Accurate tire pressure gauge
Discussion in 'General Tundra Discussion' started by Tundramoney, Apr 19, 2018.
  1. Apr 19, 2018 at 2:45 PM
    Tundramoney
    Tundramoney [OP] Old school
    Earth
    What tire pressure gauge does everyone use that is the most accurate?
  2. Apr 19, 2018 at 2:51 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I like my Tire Tek Flexipro :D.
    ColoradoTJ and nk1794 like this.
  3. Apr 19, 2018 at 2:52 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Tundramoney[OP], rons23 and JoshuaA like this.
  4. Apr 19, 2018 at 3:10 PM
    nk1794
    San Jose, CA
  5. Apr 19, 2018 at 3:17 PM
    Not even remotely a gimmick. Liquid filled gauges are very common actually. Liquid is usually Glycerine. Glycerine acts as a dampener to mechanical vibration and pressure spikes making liquid filled more accurate in high vibration environments and the internals are lubricated reducing friction and condensation. We calibrate 1000's of liquid filled pressure gauges in our cal lab each year.
  6. Apr 19, 2018 at 3:23 PM
    nk1794
    San Jose, CA
    Awesome! Thanks for the education. I bought one from Autozone the other day because I was curious. I'll have to do a comparison with the other two.
  7. Apr 19, 2018 at 3:24 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    X2
  8. Apr 19, 2018 at 3:28 PM
    The ideal method of comparison is using a calibrated pressure standard where not only do you check for accuracy but you need to check hysteresis and linearity. Simply comparing PSI readings at tire valve proves nothing unless you have actual calibration data at cardinal points for the pressure gauge in question and a similar calibrated pressure gauge to use as the "Standard" and even then you can't check hysteresis or linearity...
  9. Apr 19, 2018 at 3:33 PM
    nk1794
    San Jose, CA
    Matt, I think I could accurately say that you are more accurate than any liquid filled gauges out there. I'll call you when I need tire pressure check. :bowdown: :D
  10. Apr 19, 2018 at 3:33 PM
    Amazon sells very decent WIKA industrial pressure gauges with 1% accuracy. All you have do is attach a short pressure hose and tire valve stem adapter. We make our own and calibrate at work. About $90
    nk1794 likes this.
  11. Apr 19, 2018 at 3:35 PM
    And both may be wrong....
    nk1794[QUOTED] likes this.
  12. Apr 19, 2018 at 3:36 PM
    nk1794
    San Jose, CA
    That's why I bought a 3rd :rofl:
  13. Apr 19, 2018 at 4:00 PM
    I use the ARB one.
    ColoradoTJ likes this.
  14. Apr 19, 2018 at 4:06 PM
    The ARB is actually pretty good for the money. The movement is brass and also has a bronze Bourdon tube that more expensive gauges have. I believe ToyTec has them..........:thumbsup:
  15. Apr 19, 2018 at 4:14 PM
    I can get yours calibrated......for free............
  16. Apr 19, 2018 at 4:36 PM
    nk1794
    San Jose, CA
    Sound like I could use a 4th one.
  17. Apr 19, 2018 at 4:43 PM
    The old school pen type where gauge pops out
    Black Wolf likes this.
  18. Apr 19, 2018 at 4:48 PM
    They can be as much as 10 PSI off!!!!!!
  19. Apr 19, 2018 at 4:51 PM
    nk1794
    San Jose, CA
    What if he drops it in a puddle. Would that make it liquid filled and more accurate? :D
  20. Apr 19, 2018 at 4:52 PM
    That's what my Dad always used so I just went with what he always did
    Black Wolf[QUOTED] and nk1794 like this.
  21. Apr 19, 2018 at 5:03 PM
    As long as it is MGM.....Good to go.....:infantry::deadhorse:
  22. Apr 19, 2018 at 5:49 PM
    This is what I have.
  23. Apr 19, 2018 at 5:52 PM
    I was letting the good folks here know that ToyTec sells them. :thumbsup::thumbsup::thumbsup: I think there are a few ARB tire gauge, deflate kits on ToyTec's site...
    T-Rex266[QUOTED] likes this.
  24. Apr 19, 2018 at 6:13 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
