eddiefromcali
    Eddie
    100% Stock
    I was offered a Taco or a Tundra...took the Tundra. Wife wanted me to get the Taco but I've sat in the prior gen and figured it was just as bad....she's 5'1 so it would fit her perfectly. lol
  25. Mar 13, 2025 at 1:03 PM
    #8995
    cody.tx
    cody.tx New Member
    decided I didn't like the $129 GST non-optional "option" black tailgate inserts. came off so easily it's like they didn't want to be on there.
  26. Mar 13, 2025 at 1:59 PM
    #8996
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Ordered and installed some Tuxmat mats for my 1794 Limited Edition. The provided Velcro clips and slide in clips really made for a nice, tight install. The mats that came with the truck are nice because they have the 1794 LE branding on them put they never covered all the carpet and plastic like these do. Very happy with them so far!
  27. Mar 13, 2025 at 2:19 PM
    #8997
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    LE mats looks really cool. Never seen them before.
  28. Mar 13, 2025 at 3:15 PM
    #8998
    slowboater
    slowboater New Member
    Vancouver, BC
    those are some cool looking seat covers. what are they? i'm not going back through 300 pages to see if you posted on them! :)
  29. Mar 13, 2025 at 3:18 PM
    #8999
    SilveradoSwap
    They are oem for the 1794 limited edition, includes the seat back saddle style bags
  30. Mar 13, 2025 at 3:19 PM
    #9000
    slowboater
    Vancouver, BC
    Thank you. That makes them really expensive seat covers. :)
    Appreciate the info.
