  1. Apr 17, 2025 at 1:18 PM
    shifty` Kill another whale with your power
    Oh, and I'd be an asshole if I didn't show the tip of my old antenna and its wear-down from years of parking deck ceiling and garage door dragging.
    Just the tip.
  2. Apr 17, 2025 at 1:31 PM
    siznarf
    siznarf Not New Member
    Kommiefornia
    04 DCLB 4.7 4WD - 07 RCSB 5.7 4WD -
    Ordering a PCV valve for my 2004 (screw type, no grommet) - do I need OEM? If so, who makes the OEM valve?
    :thumbsup:
  3. Apr 17, 2025 at 1:33 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    biometrics says you looked at those for 126sec.
  4. Apr 17, 2025 at 1:35 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  5. Apr 17, 2025 at 1:38 PM
    siznarf
    Kommiefornia
  6. Apr 17, 2025 at 1:40 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Agree with the information others have shared about this, but I want to say that replacing the springs is really important. I replaced my shocks with new 4600s, but it turns out that my biggest issue was that the springs were worn out. A year later, and the springs are so shot that it bottoms out on nearly every bump. Brutal.
    EDIT: Just realized that it's got aftermarket strut assemblies with non-reusable springs.
    MooreKen[QUOTED] likes this.
  7. Apr 17, 2025 at 1:43 PM
    siznarf
    Kommiefornia
    G_unit3000 and des2mtn[QUOTED] like this.
  8. Apr 17, 2025 at 1:56 PM
    des2mtn
    SW
    Tonto cover
    I paid $10.70 plus $0.91 tax the other day down in SD which is why I have the P/N handy. There's a slightly closer dealer to me, but they charge full MSRP.
    There's some dealers on the east coast that have decent pricing and free shipping if you spend enough, sometimes there are even better sales through them like a 25% off that just ended.
    @shifty` has some good advice here.
  9. Apr 17, 2025 at 2:07 PM
    Teeing off @des2mtn 's excellent reply...
    I took the zip code of my previous employer's office on Sacramento St. downtown SFO (94111), and plugged it into the Toyota Parts system for part 12204-50030.
    It gives me the three dealers below as the closest nearby "participating dealer" options. I found the following by clicking the 'Shop this Dealer' button, then the BACK button, then the 'Shop this Dealer' button for each:
    • SFO Toyota : $12.52 before tax if you order via the Toyota parts website instead of at the counter; basically half what you paid, and you walk straight into the same parts counter to pick it up, while paying half as much.
    • Walnut Creek : $11.79 before tax if you order via the national parts website instead of at the counter; even cheaper still
    • Swickard 101 : Also $11.79 before tax thru the nat'l website.
    Bottom line:
    If you'll take a minute to read the sticky thread section, like this one for example which covers parts, or this one that covers shedloads of 1st gen info, you can potentially save a veritable FUCKTON of money and potential hassle/failures. You can save upwards of 40%, 50% or even more on parts, and with some of these parts having an MSRP of $700+, that savings is substantial. Sometimes the same price as shittier aftermarket parts, or cheaper than the aftermarket!
    YMMV, different regions/areas have different participating dealers, this is a better option for people like us near big cities. Being in the Bay Area, I think the example I'm showing you should prove, you can save considerably.
    des2mtn likes this.
  10. Apr 17, 2025 at 2:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Don't know if you've been helped yet, but as I see it...
    You're only course of action is to drill out a 6mm or 6.5mm hole and stick an M6 bolt through it to "replace" your studs. You may be able to permanently attach them with jb welb
    Or replace that piece of body work entirely
    Dblock500[QUOTED] and shifty` like this.
  11. Apr 17, 2025 at 2:16 PM
    Shit. I just remembered, you're in Cali.
    For the record, my "fuckton" reference, I don't want to be confusing. I'm not speaking in California terms of "metric fuckton" which I believe is 420g³. My usage is purely figurative. "A lot".
    siznarf, Hi06silver and 805Tundra like this.
  12. Apr 17, 2025 at 3:31 PM
    Only time reception really makes a difference is when you have marginal reception originally.
    Optimal length for the highest passive gain is a little over 1/2 wavelength of the frequency you’re trying to tune using a monopole antenna.
    shifty`[QUOTED] likes this.
  13. Apr 17, 2025 at 5:56 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Here's the sawhorse set up pretty simple. 48" boards connecting them. Allows sufficient length for bottom side of bed to sit on
  14. Apr 17, 2025 at 6:23 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Thank you--yup, thats exactly what I ended up doing--just finished it yesterday. Drilled them out and added 1/4inch bolts with washers and nuts. Seems to be working well, also replaced the plastic push panel clips holding the side marker and light assembly that are prone to rotting away and breaking after a while. https://www.toyotapartsdeal.com/oem/toyota~clip~luggage~compartment~90080-46294.html
    Hutcheson, bmf4069 and shifty` like this.
