01 first gen trailer wire diagram
Discussion in 'Electrical' started by Dparron, Mar 16, 2023.
  1. Mar 16, 2023 at 8:39 AM
    Dparron
    Dparron [OP] New Member
    Derek
    01 tundra
    Limited
    Hello all,
    trying to put a 4 plug trailer harness on my truck. Went and bought the Curt’s wire harness to plug and play and it doesn’t quite work. Been trying to troll through these threads to find a wiring diagram for the truck so I can cut and re wire them direct. I know there is some issue with no brake wire coming all the way back, and was wondering if anyone knows the combo for the greens at the rear bumper T wire bunch. There is green with black line, green with yellow line, straight green, etc. I know something with that has to go to the yellow and brown for the blinkers. Any help would be super handy. Been test touching wires and have running lights, along with 4-ways, but can’t figure out the blinkers/brake.
    Thanks ahead of time.
  2. Mar 16, 2023 at 8:45 AM
    Retired...finally
    A flat four has ground, running lights, right stop and left stop. This works for vehicles that use the same bulb filament as turn signals. Vehicles with a separate turn signal, i.e., amber lenses are required to use a converter box between the vehicle and the trailer.
    I know this doesn't answer your question directly but may help you understand your problems.
  3. Mar 17, 2023 at 4:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Shouldn't matter but which Curt harness plug did you get ?
    As for the colors you mention, I believe you're referring to the wires at the trailer converter mounted left rear corner of bed ?
    The circled conductors in below pic are heading from converter to trailer socket. I would be checking at trailer socket for proper voltage and reaction when exercising, running lights/blinkers, back-up, tail etc and then tap into trailer wiring accordingly.
  4. Mar 17, 2023 at 6:47 AM
    Dparron
    Derek
    01 tundra
    Limited
    Thanks for the reply’s.
    These are the greens I’m talking about. But not sure if they are aftermarket BS the previous owners put in
    we got current to some of the wires as we tried the blinkers, but trying to see what the truck is for the brake lights.
  5. Mar 17, 2023 at 7:36 AM
    Retired...finally
    Have you tried your brakes while checking the turn signal wires?
  6. Mar 17, 2023 at 8:18 AM
    Dparron
    Derek
    01 tundra
    Limited
    Yes. Throughout testing different wire options, was tapping brakes