  15. Apr 17, 2025 at 6:34 PM
    This reminds me. I was going to look around and see if anyone makes a basic scissorjack that I could use to lift my shell enough to redo the seals, pull my bedliner, then potentially drill and fill the hairline crack in my shell. I'm super limited on space, and the bottom flare on these Leer 100R isn't conducive to laying on the ground.
  16. Apr 17, 2025 at 7:56 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    This is my setup. I have some sawhorses underneath. I’m going to have a buddy help get my topper off and rent an engine joist to remove my current bed. I’m gonna give myself a cookie if I can do it all this weekend.
  17. Apr 18, 2025 at 1:51 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Yeah…. The previous owner mounted them himself which leads me to believe there was no alignment done. Amazingly it drives great on the highway but since I put $1300 tires on it it would be nice to make sure it’s aligned properly.
    I’m very much a NOVICE when it comes to suspension but I think I have narrowed down what I need and it’s actually not too expensive. I’m tax exempt at Tire rack and Rock Auto so I’ll probably get them there. I did notice that the ARB (Old Man Emu) site said that 2883/ 2884 were not compatible with my truck but I think they work fine (per you guys) And it looks as though KYB Strut Mount Plates SM5413 is now superseded with SM5442.
    In a nutshell as long as I go with either 4600 or 5100 Bilsteins and OME 2884 Springs and get 2 KYB Strut Mount Plates …. I should theoretically be able to keep my trucks current appearance and fingers crossed improve my ride quality.
    FiatRunner[QUOTED] likes this.
  18. Apr 18, 2025 at 4:42 AM
    Openbaffle
    Openbaffle New Member
    Got my blocks. Going to install them. iOS 18.4.1 and CarPlay holding strong. Glad I don't have to replace my stereo head unit. Just got an oil change. Oil pan seal is leaking a bit, but not enough to do anything about right now. So is my tail seal but not enough to worry about right now.
    The Black Mamba and shifty` like this.
  19. Apr 18, 2025 at 7:36 AM
    Wow, the pan is leaking? Has it ever been dropped before? We rarely ever see pan leaks on here unless someone popped it off at some point. I dunno wtf they sealed the pans with from the factory, but I wish they would've done the same on the valve covers...
  20. Apr 18, 2025 at 7:38 AM
    Meanwhile, the richie-riches over in Ketchum are probably, like, "Who the fuck stole my street sign?!" :rofl: :D
    Love it!
    Kimosabe[QUOTED] likes this.
  21. Apr 18, 2025 at 9:03 AM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Softopper Deal if anyone is in the market.
    Filthyphil and Nicklovin like this.
  22. Apr 18, 2025 at 11:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Scared this sum bitch so bad I made it shut down :rofl:
  23. Apr 18, 2025 at 11:12 AM
    Is that a manx, or is its tail just tucked away?
    Just chillin' in that there garbage or what?
  24. Apr 18, 2025 at 11:18 AM
    Dblock500
    DMV
    Based on appearance alone, looks like a definite upgrade that I'll do. Will stayed tuned for the functionality report after you get a chance to try it for a while
  25. Apr 18, 2025 at 11:29 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It was accidentally locked in my MIL's garage for almost a month. I'm guessing it ate it's tail
    Animals are more hard core than any of us could ever hope to be
  26. Apr 18, 2025 at 12:20 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Add-a-add-a-add-a-add-a-add-a-leaf.
  27. Apr 18, 2025 at 12:31 PM
    I dunno man, there are some pretty hardcore MF out there: https://www.cmu.edu/magazine/03fall/aralston.html
  28. Apr 18, 2025 at 1:07 PM
    Dakillacore
    Georgia
    I am whooped.
    LBJ's, Tie rod inners and outers, dust boots all done. All OEM, minus the MOOG inners.
    The outer tie rods originally installed
    were aftermarket. The LBJs were too. Both side LBJs had 15mm bolts instead of the 17mm that is OEM. The driver side LBJ castle nut was a whooping 27mm! The passenger side was 24mm. Very, very odd. Had to make 2 trips to the parts store. Broke 2 LBJ removal tools, but advance swapped it out so I only paid once. It was garbage quality anyway.
  29. Apr 18, 2025 at 1:14 PM
    Congrats dude. I'm personally not a fan of that specific style of puller.
    Meanwhile, it's worthwhile to keep a yellow paint pen on-hand. I mark the position of my bolt heads, marking the head and the LBJ with a line. I check them after a few hundo miles to make sure they haven't moved, and usually peek over at them at every oil change to be sure. I do this with any "mission critical" bolts where failure would be a 'bad day'.
  30. Apr 18, 2025 at 1:16 PM
    Dakillacore
    Georgia
    Thank buddy. Good idea. I'll do that now.
    Removing the LBJs were a pain in the ass. They were both stuck on really, really good. Bought an $8 fork tool from harbor freight to use after both of those garbage tools broke.
